Question about Kenmore 50522 / 50524 Side by Side Refrigerator
Keeps blowing fuse
Just moved the fridge on side and now it keep blowing fuse every time I plug it in
  • 447 Answers
Re: Keeps blowing fuse
Yep compressors probably grounded. cant lay them on their side
Posted on Nov 17, 2007
0 characters
3 Points
Starts up then keeps blowing fuse
It sound like the compressor is faulty, but without more info, cannot br 100% sure.
Feb 19, 2016 | Daewoo FRAX22B3B Black 622 l Fridge...
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
I have a burning smell coming from inside my kitchenaid superba side by side fridge. It smells like a burning plastic. The fridge still turns on and keeps things cool, but it started to kick out that...
Remove the power plug and move your fridge forward. Now look at the rear bottom side of the fridge to see if there are any parts that heats up. You can trace this to the smell emitting from the heated part and confirm. It can be the motor, contactor or the defrost timer.
Mar 18, 2011 | KitchenAid (KSRD22FKST) Side by Side...
The fridge is blowing the 12 volt fuse as soon as I power up the motor home, The fridge is turned off and it still blows the fuse, I tried to undo the 2 wires that go to the 12 volt block on the fridge and...
Unplug the wire located at terminal J4 (12v positive) on the control board, and see if you are still popping fuses. If so, then the fault lies between the wire you just removed and the fuse that keeps blowing.
If the fuse holds, and blows when you plug the wire back onto J4 terminal, then unplug the wire(s) at J2. These go to your door heater (used in humid conditions to remove condensation), as well as the interior light. The switch for the door heater is located on front panel, or is at the top edge of the freezer compartment with door open. It is not unusual for this switch to have issues since it gets chilled and moisture condenses on it. If unplugging the wires at J2 allows the fuse to hold, you probably got a shorted heater or bad heater switch. But, pull the lens off the interior light, and check the contacts there as well.
If the fuse still blows with J2 removed, then unplug the connector in the top left corner of the control board. This goes to the control panel on the inside of the fridge. If the fuse blows, replace the control board. If the fuse holds, the replace the control panel.
Jul 13, 2010 | Dometic RM2652 Refrigerator
Fridge keeps blowing the breaker
Depending on what is causing the breaker to blow will be important to know. Refrigerators do draw a good bit of power on a 20 amp circuit especially when the refrigerator goes into defrost. Refrigerators are made to run on a 20 amp circuit without other machines or appliances using the same power circuit. Circuit breakers weaken over time too especially if they have more than they are. rated for plugged into the same circuit. And your circuit may be doing its job by detecting an excessive draw of power when the refrigerator is plugged in. You must have someone that knows electricity to inspect your refrigerator for shorting and the circuit it is plugged to for correct wiring for every ones safety. Thanks, Sea Breeze
Apr 25, 2010 | Fisher and Paykel RF201ADUX Bottom Freezer...
Fridge side not cooling. freezer works. 6 yr old side by side
There is a little fan that blows air from the freezer side to cool the fridge side. Pull the plug on the refridgerator for over night, long enough to give it time to defrost if there is any, then plug it back in and see ifthe fan is running. If not then it probably needs to be replaced. If it keeps frosting up and stopping the fan then the defrost timer is probably bad and will need to be replaced.
Nov 14, 2009 | Frigidaire FRS26R4A Side by Side...
Gfi outlet keeps tripping
try running an extension cord to the old outlet and see if the fridge works then you'll know if it's the fridge or outlet. good luck
Dec 03, 2008 | Whirlpool ED2FHEXN Side by Side...
Fridge has an odor recently
It is likely that you have a problem with the capacitor.  Look for it on top of the compressor.  If it is discolored or'll know!...replace it.  While you're there, clean out the condenser fins.
Nov 14, 2008 | Kenmore 50522 / 50524 Side by Side...
Commercial fridge is blowing the fuse in panel all of  a sudden. Nothing has changed. Is it the fridge or panel?
unit could be using more power then normal if it needs cleaned, next time it blows fuse find and outlet that is still working (and not overloaded with other products) plug refrig in that outlet with extention cord and see if it blows that fuse.
May 16, 2008 | Everest Refrigeration EMGR24 Commercial...
Kenmore 50522 / 50524 Side by Side Refrigerator Logo
240 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
John Tripp
John Tripp
mike cooper
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
