Question about Sony KDF-E55A20 55 in. LCD Television
TV screen goes on and off about every two to three minutes. Lamp shuts down
  • rramza May 11, 2010
    Other people with the same issue have posted that replacing the bulb has not fixed the issue.??
  • 10,594 Answers
When did you replaced lamp last time in TV?
Seems lamp is weak in your TV and requires replacement.
Posted on Jul 15, 2009
I have a Samsung HLM617WX XAA DLP TV purchase in 2004. I replaced the lamp (BP96-00224J) in 8/09. Other than this the TV has operated perfectly. This week the screen went blank and the three LEDs flashed...
If the lamp is failing, the sensor on the ballast unit will shut it down. Check with a new lamp and ensure the cooling fans are clear and filters are clean.
Mar 31, 2017 | Samsung HLN617W 61" Rear Projection HDTV
After set is turned on for 1 - 2 minutes the TV shuts down, no blinking lights just goes out. After a couple minutes it turns back on then goes off again.
It is symptom of dying lamp in tv, replace lamp of tv to solve this problem.
Please note that lamp has not been dead or broken yet but become weak in result and causing problem.
Lamp replacement procedure is written in user manual and it is easy. Please buy Sony original lamp for good picture.
Thanks.
Jan 05, 2011 | Sony KDF-E55A20 55 in. LCD Television
TV goes off after 20 seconds Samsung HLS5086wx
First Take off the Lamp Door and replace it back the way it was secured with all of the screws. Doing this will reset the safety interlock switch which heats up and opens the circuit causing the set to shut down. After doing this and the set still shuts down check the lamp. Depending on the amount of hours on the lamp it may be a bad lamp. They will fail with out any obvious signs. If the set shut down and goes straight to the Stand By condition then you have a bad Power Supply. If you hear a whining or buzzing sound then you have a bad Color Wheel.
Apr 11, 2010 | Samsung HL-S5086W 50" HDTV
KDS-R60XBR1 Sony Projection SXRD
The lamp may be starting to go, the symptoms you describe are classic warning signs. You could unplug tv let it cool down and check lamp most likely the glass will not look clear maybe a little milky or smoky in areas..dead give away.
Mar 07, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
JVC HD DILA 56G886. replaced lamp and now it shuts down after 10
we found that it is an auto shut off system on the TV due to over heating. The lamp, if not cooled correctly shuts down. We added a mini fan in the back and it seems to work fine now.
Jan 25, 2009 | JVC HD-56G886 56" Rear Projection HDTV
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Tv not staying on
If your pic and audio goes in and out evry 10 to 15 second or more then you need to replace the lamp.ITs not complicated to change the lamp.
May 17, 2008 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 Lamp Shut Down with no blinking lights
If you TV is about 2 1/2 yr you probably need a new lamp they only last about 3 yrs. Mine popped one night and now picture comes in for about 1 min and goes out, I ordered a new lamp today they run $199. There is also a know issue with the thermal fuse. The part cost about $3 and if you know a lil about electronic you can replace it yourself
Nov 11, 2007 | Sony KDF-E55A20 55 in. LCD Television
Sony KDF-E55A20 55 in. LCD Television Logo
270 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
