Question about Garden
Chainsaw idles but bogs out and dies when given full throttle.
Chainsaw idles but bogs out and dies when given fuel
  • Anonymous Mar 22, 2014
    engine bogs down when throttle is open
    Scholar:
  • 173 Answers
First thing,
Check the air filter, once checked, & clean/replaced,
Adjust timing.
This is a very easy job to undertake on small petrol engines.
1: adjust the gap between the contact & the magneto,
2:Or adjust the space on the tip of the plug.
So simple.
Fixed'Ya!
& don't forget to rate:)!
Posted on Jul 29, 2009
Rough idle, bogs when I give it throttle then dies
Brad:
Go back to the carburetor adjustment screws and snug them down gently. Do not use force on those screws or you'll damage the needle valve seats. Turn both screws out one and a quarter turns out and start the saw. The motor should stay running.... if not adjust the screws until it stays running. Turn one screw in until you hear the motor start to stall, then turn that screw out just a little bit. turn the other screw in until the saw starts to stall, then turn that screw out a little bit. Now if the saw bogs at full throttle, turn one screw out one quarter turn. See if the saw runs at full throttle... if not turn that same screw in to where it was and try the other screw the same way. If you're good, you can adjust the screw while the saw is running to get the best full throttle run. This is not an exact science, and it takes time and many adjustments to get the saw to idle and run at full throttle. Good luck... and have patience.
Oct 03, 2015 | Garden
Chokes and Dies when cutting
Adjust the choke or carburetor. In case your chainsaw stalls when the engine is idling, ensure that the choke is set properly. To do so, first try releasing it to adjust it, and then move the plate and tighten all screws once again. To loosen any grit, spray carburetor cleaner spray on the choke's shaft. The carburetor may also need to be adjusted; consult your owner's manual which will guide you on resetting the idle mix screw.
Mar 13, 2014 | Ryobi 940968018 C4620 Label
EXCALIBUR HEDGE TRIMMER BOGS DOWN AND DIES WITH THROTTLE
I have attached a diagnostic sheet to help determine what is wrong.
May 05, 2013 | Weedeater Garden
2009 kymco super 8 sputtering idle and die
air filter worth checking first, if not that then fuel restriction, check fuel tap. fuel in carb bowl..
Feb 17, 2013 | 2010 Kymco Super 8 150
Bogs out when i hit throttle
This is fuel starvation, clean/replace the fuel filter in the tank, check the fuel hoses for signs of cracks or fuel leakage, if this fails it may well be dirt in the carb itself, remove the carb, and clean /replace the fuel screen located under the carb pump cover
Aug 18, 2012 | Homelite Garden
I have a stihl 044, older saw and its not running properly. When I try to start it with the full chock, I get fuel ranning out of the muffler every time I try to start it. I take off the air filter and...
I would say it is flooding, you realy need to pressure test the carb to check the seating of the inlet needle, a simple bulb tester is all you need, connect it to the fuel inlet on the carb ( where the fuel hose is connected ), pump approx 2/3 psi into the carb, it should hold this steady with no leak, any leaks then you will have to fit a new inlet needle, let us know how the test goes.
Apr 05, 2011 | Stihl Chain Saw Handle Models 044 046...
The saw stalls when under load and at high speed, runs good at idle and mid speeds, when you pull throttle all the way back with out load saw will bog down and die.
Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor is solidly mounted to the engine. Hope this helps!
Dec 05, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Chainsaw dies at full throttle, idles fine and works with half throttle
hi
check the fuel filter,clean the gas tank,the carburator ,check the fuel pump(not to be tired).the fine filter inside the carb under the fuel pumpand the sparkplug.
by for now savumihai71
Oct 29, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Not running at full throttle
close to the carb you will find two tiny screws. They are labeled H and L. L sets the idle speed. H sets the max RPM. Hold the throttle wide open and turn the H screw. When you find the very top end, back it down some or it will be running too lean. That would make it run hot, and provides less lubrication. Could result in engine failure if you run it too lean.
Dec 23, 2009 | Garden
Garden Logo
2,156 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
