Question about Bushnell Voyager 78-9565 (120 x 60mm) Telescope
When I a object through the eye piece,the object
When I view a object through the eye piece,the object is up side down. is this normal?. I cannot find/see the cross hairs in the finderscope. my model # am-78-9565.where can i get/buy a manual for this model.
    Problem Solver:
  • 4 Answers
Astronomical telescopes present images upsidedown, this is normal.
Posted on Jul 15, 2009
Got a old scope i can just make out its a gold crown the rest is rubbed off how do I find out how old it is and what is the size ( zoom)
Nikko Stirling is my best guess and can be from 1956 till today
And without getting my grubies on it all I can suggest is to search every Nikko scope until you narrow down the choices
I have 2 from the 1980's one has a serial number below the windage turret mount on the tube the other doesn't
Measure the objective bell to help with the search
Sep 20, 2016 | The Optics
Last used viewing was fine. After being stored the image now is side ways. the same eye piece was used. Hope you can help! Ray
The image is also UPSIDE DOWN -- all astronomical telescopes show inverted images --- it is normal. No up or down in space.
Light simply enters the tube hits the mirror on the back and bounces up and hits the smaller mirror under the focuser. That's all there is to it.
Sep 10, 2011 | Celestron PowerSeeker 114 EQ Telescope
We don't know how to operate the telescope! instructions only covered assembly! how to operate?
HI mthrede,
What you need to do after the assembly is to get both the telescope and the small sighting scope Calibrated so that they are both looking at the same object.
Start in the daylight and use the main telescope to scan your local landscape. What you are looking for is the likes of the tops of telephone poles, radio towers, or such to lock on to. You may need to use that focus knob down by the eye piece to clear your view. After this is done, adjust the little sighting scope to where it is looking at that same object. You are now ready for some night time viewing.
Jan 18, 2011 | Emerson Fans Emerson Refractor Telescope
Hi, a few days back I purchased Nexstar 4SE. I set it up exactly how it says in the manual still I cannot see any magnifying views from the eye piece. While aligning the telescope I can find the moon from...
Stars will always appear as points. It is not possible to magnify them enough to see them as disks because they are all extremely far away. A telescope will however show you stars and other objects that are too dim to see with the naked eye.
You will be able to see the planets as disks, and even features on the planets, such as the bands on Jupiter, the rings of Saturn and the phases of Venus, and also moons around some planets. There are other objects that will show more detail when magnified, such as nebula. You will be able to see a lot of craters and other detail on the Moon.
Your problem is simply that you are not pointing the telescope at these objects. This seems to be one of those telescopes that "automatically" finds objects, but these so called "go to" scopes only do this when they are set up properly. I can't say what step(s) you have missed, but clearly even if the scope thinks it is pointed at the moon, if you can't see the moon, it is NOT pointed there. The Moon will fill the field of view even with the least powerful eyepiece. If you are seeing stars as points, then the eyepiece is focussed and working properly.
Jan 13, 2011 | Celestron NexStar 4 SE Telescope
Everything is upside down on side eye piece. When viewing through the scope that's on the side of the telescope itself, everything is upside down. No matter which way it is turned, the same problem exists.
All astronomical telescopes show upside down images. It's completely normal. Nothing is wrong with the scope. For terrestril viewing you can buy an "erecting prism diagonal" which will turn the images right side up.
Like this:
http://www.skiesunlimited.net/index.php?CategoryID=98
Jul 21, 2010 | Edu-Science (10166) Telescope
I am having problems viewing
All astronomical telescopes show upside down images. There is no up or down in space. To ERECT the image would take additional GLASS lenses. MORE glass means less light pass-through for those dim sky objects.
Dec 25, 2009 | Bushnell 675x5 EQ Reflector Telescope
Can't see object with 6450 Telescope
You cannot use high power in those small telescopes. Only use the eyepiece with the largest number written on it.
I know the box said 600 power--- it was a complete LIE! The maximum magnification is 50 times aperture. You probably have something like a 2 inch lens. So 100 power is the maximum usable power.
Next time buy a telescope similar to this one:
http://www.telescope.com/control/product/~category_id=dobsonians/~pcategory=dobsonians/~product_id=08942
Aug 24, 2009 | Optics
VEIWFINDER IS BLURRY CANNOT SE OBJECTS CLEARLY
At the bottom of the eye piece there is a little slider than you can move up and down to adjust the focus. That should fix your problem if not then you are not looking into the eye piece close enough make sure your eye is pressed up against the little rubber pad and then adjust the focus.
Apr 23, 2009 | Cameras
CELESTRON 127EQ faulty magnification
It won't increase viewing power by hundreds of time but it should be able to show you a close up view of the moon and planets where they look closer (or with the moon, parts of it look closer). When you say it looks further away, something is quite wrong as you know. It sounds like the eye piece is backwards in the mount? Can't imagine what else would make it smaller. Also can't imagine you could even get it in backwards. I have a scope by Meade that is essentially the same Newtonian design. Best of luck.
Dec 31, 2008 | Celestron PowerSeeker 114 EQ Telescope
Eyepiece and objectives - they seem to be loose.
sir,
There is two kind of eye-piece in microscope one is (push in ) and second one is tread mounted.
As per my i know you have push in eye piece.
See in side that cylinder where you are pusing in this eye piece there is two jows is there it resist to come in as well as when you take it out.that pressure of jows you should be increase.
your problems will short out.
INDRAVIJAY
Jan 10, 2008 | Premiere Microscopes MRJ-01L Microscope
Bushnell Voyager 78-9565 (120 x 60mm) Telescope Logo
269 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
