Question about Sanyo DS20930 20" TV
Turning off Video2 without remote.
I no longer have the remote to my Sanyo, last time tv was used it was left in Video2 mode, I have tried the manual set button on the front of the tv but it will only let me change language and auto adjust for color, contrast ect How do I reset or turn Video2 off till I receive another remote?
Posted on Dec 06, 2007
Sanyo AVM-3259S TV is stuck on video2 remote is lost. How do change video input? Right now I can only play video games on it.
As the TV has no menu button on its front panel, you must have its remote control to select inputs.
Jul 22, 2013 | Sanyo AVM-3259S TV
Cannot get the tv into 'video1' (or ' video2') mode
Unfortunately you need the original remote. There is still a good chance you can find a Sanyo universal remote. Check your local Circuit city or Super K mart or Walmart and look inthe electronics sections. I have often seen the Sanyo universal remote! And yes it will have the options you are looking for. Good Luck!
Apr 19, 2010 | Sanyo DS27820 27" TV
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
Sep 29, 2009 | Sanyo DS31520 31" TV
Reprograming my tv remote
Hi chevry,
universal remotes vary with respect to button options. For a Sanyo TV you can try these codes. (This is manual mode).
0098, 0066, 0091, 0023, 0017, 0027, 0080.
Press the TV button on the remote. Than press & hold the set button until the LED stays on. Enter the four-digit code. When the remote control recognizes the correct code the LED will turn off. If the code is not correct the LED will flash several times & stay lit. Enter the next code. (You'll have less than 25 seconds to try another code) or the remote will exit the programming mode.
How to use the auto search. (One code at a time). This will take some time.
Turn on the TV. Press & hold the set button until the LED comes on, point the remote at the TV & press the volume + once (This moves the remote through 1 code at a time. Continue to press the volume + (Do not do this very fast or you'll miss the correct code), until the TV turns off or changes channel. Than press the set button again & the LED will go off. The remote should now be programmed for the TV. Test TV by turning the on/off button on remote. Check volume up & down.
Good Luck!
Jul 04, 2008 | Televison & Video
Sanyo DS31520 TV
I am relentless when it comes to problems like this. I had the same problem with my TV being stuck in video mode. I found out that there is a reset button......It's on the @*&#^&^ original remote!!!!! So I tried programming my Time Warner Scientific Atlanta AT8550 remote for the TV to see if the "video source" button would work. IT WORKED!!!! You have to use code 1062. Instructions are:
1. Turn the TV on.
2. Press and hold select and the TV keys until the lights blink twice.
3. Enter 1062. All mode keys blink twice to indicate that the code was accepted.
4. Point the remote at the TV and press power to test the TV.
5. You can then successfully use the "Video Source" button on the bottom left of the remote to change the video mode. VOILA!!!
If you don't have a Scientific Atlanta AT8550 remote, I'm sure you know someone that does. They're everywhere!
Feb 10, 2008 | Sanyo DS31520 31" TV
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
TV (Model DS27510) is stuck on Video2 setting, unable to change!!
Ours is doing the same thing except on Video 1. I called Sanyo customer service and they said I need the original remote. They were willing to sell me one for $20. Here is what I did instead. I used a cable box and hooked the cable in to it. Then I took the type of cables that will hook into my video 1 slot and plugged them in there and plugged them into the back of the cable box in the "cable out" positions. It worked ! If you do not have a cable box you might try a DVD/VCR combo or a VCR. Good Luck
Sep 16, 2007 | Sanyo DS27510 27" TV
Magnavox universal remote for sanyo tv this nice sanyo ds19310 from brother without remote..have a magnavox universal remote but don't have code for tv or if i can use magnavox codes or can i set remote to it another way...thanks for any help i can get! megnavox tv code is Press following key combination 0>6>2>5>9>6>MENU to select item press cursor(up)and (down) to change item value press cursor(right)and (left) cancellation of service mode press POWER button on the set regards thanks
Sep 10, 2007 | Sanyo DS19310 19" TV
Cant change channels
Your in the video mode so you have to change the input. On the original remote, its the button left of the power button. A universal may not work for this. If you need the original remote, Its available at Good Luck
Aug 18, 2006 | Sanyo DS31520 31" TV
Sanyo DS20930 20" TV Logo
447 people viewed this question
Top Sanyo Televison & Video Experts
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
