Question about Maytag SAV571EEWW Washer
Maytag Washer, SAV571EEWW
It looks like the brake pads are in the bottom broken up. The washer spins 1 direction when in agitate cycle.
  • 447 Answers
Re: Maytag Washer, SAV571EEWW
Yes if the pads are damaged it will spin in agitation. Pads are easily replaced.
Posted on Nov 17, 2007
0 characters
3 Points
The washer stopped spinning and agitating. The motor runs, the belt turns all 3 pulleys. The main pulley will turn the agitator by hand. When the 6 screws are not attached to the brake stator the machine...
1) Check the imbalance/lid switch FOR continuity. Check also the speed selector switch (if any), the water level and water temperature switches for proper operation .
NOTE: If any of the selector switches on the console are only partially pushed in, it may cause improper function.
2) Check for a broken or badly worn belt.
3) Check the motor rollers and tension springs for damage and the motor roller tracks for jamming. Any of these might cause the belt to be loose.
4) Check the appropriate timer circuits for continuity.
5) Remove the belts and see if the motor will start. If you hear the motor buzzing, but it doesn't start in either or both directions, test the capacitor (if any) and starting switch
If it does start with the load removed, turn the pump and transmission pulleys by hand, in both directions, to see which is locked up. If the pump is locked, If the transmission pulley is locked,. Note that the transmission pulley will normally be very stiff when turning it in the clockwise direction, as you look at the bottom of the washer.
Nov 14, 2010 | Maytag PAV2300 Top Load Washer
Spinning cycle
When it is spinning, there is no agitation. Why? there is 1 motor with 2 directions to provide sinning and agitation by 2 different mechanisms. The sound from spinning, and rinsing could be some worn out parts from the mechanism need to be inspected and replaced accordingly such as the pulley, the clutch, the brake and 8 springs from bottom tube hung to the chassis to keep the tube balance under the load. Hope this can help.
Jan 08, 2010 | Whirlpool LSN1000LW Top Load Washer
Maytag Performa PAVT920AWW washer makes a squealing sound
i am sorry but i had this problem happen before with my customer maytag performa, what i found out is that the brakes become crystallized, causeing a squeaking noise, remember in agitation, the brakes stops the the drum from spinning, what i advise you to do is change out the breaks or take the brake pads and rub them with sand paper
Aug 23, 2009 | Washing Machines
Clacking sound on agitate cycle only, no noise on spin
The agitate cycle uses the motor and a spring to function. The spring is made in pieces and asit gets older some of the sections of the spring break. To verify that it is not a loose drum. Ope the washer during the wash cycle andhold the drun by hand. If the noise stops lool for the loose bolts or replace the springs, they may be weak after that many years.
Aug 18, 2009 | Washing Machines
Screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
Feb 28, 2009 | Maytag Dependable Care LAT9706
This is probably a timer problem. In maytag washers the motor turns in one direction to wash, the opposite direction to spin. The timer decides which direction to start the motor.
Jul 05, 2008 | Estate TAWX700JQ Top Load Washer
Maytag won't agitate during wash
sounds like you have a broken sety fo brake pads, just replaced a set today for same reason, open the lower acess panel and with a flashlight look into the bottom , your lookin for brake pads( theyre probably broken and laying under unit.)
Apr 28, 2008 | Maytag SAV4655A Top Load Washer
Maytag washer sav571eeww
is the machine level and on a solid surface is thia a new machine
Mar 27, 2008 | Maytag SAV571EEWW Washer
Maytag SAV571EEWW Washer Logo
179 people viewed this question
Top Maytag Washing Machines Experts
Richard Roth
Richard Roth
Al Clark
Todd Marr
Todd Marr
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
