Question about Dell E771MM 17" CRT Monitor
My monitor sucks
My monitor has gray lines going horizontally across my screen. When i hit it a few times it goes back to normal, but in a few seconds it returns...what should i do?
  • 138 Answers
Re: my monitor sucks
Don't hit your monitor. JUST Buy a new flat screen, don't use CRT monitor. It has an effect to your eyes. You better save your eyes, don't save the money for anything else.
Posted on Feb 07, 2008
0 characters
3 Points
My i2352Fh monitor has developed a white vertical line which tracks back and forth across the middle half of the screen how do i get rid of it? the screen is 3 months oldn
Thanks Melony - had exactly the same problem - your post above helped me fix it...... Here is how to fix it .
  • On the base of the screen press the Menu button (far right),
  • Then press < or > to get to the Extra (looks like a screwdriver and spanner) and press Menu again to Enter.
  • Press < or > until you have selected the RESET and press menu again to Enter.
The line should be gone. Close the menus and all should be fine. I hope this helps someone. I searched the internet and this was the only post that gave me a clue. Thanks again.
Dec 16, 2012 | AOC I2353FH 23" WIDE Monitor
How do I Fix LCD White Screen?
If you see "fractured lines" across the screen, it would appear that your LCD screen is broken. That's the only way these kinds of lines appear.
You need to replace the screen.
May 14, 2012 | Computer Monitors
Run a full scan using your anti-virus program to see if it will track down anything, next go to Type: malwarebytes anti-malware and run the program with a full scan, "free" this program find just about anything that is lerking in your computer. Now! if all this fails, do a complete fresh install of your operational system.
Apr 18, 2012 | AOC 2436Vw LCD Monitor
Horizontal black lines across the screen
you can try contacting Lumaco they are a British monitor repair specialist.
It might even be cheaper to buy a new one.
Jun 19, 2009 | Relisys TL 766 Monitor
A big white vertical static band appears as soon a i turn on the power
Some of the transistors or the connection to the panel inside the monitor are damaged. There is no absolute fix for this problem.
You can try pushing on the bezel (NOT ON THE SCREEN) of the monitor at the edge of the screen directly at the lines and you may be able to push the connection back together well enough that the line goes away, but usually in desktop monitors the bezel is too rigid to allow you to put any pressure on the connections at the back of the LCD panel.
Mar 30, 2008 | Sony SDM-P234/B 23" LCD Monitor
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Horizontal line across the middle of the screen
replace the vertical ic,when your vertical ic is defective you can see the horizontal line across your screen
Oct 19, 2007 | Gateway FPD2275W LCD Monitor
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Lines across screen
The screen you have is almost certainly on the way out. This type of fault is in the Horizontal Flyback section of the Monitor. Usually components fault or age and change value, these lines are normally "Turned Off" so ya can't see them, that "Turn Off" circuitry is going faulty.. it will only get worse. I suggest a new, or 2nd hand monitor as they are so cheap these days fixing CRT monitors can be cost prohibitive.
May 10, 2007 | Gateway FPD 1510 15.1" Flat Panel LCD...
Dell E771MM 17" CRT Monitor Logo
125 people viewed this question
Top Dell Computer Monitors Experts
Brian Sullivan
Brian Sullivan
William Miller
William Miller
Are you a Dell Computer Monitor Expert? Answer questions, earn points and help others
