Question about Electrolux ICON Designer E30SO75ESS Oven
How do I remove the oven door to fix the inner glass that has come apart
    President:
  • 1,136 Answers
Hi, The picture I looked up is very poor but, I believe you will need to open the door all the way. Look at the hinge and see if there is a small hole that you can insert a small nail into so that the door will not close all the way. Once you get this done, try closing the door and lift up at the same time. This should release the hinge inside the wall and allow it to pull off. Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Posted on Jul 15, 2009
4 Suggested Answers
  • 11 Answers
SOURCE: zanussi ZBF 660 oven door requires removing to access replacement of inner glass
Hi BisseeCath,
Not sure if you still need to get your oven door off still but I have the same oven and have spent the last several hours trying to remove it and searching the web to discover how to remove it until I have just discovered a wonderful video tutorial on YouTube www.youtube.com/watch?v=hSzc4Uqbbr8
that discribes exactly how to do it (just copy and paste it into your address bar.
It is the fourth and final instruction in the video but it really is easy.
The hinge is a latching over system type that folds back into the glass apparently.
Just get a screwdriver and where the end of the hinge dissappears into the housing of the oven just flick up the hinge with the screwdriver and the locking mechanism folds back towards you and the glass.
Once both are done just jiggle and pull up the door and it will remove easily....godsend!
Regards,
DIYDIM
Posted on Dec 05, 2008
ginko
  • 19396 Answers
SOURCE: replace inner oven door glass on kitchenaid wall oven
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Posted on Apr 08, 2009
  • 18 Answers
SOURCE: the inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Posted on Feb 18, 2010
How to I take inner glass off the door to clean
you will have to remove door, then remove all necessary screws on door framing which sandwiches glass between inner and outer panels. How to Take Apart an Oven Door to Clean the Glass
Jan 06, 2016 | Ovens
Taking apart a NEFF oven door
The inner door glass is held on by two clips at the bottom (hinge side) and two slides near the handle side. Remove the door from the oven and lie it the worktop flat with the hinges uppermost. Near the hinges you will see the glass is angles leaving a triangle of metal frame either side near the hinges.Rest the outside of your hand on the metal for purchase and then pull on the glass along the bottom edge (reasonable tug required) this will disengage the bottom clips and then slide the glass down about an inch to remove completely.
Mar 21, 2013 | Neff U1661 Double circotherm super...
Really how do you get to the inner glass, it has a disgusting line of **** inside i would like to clean thanks
IF YOU OPEN THE OVEN DOOR THERE SHOULD BE SOME SCREWS YOU CAN REMOVE LOOK AROUND THE DOOR EDGES FOR SCREWS ALSO REMOVE THESE AND YOU SHOULD BE ABLE TO PULL THE INNER DOOR OFF LOOK MAT THE GLASS CAREFULLY IF THE GLASS IS SEALED TOGETHER WITH ADHEISIVE DO NOT PULL GLASS APART, IF IT HAS A GASKET FINE SEPPERATE THE GLASSES AND CLEAN AND PUT BACK TOGETHER
Feb 05, 2011 | Ovens
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Replace inner oven door glass on kitchenaid wall oven
Mar 22, 2009 | KitchenAid KEBC101 Electric Single Oven
Broken inner glass on Model # NGSG3PZAQA
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
How do I replace the inner glass on the oven door? I have taken the door off and it is apart, but the glass assembly looks to be one piece. How do I remove just the inner glass for replacement? JenW30400W
moz-screenshot-7.jpgmoz-screenshot-8.jpgTo replace the door glass do the following:
Part here: _.gif PS2087058
Mar 14, 2009 | Jenn-Air 27 in. Electric Single Wall Oven...
Smeg se336ss 5 some so and so has broken the outer glass door!
We removed the front glass of our oven door after a big spill between the two glass sections (by blunt force!). Since it took us 4 hours to put back together, we wanted to spread the info in case any others have the misfortune to make this mistake! Note, I wouldn't do this unless you have to, just incase you can't get your door back together again.
Assuming the back sheet of oven glass is still in position, but the front sheet is not attached -
1. Follow the manual instructions to remove the door, ensuring that both hinges are locked fully (otherwise you won't be able to get the door back on easily)
2. Once the door is removed, ensure that the plastic spacers that hold the two sheets of glass apart are in original position, resting on the inner door, at the bottom corners of the tempered glass
3. Remove the narrow metal strip at the bottom of the inner door by unscrewing the 3 screws that hold it in place. This is the metal groove that the outer pane of glass needs to rest in
4. Lay the outer sheet of glass in position in this metal strip
5. Lay the outer sheet of glass over the inner door. Slot the outer sheet into position at the top of the inner door first, ensuring it is layed flush at the top.
6. A second person needs to ease the metal strip back into place at the bottom of the inner door, so that the two sheets of glass are now held together at both top and bottom.
7. Screw the metal strip back into position with the 3 screws
8. Follow the manual instructions to replace the door. Ensure that the small grooves at the bottom of both hinges are resting in position correctly, otherwise the door will not close flushly.
Jan 17, 2009 | Smeg DO81CSS Electric Double Oven
How do I remove the glass on the inside of the oven door to clean between the two pieces of glass
We just replaced the inner glass last night. The door needs to be removed, then take the screws out that holds the inside panel on. I suggest writing notes of the steps that you take when you remove the panel and glass. Our model had three pieces of glass. Be careful replacing the door, we knocked the lock loose which in turn knocked the sensor for the light to come on. We had to take that part of the oven apart also to fix it. Hope this helps. I may not have done this if it wasn't for the broken glass.
Dec 30, 2008 | Whirlpool RBS305PDS Electric Single Oven
Viking: VEDO205 Blew my inner glass door
If you can take the door apart then you can fix it. Remove all the retaining screws to access the inner glass.
Dec 11, 2007 | Viking DEDO205 Stainless Steel Electric...
Electrolux ICON  Designer E30SO75ESS Oven Logo
1,311 people viewed this question
Top Electrolux Ovens Experts
ashburton
Mack Baxter
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
