I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the antenna??? I can only get 3 PBS stations and 1 local station!
  • 458 Answers
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Posted on Jul 15, 2009
The model # is: L42FHD37. I need to know how to set up an amplified indoor HDTV antenna. RCA multi directional serial # ANT1450BFW.
Attach the antenna to the antenna/TV input on the back of the TV. If you have a flat twin lead wire on your antenna, you'll need a co-ax converter. (Best buy, etc.) Power on the TV (and the amplified antenna) and use the Input button on the remote to select the TV input. Next use the menu button to select channels and then engage the auto-search option to memorize all of the available channels in your area.
Feb 29, 2016 | RCA Lg 42ls5700 42" 1080p Flat Panel...
How do I hook an antenna to my tv
Hi Dwayne,
The Proton has an NTSC analog tuner and also an ATSC digital tuner. Have you tried switching or changing the SOURCE inputs?
You may also have to use the scan button to have the tuner "find" the channels for you once you determine that you have selected the correct source for the antenna.
See page 9 of the manual.
http://www.manualslib.com/manual/323457/Protron-Pltv-4250.html?page=17#manual
Jan 18, 2015 | Protron PLTV-4250 42 in. LCD Television
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
I have a RCA D52W20 rear projection HDTV. This TV was purchased in2005. I cancelled my cable and I just hooked up a digital antenna but the TV isn't finding any channels. What do I need to do? I was...
HDTV indicates the number of lines that are shown by the TV. (HD means that at least 720 lines can be displayed in a given picture.) To receive OTA signals, you need an ATSC tuner (digital) of sufficient power (with a clear path to the transmitter) these days. The RCA D52W20 was released in 2002 and only has an NTSC (analog tuner). You will need a digital-to-analog converter to receive OTA TV (unless any low power analog stations remain in your area).
Please note that the basic digital-to-analog converters that were available with the government coupon back in 2009 were SD (480i lines of pixels used) units. HD d-t-a converters exist but are more expensive.
I hope this helps.
(the phrase "digital antenna" is meaningless; check with tvfool.com or antennaweb.org for the direction of local transmitters. TVfool.com will give more information on the type of antenna (indoor, outdoor, amplifier) that you will need to receive channels in your area. Antennaweb assumes an external antenna but is very conservative in the stations that it will indicate that you can receive. Antennas are given a color rating based on how far away the transmitter can be to get a watchable signal. Since digital signals are either enough for the tuner to interpret or you get a "no signal" message, you often need a stronger signal than was needed to receive a watchable analog channel.)
Sep 27, 2011 | RCA Televison & Video
I have aflx-3202 t.v. what type of h.d. tv antanna can I use thank you
Any set top HD antenna will do if you are not surrounded by hills and mountains, it maust have COAXIAL connector to attach to your TV. HD (ATSC) antenna is the same as UHF antenna (HD (ATSC) uses the the old UHF band for transmitting) but HD sound better than UHF for marketing purpose so they can charge you more with the word HD on the box.
TARGET or RADI SHACK, BB.
http://www.bestbuy.com/site/RCA+-+Indoor+Off-Air+HDTV+Antenna/8280834.p?skuId=8280834&ci_src=14110944&ci_sku=8280834&ref=06&cmp=RMX&loc=01&id=1171058630499
Learning
http://tv.about.com/od/hdtv/a/hdantenna.htm
http://www.crutchfield.com/S-RIn3fwb4G6X/learn/learningcenter/home/antenna.html
http://www.hdtvantennalabs.com/articles/category/over-the-air-hdtv/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Dec 26, 2010 | Element Electronics FLX-3211B 32 in. LCD...
HDTV unable to get HD Channels w/ Antenna
The problem could be your antenna. Many people will buy small indoor tv antennas and wonder why they're not getting the signal that they want or the channels that they expect. Its not your fault. Digital signal is in two formats: UHF AND VHF. Some antennas only receive UHF. But many of the low band channels are VHF, so 1) you need an antenna that will receive those signals and 2) you need to know how and where to install that antenna and 3) you need to know if you need a signal amplifier depending on your coaxial cable length and number of connections. I recommend visiting dennys antenna service (no I don't work there and I have never purchased anything from that website. He just has an excellent informational article with a great deal of "how to" on his pages.). http://www.dennysantennaservice.com/2029710.html This should be of great help to you. Happy viewing =)
Dec 26, 2009 | Toymax Magnavox 37MF337B 37 in. LCD TV
How to install an amplified indoor HDTV flat antenna? Have not purchased the product yet but I am very interested in purchasing it.How do you install it? Please note I have a LCD Flat Screen TV made by...
The antenna, will more than likely, come with a feed cable with a screw type F connector that you attach to the antenna connector on your Phillips TV. Pretty simple! Most antenna's will come with complete installation instructions.
Jun 27, 2009 | Televison & Video
I have a 32" Toshiba 32AV500U 32-Inch 720p LCD HDTV along with a HDTVi VHF/UHF HDTV Indoor Antenna. I purchased the TV and antenna about a year ago. I am unable to get any digital TV, only analog. I was...
Look in your manual for a channel scan entry. It should be an item in your setup menu. What this does is re-scan for all the signals it can receive.
Once the scan is done, it should display all the channels that are viewable in your area
Jun 20, 2009 | Toshiba 32AV500U 32 in. LCD HDTV
Indoor antenna problem with Magnavox LCD TV Model 15MF605T/17
I have found most of these indoor antennae to be ineffective and a waste of money, however, I do not know anything about this particular antennae. I to have a Dish DTVpal, which I love! It's ugly and probably won't fit in your kitchen, but the best solution is to make your own "bow-tie" antennae, mount it indoors or on the roof and run a cable to the kitchen. Directions can be found on You-Tube. I live in SE Idaho (Pocatello) and can get 13 channels, most without having to adjust the antennae.
May 27, 2009 | Philips Televison & Video
RCA HDTV, indoor antenna and Dish Receiver 311
I want to use two (2) 311 dish receivers with only 1 outside antenna.
Jan 08, 2008 | RCA L32W11 32 in. HD-Ready LCD Television
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
