Question about LG LRBC22544 Bottom Freezer Refrigerator
The water tank in my LG LRBC22544 refrigerator is leaking (apparently a common problem). I have a new tank assembly but can't find instructions on how to replace it (I'm now sure how the tubes connect).
  • brewer116 Jul 15, 2009
    Problem is solved. After taking a close look at the new tank assembly it was not hard to figure out how the tube connected to the tank. Just had to pull the black (or blue) retainer clips out so that the retainer can be pushed in, then the tube easily pulls out. Done in about 3 minutes.
4 Suggested Answers
  • 159 Answers
SOURCE: Problem with water flow in LG LRBC22544 Bottom Freezer Refrigerator
Sounds like you have excess pressure building up in the water system. Is the water dispensor working? If not it sounds like you have a frozen line somewhere or the valve in the door is not working to allow the water to dispence.
Posted on Jul 13, 2007
SOURCE: Refrigerator leak
the water fill tube for i/m is on the back of ref. the tube you have is to the water dispenser. look in freezer floor, is it full of ice? if so, remove all ice and clear drain hole for evap. if not, reassemble what you took apart and inspect tube under ref. while someone runs water dispenser. find leak and repair.
Posted on Sep 15, 2008
SOURCE: I have an LG fridge
I have had the same problem. In my case, its the little water tank behind the left crisper. The tank has cracked (twice now) which means replacement (again). The water leakage gets so bad that it leaks into the freezer causing ice up problems in the rear.
Posted on Jul 15, 2010
No water in water dispensor
Don't forget that your dual water control valve has two sides. One side is for the ice maker and other side is for water dispenser. The water dispenser side may have recently failed causing water to not enter water filter area or dispenser, Thanks Sea Breeze
Feb 21, 2012 | LG LRBC22544 Bottom Freezer Refrigerator
I am continually getting a frozen sheet of ice beneath the deli drawer
Hi this is your water tank leaking due to it freezing from too low of temperatures, this particular model, had problems with damper assembly leaking, you will need to change out the water tank, but before you do that you need to fix the temperature problem, which requires adjusting or replacing the damper assembly in the back of the refrigerator at the bottom, You can install a bigger gasket or the new damper comes with one. If you need futher assistance let me know.
Sean
Mar 27, 2011 | General Electric Profile PFSS2MIXSS...
I have an LG fridge (LG LRBC22544) that collects water underneath the crispers. It freezes (almost 1 inch thick) and then melts. Once it melts, then it leaks out the door. This reforms every 3 weeks or...
Apr 27, 2010 | LG LRBC22544 Bottom Freezer Refrigerator
Water Leaking From Under LG LRFD21855 Refrigerator
yep, it looks like a frozen drain pipe. to solve it , defrost your frig for 24 hours. if that doesn't help, see the following page for details how to fix it. http://www.schneordesign.com/Avi/LG/LG819_fix.htm good luck Avi
Sep 16, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
I have a lg fridge/freezer and water flows from the bottom of the freezer in two channels. What is causing water to flow? Bottom draw of freezer is frozen to the floor of the freezer compartment. Help...
You have a blocked drain hole at the bottom of the fridge put very warm water in the the drawers and remove once they un thaw then remove them and clean the drain hole in the bottom. If you need more help just post here and I will give you more informaion, also if it's got a lot of water you will have to remove the drip pan and drain it out
Aug 26, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Fridge is no longer cooling. ER where the
Sounds like the FF(Freezer Fan) is wearing out or is worn out. This assembly supplies the circulation for the freezer as well as the refrigerator. When is slows down or stops the circulation of cold air to the refrigerator is the first thing that is effected. The minimum cost to replace this assembly is around $300.00
Jul 10, 2009 | LG LRBC22544 Bottom Freezer Refrigerator
Water tank assembly question??????? again
i believe the water line is removable and you will be able to use the hose that is already there. it will have a collar that you depress tehn remove the hose. thanks Peyton
Feb 22, 2009 | LG LRFD25850 French Door Refrigerator
LRFC22750TT French Door/Bottom Freezer ER/FF Error
the ff error code means freezer failure.you need to replace the defrost control assembly in the freezer compartment behind the back panel..and the evaporator fan may be out also..mark at applianceliquidators@verizon.net or 503-406-7179
Aug 16, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
Back reservoir
Kiwy, your part number for this reservour is 4838jj1003a. Since they had a lot of problems with this tank they replaced it with coiled plastic tubing. You can find the replacement part at repairclinic.com, it will show you a picture of it. Or you can go down to your local hardware store, buy some 1/4 inch plastic tubing for water and 2 quarter inch John guest fittings to hook it up. That's all it is now, is coiled plastic tubing to chill the water. Catriver.
Dec 28, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
Jul 13, 2007 | LG LRBC22544 Bottom Freezer Refrigerator
LG LRBC22544 Bottom Freezer Refrigerator Logo
496 people viewed this question
Top LG Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
christian nielsen
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
