I have a lanier copier 5216 and it is flashing H and 4 on its display is there a way to reset this ir is there something wrong internally.
  • paul252 Jul 15, 2009
    Thank you I think the repairs are beyond my means though any decent repair people inthe ft lauderdale area ?
  • 2,200 Answers
Hi
H-4 means the fuser unit is not heating up.
An reset occassionally works i.e - disconnect unit from mains for 30 seconds or more then reconnect.
Failing this check the fusing lamp in the heat unit along with any thermal switches.
Hope this helps. Please remember to rate my answer. Many Thanks
Posted on Jul 15, 2009
What is error code SC542 for ricoh aficio 9005?
Ricoh Aficio MP2510, 3010 Error code sc542 on Lanier ...
? 6:08
https://www.youtube.com/watch?v=58MQVyjfDyg
Sep 3, 2013 - Uploaded by Used .Copier
Are you getting Error Code sc542 on your Ricoh, Lanier,Savin or Gestetner copiers? ... Ricoh Aficio 1022 ...
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...
? 2:41
https://www.youtube.com/watch?v=3CnGl1Ytp34
Sep 21, 2015 - Uploaded by Copier Liquidation Center
How to reset Ricoh Error Code sc542 sc546 sc548 problem ...Ricoh Aficio copiers : AFICIO 1013 F
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Lanier 5527 that is displaying SC541
This is a fuser error, you will need a service call.
Feb 01, 2010 | Lanier 5222/27 Laser Printer
Lanier Model #7320 Copier SN 826255. Has a wrench
Press "clear/stop" and "8" at the same time. An error code will be displayed in the copy quantity window as long as those two button are held down. What is the error code? Each code is specific to different areas of the copier. I will be more than happy to assist you in resolving.
Sep 23, 2009 | Lanier Office Equipment & Supplies
How do you reset a lanier 6112 copier so the wrench stops flashing. thanks
The maintenance time is flashing.To be use the service enter code C-0-0-C or C -Interrupt-0-Interrupt,then press 20(maintenance counter clear) and 72 maintenance preset counter setting for a new value.
Aug 07, 2009 | Lanier Office Equipment & Supplies
We had a power outage and now my lanier 6523 copier won't copy. It says ready but won't recognize that I hit the numbers. Is there a reset or something?
Try turning it off, then unplug it from the wall, wait 30 seconds, and plug back in, then turn it on and try to operate.
Jun 22, 2009 | Lanier Office Equipment & Supplies
Lanier 6725 need pm code or manual
A2 means something is wrong in the duplexer. Check all parts of the duplexer for jammed paper.
May 28, 2009 | Lanier Office Equipment & Supplies
Service code 561 error
Hello sir; Just follow my direction, it will reset your machine;
1, press "clear mode", "107", then press and hold down "clear/stop" key.
2, touch "copier SP" on the screen.
3, enter "5810-001" press enter.
4, set value to 0, then turn power off and back on again.
May 15, 2009 | Lanier Office Equipment & Supplies
Problems with my MODI XEROX 5216
It can not copy. When I power on after 30 seconds the copier show U4 in the screen and do not work.
Mar 13, 2009 | Xerox Office Equipment & Supplies
Ricoh c410dn sc307
That crosses over to the Lanier LP226cn.
SC307 - Charge AC bias error [Y] (Level D Error)**
Symptom: The charge current less than 200 ìA is detected.
Possible Causes / Required Actions:
• Defective charge roller
• Defective connectors
• Disconnected harness
• Defective high voltage power 1
1. Check the connectors.
2. Replace the PCU for yellow.
3. Replace the drum positioning plate.
4. Replace the high voltage power 1.
** (Level D Reset Procedure) Turning the main switch off then on resets SCs displayed on the operation panel. These are redisplayed if the error occurs again.
- Lanier Tech
May 21, 2008 | Office Equipment & Supplies
Lanier 7213
Is the copier displaying any numbers or letters besides a service call light. The copier will display more then you are telling. Need a little more info. to give a educated answer or do you want a SWAG answer?
Mar 11, 2008 | Office Equipment & Supplies
35 people viewed this question
k24674
jasbo
jasbo
