Question about Brother DCP-585cw All-in-One Wireless Color Inkjet Printer
Can't connect to router. all is ok with router
  • 30 Answers
TRY THIS:
call in your provider to change the ssid and the network key
[all computers will be disconnected]
and then try to reconnect them one by one to the new ssid or network name
this should resolve the issue
always make sure that the wireless properties are okay and the same as the router
also check the device manager: network adapters if they are properly installed and no errors on the icon for the adapters.
Posted on Sep 20, 2009
I am having problems with my Linksys wireless router WRT54G connecting with the internet. When I connect the router to the internet I lose internet connections. Normally it works with the internet, but in...
1. RESET both the modem and router by unplugging them from the wall outlet for 30 seconds.
2. Power them ON again, and after 2 minutes check the connection.
3. If not OK, connect a computer directly to the modem, reset the modem and check the connection after 2 minutes.
4. If not OK, check your cables and if these are OK, call your ISP for your status and line quality.
5. IF OK, check the Powersupply of the router.
Sep 04, 2011 | Linksys Wireless-G WRT54G Router
I use AOL as my ISP, with British Telecom supplying my telephone line rental. On Friday 2nd my internet connection kept dropping out, and then eventually stopped connecting altogether. My original router...
If BT tested the phone line is OK but did AOL test the connection to the Netgear router and get the IP address of your Netgear router.
The phone connection is OK but the ADSL connection from the telephone exchange may not be working, that is why you are not getting an ADSL light.
Jul 12, 2010 | NetGear DG834 Router
Netgear wireless wgr614 is configured and the ports wired connected and is working ok while wireless portion the laptop running vista says connection is limited and unable to browse
If you connect the computer to the router , it works.
That means the wired connection is OK.
Open the set up page of the router check the wireless settings of the router.
I think your network is secured and you are not typing the correct network key.
just open the router set up and check the wireless settings .
Apr 07, 2010 | NetGear WGR614 Wireless Router
Router works OK with ethernet connection, not OK with wireless
There are several problems that can cause the wireless connection to drop.
Please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559120-wireless_router_disconnecting
Apr 01, 2010 | NetGear WGR614 54Mbps Wireless Router...
How can I make my router private so no one else can connect to it?
to make your router private u will have to get acces to ur router firs if u cant just reset the router from the back the log to the internet and if u cant conect type this192.168.1.101 the brand name of the router appear then enter the user name and pasword if u cant type ADMIN in the user then press enter then go to settings and chose WEP share key and type your password recomment to use a strong password ok then click save. also create a user name while u in thre ok. that will reset the router after that go to my network conection right click on ur wireless router name and go to propertis then chose the WEP share key and type the password then ok. that will set ur router privated ok. good luck
Feb 07, 2010 | Gateway Belkin 54g Wireless DSL/Cable...
Could not make router to work, Netgear modem adding router.
i suppose you have to connect modem to router's "source" socket and modem to socket "in wall" then reset and reconfig router and you should be ok
Nov 10, 2009 | NetGear WGR614 Wireless Router
Although cable to desktop connects to internet, my router from desktop to laptop via router won't connect.
Desk top to internet is OK.
How about Destop through Router connection to Internet OK?
Assuming you want to connect wireless from Lap top to Network, need to configure correctly for wireless in Router.
If you connect Lap top to router by wire and it didn't work that mean your router is bad.
Jul 03, 2009 | Linksys WRT160N Wireless Router
I got a new netgear mondem router and i will not install i already have one that is not a router and that instaled ok
it's all seems to be ok. router is only for lan connections. if you have a 4port router then you can connect up to 4 ethernet based devices
May 02, 2008 | Computers & Internet
Connect to VPN 1 Securemote
if you are still having the same problem, try opening up the DMZ on your router or ask your network administrator for ports to be open on the router.
Dec 27, 2007 | D-Link AirPlus DI-524 Wireless Router
Internet connection
Ok I have done it a little different sometimes... try this approach... First connect up the DSL Modem to the PC via Ethernet.. Configure the modem from the PC using the Connect to the Internet Wizard... enter all ya ISP details Logon, Password etc. Once this is going OK.. Disconnect the Modem... and then connect it up to the "Router" using the "Uplink" port and when connect ya Modem to the router... then connect another Ethernet cable from Router to same port on ya PC. Then simply use the network setup Wizard to set up an Internet Connection and connect up via ya router thru ya modem... generally works for me....
Aug 31, 2007 | Dell TrueMobile 1184 Wireless Broadband...
Brother DCP-585cw All-in-One Wireless Color Inkjet Printer Logo
184 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
