Question about Bosch Nexxt Premium WFMC6400UC Front Load Washer
Out of balance spinning.
Hi,   My Bosch washer seems out of balance when spinning, even with no load. With a small load, it seems worse. The washer is only a few months old, but had to be torn apart and rebuilt because a blanket disintegrated and the parts fouled up everything. The washer is on a pedestal, but is level and without any wobble.  Any suggestions?  Thanks,  Dylan
  • Anonymous Mar 17, 2014
    when spinning the machine is off balance because door seal is coming apart
  • 213 Answers
There is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Posted on Nov 20, 2007
Get rid of the pedistal they cause lots of problems with balance
Posted on Dec 13, 2007
SOURCE:
Whan washing a full load of towels the washer does not seem to spin properly and we have to reduce the load to 1/2 to get the water out. Is this a common problem or should we have a repair tech come take a...
Its being overloaded, most washers have an out of balance spin control which prevents the spin cycle if it cant balance the load, its to help protect the bearings. Hope this helps
Feb 24, 2011 | Bosch Nexxt Premium WFMC6400UC Front Load...
Is it ok to wash small loads?
Hi, yes of course it is. I know there seems to be much mis-information out there, but small loads are not an issue at all. You must only insure the few items in the machine are of similar or "like" materials so the unit can balance when performing the spin cycle. Also be sure to adjust the amount of detergent and a lesser spin speed will likely be adequate. (delicate cycle maybe ?) Hope that answer's your question. Thanks for visiting fixya and please take a moment to rate the info provided for you by me here today and comment if you like. Good luck. Macmarkus :)
Dec 24, 2009 | Bosch Washing Machines
Out of balance condition
I had a Fridadaire model and had the same problem. It could be 3 things. 1- the weight came loose that balances the drum. 2- the bracket that is attached to the drum could have cracked. 3. the bearings to the drum have worn out. All of these problems involve taking the washer completely apart. This is big process, but if you have time and patience it worth it.
Is this model belt driven?
Jun 01, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
check the drain pump in the bottom of the unit and verify its not clogged, verify unit is level, also check the support struts/springs for the tub.
May 26, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
During spin cycle washer spins fine but toward the end of the cycle it spins out of control like it is out of balance? Any help is greatly welcomed.
Some front loaders have a super high speed at the end of the spin. Front loaders don't like small loads, the laundry does not spread out evenly enough for a balanced spin.
May 08, 2009 | Frigidaire ATF6000ES Front Load Washer
Whirlpool washer drum is loose
hi, sorry to say but the drum bearings are shot . and the balance weight on the underside off the machine is also shot .
would be alot cheaper to buy a new machine .
Jan 11, 2009 | Washing Machines
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Bosch Nexxt Premium WFMC6400UC Front Load Washer Logo
1,197 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
