Doesn't turn because belt is broken. Agitator doesn't turn
SOURCE: whirpool agitator
The parts are called agitator dogs,the top half of the agitator should pull away from the bottom half.
SOURCE: broken washer belt
This machine has no belt. It does have a motor coupling. Easiest way to replace it is to lay the machine on its back. Remove the pump cilps and slide the pump out of the way. Remove the motor clips (they may each have a 5/16 screw), and slidt the motor out. Replace the coupling and assemble in reverse order. Coupling # 285753 available at www.timerking.com for 9.99 or from sears. Hope this helps!
SOURCE: 2000 Eclipse GT turns over
Hi, if the car turn over, and it don't start. Then it is like the
engine don't get fuel. Or bad a spark plugs. Most common problem is the
fuel pump going bad.
It could also be a bad fuse, but a easy way to check if the fuel pump is
ok is to have someone stand at the back of the car when you turn the
ignition. The fuel pump should make a buzzing sound for a few seconds.
And if you don't start the car right away the fuel pump will stop.
If you don't hear any buzzing from the fuel pump/fuel tank then you have a bad fuel pump............
SOURCE: My monitor turns black automatically after about 3
LCD monitor? More than 2 years old? Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
If yes, then read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
SOURCE: Bottom agitator brush bar doesn't rotate.
First, check to make sure the brush bar is on. The switch is right next to the machine's on-off button, and it is easy to accidentally turn it off when you turn the DC 25 on or off.
Next, check for and clear any obstructions in the brush bar housing.
Finally, check for belt wear and replace if necessary. There is a very video online showing the procedure.
