SOURCE: Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
SOURCE: Vizio LCD 37 Inch Turns Off Randomly
This could be a main board or power board issue. replacing main board and/or power board should resolve this problem.
I had a similar problem with my 32 inch plasma tv. I called vizio's
1 800 number and the guy said to unplug the tv from the wall and hold down the power button for a minute and then plug the tv back in outlet and turn on. And it works I guess from what I understood from his heavy accent was that the tv retains power and this resets it somehow. hope that was helpfull!!
SOURCE: emerson 42 inch plasma (Walmart special) need code
Try the Samsung codes that are in the manual for the remote. The Emerson is a rebadge of a Samsung. My Dish remote worked poorly with the Emerson codes but the first Samsung code I tried worked beautifully! :)
SOURCE: my vizio 50 inch plasma tv will not turn on. what
Tries unplug,replug about an hour,see if it reset itself.Not than must replaced the signal tuner board.Plasma have this problems alot.
