Question about Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair
8 charge lights flashing when i turn it on. will not move. batteries have been pulled down really low many times. could one or both quit all at once?
  • 520 Answers
Yes they would stop fairly quickly but before you replace them check to see if the voltage is consistent on both batteries. Also check the connections. If they have been exposed to any water of high humidity they may have corrosion and lost connection. Hope this helps. Please re-post with updates or questions. If you feel like this solution has helped then please accept and rate the solution. Thanks cj2176.
Posted on Jul 15, 2009
Chair shows full charge, or most of a charge (depending on how long it sets between looking at it), and has limited mobility for a while, after sitting turned off for several hours.
Hi if the batteries r 5 years old it would be a good idea to replace them ...u can't rely on you're charging circuit giving u a true reading on the condition of you're batteries they have to b tested with a BATTERY LOAD TESTER they put a 100 amp load on them this will give u a true reading on the condition of you're batteries ..cheers
Sep 10, 2015 | Pride Jazzy 614 Hd JAZZY 614HD
I have a 2006 tribute that won't start, sometimes. The battery has been replaced and the alternator is not putting out quite the correct voltage but isn't really bad yet I don't think. It&
You need to replace the alternator, it may be charging the battery enough to start the vehicle for a few days, but once the battery runs low, it cant recharge the battery, would have the alternator tested, but i'm pretty sure that is your problem. Hope this helps...
Sep 08, 2012 | 2005 Mazda Tribute
Iam useing sony ericsson w850i for past 1 year.suddenly one day it was switched off if i seem to turn on it is flashing the red light.and now iam not useing that phone any ideas to turn on my phone back.
from my own experience and idea, I think that flashing light indicates low battery.
This is usually common with Sony ericsson phone, it flashes a red light once battery is low and you want to power is on.
Maybe should test your phone with another battery.
All the best.
Jan 05, 2010 | Sony Ericsson W850i Cellular Phone
I have a Dell Inspiron 1525 that won't start. The battery light would flash orange 4 times then blue once, and then start over with the same sequence. Pulled the power board and fixed the solder joints on...
This is directly from the User Manual:
If the computer is connected to an electrical outlet, the Battery light operates as follows:
• Solid green: The battery is charging.
• Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the light operates as follows:
• Off: The battery is adequately charged (or the computer is turned off).
• Flashing orange: The battery charge is low.
• Solid orange: The battery charge is critically low.
Dec 27, 2009 | Dell Inspiron 1525 Notebook
2004 Polaris Sportsman 400 Only idles, quits Electrical Problem?
Sounds like the battery may have a bad cell. The reason it quits dying is that there isn't enough juice in the battery to fire the plugs. On older pull start vehicles the stator put out the power to run the coils. On atv's with batteries, the power output is sent to the battery, and then to everything else. If the battery is bad or just dead, it eats up the current and leaves nothing to run the motor. The dash lights go out because it completely drains all current until even those lights go out. Once the motor quits runnung, there is enough current to get those lights back on again. Hope this helps...
Oct 08, 2009 | 1970 kawasaki Mach III H 1A
Won't charge after the battery runs low.
that means your battery is flat so first boost the battery using universal charger or in other way charge you battery directly
Apr 08, 2017 | Sony Ericsson XPERIA X1 Smartphone
My NEW Blackberry 8310 won't charge! Red light flashes just once.
get a message saying my USB is not sufficient enough to charge phone ???? It works on other computers just not the one I need it to work on.
May 09, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Verizon samsung sch u340 not charging:please help!!!!
the best thing i think you should do is buy another charger....
thats my first sugestion...
Jan 02, 2009 | Samsung SCH-u340 Cellular Phone
Flashing device status light
Ok the lightning bolt is your power indicator: solid green-charging, Flashing green-fully charged, flashing red-low battery, flashing red three times the once green-bad battery. the "trash can" looking one is your hard drive activity indicator it will flash while your hard drive is reading and writing.
Nov 20, 2008 | Dell Latitude D600 Notebook
I have a Samsung P800 camera. I'm currently trying to charge it but the light on the charger chord is flashing orange and it doesn't seem to be charging. Please help.
Ok. I have the samsung l200 but the cameras are very similar. I had the issue as well. When I plug it in it flashes red once, green once, then orange consistently. It would not charge the battery.
The fix was really quite unexpected. I did two things not sure which fixed it.
1. slide the cable into the camera slowly until the light turned red once, then pulled it gently in and out a few times.
2. as i plugged it in, I tried to angle the plug side to side sliding it to the left and right on a diagonal. I was hoping the pins would be touched differently when I did this which might reset something.
not sure which of these two things corrected the problem, but the camera is now charging.
Aug 12, 2008 | Samsung L200 Digital Camera
Pride Mobility Products New Pride Mobility Jet 3 Ultra Power Wheel Chair Logo
73 people viewed this question
Top Pride Mobility Products Health & Beauty Experts
wcdoc1953
wcdoc1953
Colin Taylor
Robin Hill
Robin Hill
Are you a Pride Mobility Products Health and Beauty Expert? Answer questions, earn points and help others
