BIOS chip marked: 686 AMIBIOS 1999 UB40 7709
Visit http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=574&LanID=9
and compare that is your BIOS updated ? If not, I suggest first update your BIOS to the latest version and see if error is removed ? Try Load Optimal Settings of BIOS. If fail, then try resetting the BIOS. If you have install anything new, try to boot by removing the new device. I suggest from the above URL, you can download the manual of the mother board. I hope trying these steps will remove your problem.
SOURCE: bios update dont work
I'd like to know if this is the bios you downloaded?
http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=1065&OSFullname=OS+Independent&lang=eng&strOSs=38
SOURCE: I can't boot with USB -
Have you set it to boot from USB otherwise it will boot from other first
SOURCE: my bios is corrupted and iam not able to boot from it
The intel site has bios recovery instructions that might help you
Instructions for Recovery Bios Update
Hope this helps you
SOURCE: Gigabyte Motherboard wont flash bios
your bios has been corrupted.
The AWARD BIOS has a similar procedure to AMI. To recover an AWARD BIOS you will need to create a bootable floppy diskette and add the desired BIOS file (we recommend using the most recent). Award BIOS's generally are in .BIN format, where as AMI was .ROM format. You will also add an AWARD flash utility (usually awdflash.exe) and an AUTOEXEC.BAT file.
The AWARD BIOS does not automatically restore the BIOS information to the 'system block' like the AMI BIOS does. You will need to add the commands necessary to flash the BIOS in the AUTOEXEC.BAT file. The system will run the AUTOEXEC.BAT file, which contains the flash instructions.
Note: 12345678.BIN represents the name of your BIOS.
Step by Step:
1. Create a bootable floppy diskette or bootable dos cd /usb drive
2. Copy the BIOS file and flash utility to the disk
3. Create an text file with any standard text editor and add the following lines
@ECHO OFF
awdflash 12345678.BIN /py/sn/f/cc/r
Exchange the awdflash with the name of whatever flash utility you are using, and replace the 12345678.BIN with the name of the BIOS file you are using. The parameters are explained here:
py = program yes
sn = save no
f = flash
cc = clear cmos
r = reboot
Remove disk and restart computer
If you found this useful , please rate below
Kind Regards
1234s282
SOURCE: I have a Award 1998 PCI/PNP 686 bios chip and need
Since Award 1998PCI/PNP 686 bios chip needs 80MB and over.. My suggestion is to buy a higher capacity drive to be able to support the boards requirements.. just post again for more questions.. thanks.. =)
thanks. Terry
