Question about Zenith Televison & Video
I have a tv message say "disconnect a/v jack" and because of that message, I could not see any channel or picture.
  • Zenith Master
  • 5,568 Answers
I assume you know that this is a message concerning external inputs from other devices such as home theatres, etc.
Have you pulled up the main menu to see if something has misset itself? This is often a selection called 'input' or 'source' and if misset, you won't see any content from cable or satellite box. One remote we have has the source selection on the remote as a button function and it can easily be pressed unintentionally.
If this is an automatic function (some are) then the circuit that should do the detection of source has failed.
Posted on Jul 15, 2009
TV is hooked up to cable and I hit the channel up Arrow on the tv remote,now message on the screen that says please run channel automatic search. message does not go away cannot use my cable remote
how do you have the cable hooked to your tv? Is is hdmi? Is it the antena jack? Your tv is asking you to run the channel program because the cable is hooked to use channel 3 or 4
Dec 03, 2017 | Televison & Video
How do I turn off pscan on a rca dro2oon DVD player
IMPORTANT:
If you don't have a Progressive Scan TV or you don't have the DVD player connected to the correct Input Jacks, and you activate Progressive Scan in the DVD player you won't see a picture! Don't panic-try the following:
First, press the PREV/VIDEO button on the front of the DVD player (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If that doesn't work, press and hold PREV/VIDEO button on the front of the DVD player for 3 seconds. Now, press the PREV/VIDEO button again (it will go to the next video output option, which is an interlace output so a picture should appear on the TV screen). If you still don't see a picture on your TV screen, make sure the yellow cable (provided) that is attached to white and red cable (called audio/video cables) is connected to the DVD player's PREV/VIDEO jack and the TV's Video Input jack. Change your TV channel to your TV's Video Input
channel that activates the TV's VIdeo Input jack where you have connected the yellow cable (page 9 of your manual has more information).This PREV/VIDEO jack on the DVD player always outputs interlace video, so you should see a picture on the TV screen.
As a last resort, you can reset the DVD player to the factory default settings:
Press and hold the STOP button on the remote control and the NEXT button on the front of the player at the same time - wait at least 5 seconds before you release both buttons
Sep 25, 2016 | RCA Televison & Video
Please help diagnose problem with Panasonic TH-50PC77U Plasma HDTV
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 31, 2015 | Panasonic TH-50PC77U 50 in. Plasma TV
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
I have a dct700 which is displaying only a red light next to the messages and no other lights. I have disconnected and reconnected the box several times and have also checked all the cables. I am not...
those are the only 2 lights on a dct700
the red one usually means you have a message under the menu (probably junk mail about upgrading to video, internet and phone)
try to find out if your on the right channel.
-if a cable goes from your box to the tv use the buttons on your tv to get to 3 or 4
-if the red, white and yellow goes to your tv look for a input or source button on your tv and press it repeatedly till you find the correct input
to clear that message after you get a picture go to menu and try to find something about messages.
Jan 24, 2011 | Arris DCT700 DTV Receiver
Scrambled picture when cable box is hooked to hdtv plugs on philips 60 inch rear projection tv
I have a 53inch philips that is showing pictre but showing green, red as shadows..
Oct 03, 2007 | Televison & Video
Disconnect A/V jacks message appears
In the service menu option 40 ( auto camport ) should be set to 0 not 1
Sep 28, 2007 | Zenith H27G48S TV
Sony tv problem
If you are connecting the dish receiver to the standard antenna jack (F connector) on the TV, then the TV must be in TV mode and tuned to channel 3. If you accidently change to another channel then you will get the "no signal" message. If this is the case then simply put the TV back on channel 3. If you are using the RCA jacks (red, white yellow) to connect the dish receiver to the TV, then the TV must be in the VIDEO mode to work properly. If you accidently put the TV in the TV mode, you will get the "no signal" message. If this is the case then simply press the TV/VIDEO button.
Sep 18, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Televison & Video Logo
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
