Question about RCA F36450 36" TV
Channel numbers change, but actual channels don't.
Have picture and sound, the number will change, but the channel won't. try to switch to different input jacks to set up game system, but no matter which i select they won't work either.
  • 68 Answers
You may have to replace the tuner.
Posted on Feb 10, 2008
Westinghouse ld2680 will power up and display channel then got to black screen and keeps repeting this.
I don't have a fix, but here is a workaround:
1) While a picture is displayed, use the channel up/down button to switch to the nearest channel with a different major channel number (i.e. the number before the period is different).
2) Now press the menu key to enter setup and then rescan the channels.
Your TV should now work correctly for a week or two, then the problem will surface again. Repeat this workaround as often as necessary. I hope this helps.
Jan 26, 2012 | Televison & Video
LCD 42 LG TV won't change channels with channel button only with numbers
First check with fresh batteries. that does not resolve it If a universal remote- try a different code. If original remote, press the "TV" button first to make sure it is using the right parameters. If still not resolved, the issue may reside in the IR circuit of the set.
Dec 31, 2011 | Televison & Video
Same thing... suddenly will not "allow" one channel to be seen
go to tv menu, do an "autoprogram" and it will select all available channels.
You can also do an add/remove channel and manually delete the channels you know you don't have.
You can also change your tv from air to CATV (cable) On cable tv you can still get all the air channels and Fox just the numbers will be different, but you may have a better signal
Jul 10, 2009 | Olevia LT42HVi 42 in. LCD Television
Channel numbers change but channel does not
The problem is in the "Guide-Plus" set-up. Go theu the set-up process again and when it asks you if you have a cable box select NO.
May 25, 2009 | RCA P61960 61" Rear Projection Television
Re: Sony Bravia remote problems
sounds like you need to "autoprogram" your channels. In the customer menu search for "settings" (looks like a toolbox) select that, arrow down to "channels" select that, you'll see option for "autoprogram" select that. Any channel it sees it will lock in and you shouldn't have to press numbers anymore.
Rustym62
http://www.the-tv-dude.typepad.com
Apr 27, 2009 | Televison & Video
Digital channel numbers are different
The channels for a digital stations are really just "names". Thy will be the number for the old analog channel followed by a "-" and a number 1 through 4. The actually frequency can vary
from the old frequency. You can see this at;
http://www.tvfool.com/
To set up your tv, you will have to connect your signal source (Antenna or Cable) to the set.
Go into the menu and select the Signal source (Channel) to match what you connected.
Go into the menu for scan or auto program and SCAN in the channels in your area.
Now you can watch the stations on your set.
If the broadcast frequency of any station change, you can re-scan it in again. The "name" will not change so the change will be invisible to you.
Feb 25, 2009 | Vizio L32 32 in. LCD HDTV
Sony WEGA 42" LCD Rear Projection TV It won't change channels up or down with the remote or the buttons on the television.  It will change channels with the number pad on the remote but not the channel...
Hi, it sounds like your saying that punching in 08, 09 etc. works but channel up button won`t switch from 08 to 09 correct??? If so you need to go into your tv`s menu and "autoprogram" your channels into memory, video-tek
Jan 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Menu won't show.
sounds actually like it has had weather damage, sometimes water can get into a place it shouldnt on a tv, not shorting it out, but instead messing up in your case the numbers or menu screen, so i'd say it is best to take it to tyour nearest recycler, hope this helps.......jason
Dec 29, 2007 | Sony KV-27FS12 27" TV
Magnavox TV
It's possible that V-chip is locked.. Go to the menu and see if the lock option is active... The backdoor password is 0-7-1-1 twice.. Entering it the first time, if it times out, will display "incorrect" just enter it again and it should ask you for a new password..
If that's not it let me know and we'll try a couple other things.
Bill
premtech@willapabay.org
Nov 17, 2007 | Philips Magnavox MS3652S 36" TV
RCA F36450 36" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
