Question about Whirlpool MH1150XMQ Microwave Oven
No power to unit
Everything on the display lights up. When I set a cook time. The unit counts down, but nothing else happens. The problem did not start until I tried to replace the light under the unit. It would flicker, I tried to change it. I took off the bottom panel, noticed the bulb was loose, tightened it, then it blew up. After that only the control panel works, but nothing else. I need some help. I've only had the unit 5 yrs and it gets below normal use. Please help me to salvage this unit.
  • peelsession Dec 08, 2007
    I have a Danby DMW162W-OTR, it's less than a year old and I have the same problem where the timer counts down but the microwave does not work. I hear a loud tick or spring sound when I push the start button but nothing else. Let is sit unplugged for an hour, checked the door switches but no change.
  • Whirlpool Master
  • 9,098 Answers
I would first suggest that the door switches and door switch mounts be checked, but one of the problems is almost certainly trouble on the control panel, which we regularly repair nationwide for $39.95 postpaid.
The light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This often can affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on. Other trouble can occur as well.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement,
disassembly information and info on our repair service at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Posted on Nov 18, 2007
  • William Miller
    William Miller Dec 01, 2007
    We're happy to help and we appreciate your thoughtful rating of our answer.
My microwave stopped working you can input time but when you push start nothing happens it has power and everything just will not start its like the start button does not work
Possibly a bad door switch behind the holes where the latch hooks go into. Usually with the bad switch the timer counts down but nothing runs. It all depends on which switch is bad. Usually 3 switches inside.
Apr 13, 2015 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
My new Haier microwave isn't working! I just plugged it in for the first time, and set the clock on it. Then I tried to turn it on. No matter what cook time I enter, and then press start/30 sec., nothing...
When it times down but doesnt heat it is typically a problem with the door switches, especially one you just bought, may have been from shipping . A switch or connection may have been disodged when being shipped to you. Most machines have something like 4-5 wswitches, If 1 doesnt report right it will stiop the unit from running. But since some of them are closed it will accept the programing and try to operate. So a lot of times you get fan running and tray turning but no power to the secondary circuits. You will need to find out who does warranty for them or return it where you bought it as a defective unit.
Aug 14, 2017 | Haier Microwave Microwave Oven
We have a Frigidaire FMV156DCC that is about 3+ years old. as of last night when the door is closed and the time is selected one of 3 things happen (or doesnt happen) 1. is nothing, just a dark...
I would replace the door switches and set up the door gap to 1/8" just enough to alow for a little play.
Setting the door square is acheived by slackening the lower door hinge and re tightening it when the door is square.
Hope that helps.
Jan 03, 2011 | Frigidaire FMV156DC Microwave Oven
Our Kenmore Microwave Oven # 721.89941490 does not respond when the "start" button on the touch pad is depressed. All other functions of the oven work normally, including time set, count down, light,...
poosible burned contacts on cook relay mounted on circuit board; or, a defective solder connection(s) on same board. another spot to check in the door microswitches.
Aug 30, 2010 | Microwave Ovens
We changed the cooktop bulb and now nothing works. When you push the light button the light inside the microwave turns on. If you set the cook time the time counts down but nothing runs.
Check the door interlock switches. They will keep the unit from starting but you will have power everywhere else. If this is helpful, Please leave positive feedback. Thanks, SnugglePants
Oct 20, 2009 | Whirlpool Microwave Ovens
Does not cook - time counts down extremely fast
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
Then let us know if the hard reset does not fix it.
and please reply back with your brand and model number so we can help you.
Feb 06, 2009 | Goldstar MV-1526 Microwave Oven
GE Spacemaker Microwave Clock inop
You can download GE owner's manuals and installation instructions here.
Oct 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson Microwave MW8115SS
there is a thermal fuse inside that is likely blown.
easy to replace just have to google bullet thermal fuse.
May 11, 2008 | Microwave Ovens
Power cuts out after about 5 seconds
Hi try unplugging form mains for an hour this will reset any settings back to factory settings let me know what happens after doing this then i can assist you further ok
Mar 19, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool MH1150XMQ Microwave Oven Logo
50 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
