Question about Mtd 46" Dozer Blade, Fits All & Yard - Man Lawn & Garden
Yardman 42" lawn tractor. the blade bolts to a shaft, on the shaft is some kind of bearing and above that is a pulley. where can I find the bearing?
    Sergeant:
    Champion:
  • 226 Answers
You can't find just the bearing as this is a pressed and molded race set.you'll have to buy the set.i suggest(partstree.com).i get alot of my parts there.put your make &model# in then click deck assembly i'm sure they'll have what you need hope this helps
Posted on Jul 15, 2009
How do you check to see if Drive pulley bearings are bad
take belt off, grab blade at end and watch center bolt move more than a little bit or swing by itself when turned loose. Try turn blade with hand to feel bearing roughest is another way
Jul 13, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
HEAVY VIBRATION OF MOWER DECK (CRAFTSMAN17.5 HORSE TRACTOR?)
Even new blades can be out of balance, but my guess would be either the other blade spindle, or the tensioner pulley bearing.
Apr 05, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Yardman AE5165 Ride on. the belt that drives the cutting blades breaks regularly. Is this a common problem and is tere a solution
Check your spindles and housings. This is what the pulleys sit on top of. It sounds like the bearings may be bad on one of them, or the pulleys themselves may be bad. The shaft itself could be bent causing the pulleys to be crooked, thus shredding the belt.
Aug 28, 2011 | Yard Man Garden
The bolt holding the blades is broken off
Your st bet is to replace the entire spindle assembly.
It's not as cheap as drilling out the old bolt and using an "easyout" tool to remove it, but the outcome is certain.
Better yet do a web search on "137645, 137646 Shaft Kit For 130794 Mandrel, AYP" and you can find the shaft only with bearings.
On Amazon:
Sep 06, 2010 | Craftsman 21 Hp 42" Lawn Tractor Riding...
Smoke when blades engaged on yardman 42'' yard tractor
The oil on your pulley could definitely be the culprit. You need friction in order for your belts to work properly.
Apr 17, 2010 | Mtd Garden
I need to replace the entire blade and blade shaft but I cannot get the blade shaft and belt wheel off. Is there a trick to getting it off?
YEP BIG IMPACT Its best some times on AYP which is the MFGR of Craftsman to replace the whole thing. Casting, shaft and bearings. Drop the deck.put a peice of 2x4 or 4x4 between the housing and the blade,then take the pulley nut off with a 1/2 impact or a breaker bar and a 4 ft piece of pipe for a Cheater bar. This may take 2 people to do depending on your tools. All new housing and shaft and bearing is about $60 u may find em cheaper on Ebay.
Oct 21, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
Removing pulleys from 42 inch Craftsman mower deck
Put the blade back on the star on the shaft and tighten it down. Now you have some backup for the pulley nut. You may have to wedge a 2x4 between the blade and deck. THe EASIEST way is get an impact and zip it off. :-)
Jun 15, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
I sharpened the blades at the end of last mowing season. The next cut was very uneven, so I checked to make sure that the blades were installed properly and re-leveled the deck. The last cut was even...
The problem you discribe is the classic broken blade spindle or quill. The tube that supports the bearings between the deck pulleys and the blades is almost certainly broken. Look under the deck [mower OFF] at the piece right above the blade that is malfunctioning and you will probably find a bad bearing or a chunk of the tube that holds the bearing/blade to be missing. That happens when the blade gets 'wacked'. The outer edge is cutting too high because the belt is pulling the shaft toward the center of the deck. The quills are fairly easy to replace. Get the model number off your tractor before you go to buy the part.
Apr 04, 2009 | Craftsman 42 in. Precision Cut Plus 24hp...
Mtd 46" Dozer Blade, Fits All  & Yard - Man Lawn & Garden Logo
189 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
