My airconditioner will only blow on the floor, i can turn the knob and it wont change.
    Novelist:
  • 109 Answers
If this is a wall or window unit, the plastic vanes on the front direct the air flow. If there is a knob to change the AIRFLOW (not the temperature) direction from "down" to "front" or some such, try removing the front panel and see if the control knob has come loose, or see if there is some kind of linkage that has come loose or is broken. Replace broken parts as needed, or fix them if you are able. If this has helped, please rate it accordingly. Good luck.
Posted on Jul 15, 2009
What is the problem with my mode selection knob?
HAVC Blend Door problem under the dash
Oct 03, 2014 | 2003 Kia Sorento
Airconditioner only blows out of defrost
This May Sound Stupid,But You Can Have The A/C Button Pushed In,But The" Other Knob"That Turns For Vent,Defroster,Ect.Has To Be Turned So That The Arrows Point Out Towards You .Thank You !
Jun 28, 2014 | 2000 Saturn SL
Center air vents
cant think why going at a higher rpm could change the vent setting but at a higher rpm the a/c will get to a lower temp so perhaps the vent setting knob is at fault and the vents are set to floor and not the panel. i'd investigate the vent knob operation as a first step let me know how it goes
Apr 22, 2014 | 2005 Dodge Dakota
HVAC only blows hot air and moves between defrost, panel and floor
vacuum controls stuck work the knob a bit and try to free it..
Dec 29, 2013 | 1998 Oldsmobile Bravada
Air blend door actuator
Possible bad blend door actuator .some gm cars can be relearned to the new climate control head
Jul 28, 2013 | 2001 Oldsmobile Aurora
Airconditioner on 1996 dodge ram 2500 diesel pickup wont blow hard when turned on to do so. why will it not blow hard?
does it have a cabin filter? if so change it the blower motor has different speeds perhaps the high is burnt out it will still run on lower settings
Aug 06, 2011 | Heating & Cooling
I have a 2004 Yukon. The airconditioner blows
OK, do you have 'zoned' cooling where the passenger side can have a lower or higher temperature depending on a setting on the heating/ventilation/a/c console?
This is the way my Cadillac Deville is, it actually has a knob on the passenger side for the passenger to control temperature.
Good luck on this.
Also, make sure the system is charged up fully with r134a.
Jul 11, 2010 | 2004 GMC Yukon
The knob on 2002 alero will not change position
Trace it down to the box from the switch (lubricate WD-40) and try to turn it from there. Not sure what else it could be unless the cable between the two is broken or disconnected.
Dec 28, 2009 | 2002 Oldsmobile Alero
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
