Question about Samsung LTN1565 15 in. HD-Ready LCD Television
I moved this TV to another room about 10 days ago and it worked fine. A few days later I hooked up a dvd and I had audio but no picture. Screen is lit but blank. Unhooked everything, hooked it up again and it worked fine and played dvd fine. I just turned it on again (several days later) and again have no video, just audio.
  • 304 Answers
You probably have a bad Main bd and needs to be replaced. Contact 1-800-SAMSUNG for the part number or have a trained Samsung tech repair the set.
Posted on Jul 16, 2009
How to fix problem with TV that has no sound or picture?
Take it to a Samsung repair centre. It boards that need replacing, and there are many. You have to swap out the right ones.
Mar 28, 2017 | Televison & Video
My picture display is narrow and does not cover the screen.
Does the Genie box have screen settings in in? Sometimes hd will show in smaller screens. Makes the picture nicer. If you adjust the screen size with your remote the high definition "niceness" will not be there.
Jul 30, 2014 | Seiki Televison & Video
Our TV has been perfect for many years. We now suddenly have the picture compress, if you will, to the bottom 2/3's of the television screen, and it makes an angle like a triangle going toward the bottom....
This fault sounds like failure of the LINE OUTPUT TRANSFORMER.
It can be fixed, but may cost you around $120, possibly more if you have to call out an engineer.
Best NOT to use the TV as it is, because it could possibly damage the system.
If you do use it, this line will become permanent and if you get the TV fixed later, there will always be a burnt section of the screen where the line was - so I suggest you either pay to get it fixed right away, or consider buying a replacement.
Hope this helps!
Mar 08, 2011 | Sony KV-32S42 32" TV
My toshiba sdk990ku dvd player stopping playing the audio. Have connected via HDMI to LCD HD tv and worked for months! One day audio stopped, but picture is fine. Tried different HDMI cables, dvds with no...
Tries unplug,replug it back like an hour later.Letting the DVD player resetting itself back to the factory setting.Tries it than,see if it work than.Not,than tries hook it up with the RCA component cable Y,R,W.If still have the same problems,the PCB in the DVD player is bad.Not worth repairing.Trash it.DVD players are very cheap these days.U can get a brand new one like for $40 dollars.
Nov 18, 2010 | Toshiba SDK990 Player
Everything works but the picture; even on screen programming
try pluging cable wire directly to the tv to see if you get a picture you may have shorted out the rca connection may need to be repaired good luck.....
Jan 11, 2009 | Emerson EWC1301 Combo
Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Dec 03, 2007 | Toshiba 27AF45 27" TV
Mitsubishi vs 5051 rear projection tv sound but no picture
No video but good audio Mitsubishi VS5051. Check R509 and R 519, 100 ohm resistors located on the main PCB near the flyback transformer. Also bad connections on any of the yokes and the vertical output IC will cause the same problem.
Sep 19, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Will not work with cable
The set has a problem with the tuner itself and there are no resets in this new sets,you should remove the back cover and carefully tap with a wooden or rubber handle the tuner area where the cable comes in to see if a channel would tunes in,if it does react is likely it has loose conections in the tuner grounds or pins,the conector where you screw the cable to can not be loose either,it should be nice and solid,if you are familiar with tv service is something you can try but if you are not too familiar call for assistance from a servicer or just save the money and use a vcr to change the channels using the same imput as the dvd player unless you have two separete aux.imputs. Let Us know if you need more information.
Nov 10, 2006 | Sony KV-35S45 35" TV
Samsung LTN1565 15 in. HD-Ready LCD Television Logo
156 people viewed this question
Jerry Greenberg
Jerry Greenberg
