Question about Canon PIXMA iP3000 InkJet Photo Printer
I have a ip3000 series printer from canon and it stoped printing
I have a ip3000 series printer from canon and eventhough the ink tanks have in the printer stoped printing both color and black
    President:
  • 2,306 Answers
It needs a new printhead, QY6-0064-000, around $50.00
Posted on Aug 19, 2009
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
How can I remove the Canon iP3000 ink jet printed heads for cleaning?
heres the support site for that printer http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10238 - downloads and drivers tab - has all the software and user manuals - the FAQ tab has a section on cleaning the printhead using software - also a link to removing the printhead
The FAQ has full images and step by step instructions Remove the print head iP3000
  3. Note: Gently open the paper output tray while holding it.
  4. After confirming that the print head holder has moved to the center, open the inner cover. Remove all ink tanks.
  5. Raise the print head lock lever and remove the print head.
  6. Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.
  7. Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.
  8. Close the inner cover and top cover.
  9. Note: Check that each ink tank is installed in the correct position.
Apr 10, 2010 | Office Equipment & Supplies
Canon PIXMA iP3000 waste ink tank showing nealry full..
Follow this procedure:
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 04, 2009 | Canon Office Equipment & Supplies
How do you change waste ink tank
There is no tank, just absorbent pads under the print engine. Each set is cut for each specific printer. After changing you have to enter service mode to reset the counter.
Jul 11, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print.. cannon pixma ip3000
Ink has dried in the printhead. You need a new one, QY6-0064-000, around $50.00
Jun 30, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Will not print blue
clean head cardrige and calibrate color cardriges.
Jun 01, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
IP3000
canon ip3000 & ip4000 the heads get dirty.
if you keep doing cleanings and deep cleanings it will eventually cause an error because it thinks the tank is full.
take out the head - in the sink, with warm not hot water rinse out much ink as possible. then use windex, the ammonia removes the ink. flush good - shake out head, drops will form on the bottom. keep doing it until drops are clear. rinse with water. shake out well. dry contacts.
I use a water pic as a pressure washer to force water thru. replace head and tanks.
do not use clean, instead print a page of 'X's
make every 5 rows a different color. this way you can see what is working and it won't fill up the cleaning tank, causing a code error.
you can use any ink you want as long as it is the proper type- don't have to be canon
Sep 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Ip3000 every time i dont use my printer for a few days the colours go funny
Hello Dear,
Although ip3000 is a good printer, its the limitation of a inkjet that it should be used regularly, the problem you are facing is probably due to the consistancy of the ink that dries up in the print head differs from that which are in the ink tanks, the solution is that u should always turn off the printer from the pannel ON/OFF Switch first and then from the mains, by doing so the purge unit of the printer caps the Print Head nozzels and u will get good prints.
Wram Regards,
Manoj Joseph
+91 9352008418
Jun 13, 2008 | Canon Office Equipment & Supplies
Printer not printing
Try a new tank, there are more and more people getting bad ink tanks. HOWEVER if it is a printer that has seperate heads you might have to change it.
Sep 14, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
198 people viewed this question
old marine
old marine
