Question about Panasonic CQ-C1103U CD Player
There is a remote wire that comes out the back of this stereo. Or do I need another harness
    Problem Solver:
  • 5 Answers
That is if you want to run an amp
Posted on Jul 15, 2009
3 Suggested Answers
SOURCE: VRVD630, easy question..
Hallo! It very easy. I bought some parts (probably $5) and made adapter. Everything work perfect. Good luck!
Posted on Apr 19, 2009
motor1258
  • 6674 Answers
SOURCE: I removed my stereo from my 2005 Chevrolet Tahoe.
Check out this link. Should have necessary info for you.
http://www.the12volt.com/
Posted on Feb 25, 2011
Hi, I have an offbrand, dual 15"s, but they still work like the normal brand ones. The question is, why they give me feedback when the car is off and some Windows r open. It just sits there and hums
It sounds like your amp isn't shutting off. If its humming when the stereo is off, and the key is in the off position, make sure that you have the remote power wire coming off the amp hooked to the blue/white wire coming off the stereo harness(with aftermarket harness). If your using the stock stereo, it can be hooked to the switched 12+ wire ( lookup factory wiring here:
The Install Doctor The Do It Yourself Car Stereo Installation Resource... ) but the amp will only shut off with the key off, not when the stereo is off and the key is in the on position.
Sep 19, 2015 | Cars & Trucks
F5TF-19B132-BA Ford Radio Pin out
The stereo pin layout can be obtained from the car dealership, also a repair manual should have the stereo wiring harness layout in it , the stereo harness adapter for installing non oem stereo, found at the local auto parts store will come with the wiring layout, wires are color coded too, sometimes the stereo harness or stereo harness adapter will have small writing on the wires itself, showing you what that wire is for, and where it should connect.
Basically it comes down to, obtaining the stereo wiring layout, read the description on the wires, and properly connect them together, then solder the wires or crimp them, I like to solder mine with soldering wire for electronics, and put shrink tubes to protect the wires, put the shrink tubes on the wires before soldering together, and ensure the shrink tube is the proper size awg wire gauge.
You will also need, aftermarket face adapter kit and antenna adapter, if installing aftermarket stereo.
Hope this helps and enjoy the stereo :)
Apr 11, 2015 | 1999 Ford Taurus
Aftermarket stereo turns on but can't hear anything 1997 explorer
Did the truck have the premium sound system? If so, you will need to connect the blue remote wire to the blue remote wire on the harness. You may also need a special harness to bypass the factory amplifier.
Jan 10, 2014 | Car Audio & Video
Please Help I Need A 1992 Mercury Capri XR2 color-coded Stereo Wire Harness Diagram
Go to your local auto store and get the Hanes auto manual for this care and they should have a wiring schematic for you to follow also you can look your new stereo up on the web and find out what each colored wire goes to what!!! Good luck
Jun 07, 2012 | Lincoln Cars & Trucks
I want to know where and which cables to connection on my van
Thats pretty vague, but here is the basics:
Battery wire (red) should go from the battery of your van to the amp (+)
Ground wire (black) should go to the frame (metal) of your van and to the (-) of your amp
The blue wire should go from your amp to either the back of your stereo unit (remote accessory) or to the fuse box (accessory/ignition)
Left/Right audio should go to the subs.
If you are looking to install a new stereo into your van, they make a wiring harness that will fit the year and make of your van to get you going in no time.
All you do is buy that little wiring harness, and connect the wires on the back of your new stereo to the same colored wires on the harness, and plug the harness directly into your dash!
Super easy!
Hope this helps you out!
Feb 23, 2011 | Car Audio & Video
I have a 92 marquis, and ive just changed out the factory stereo with a aftermarket. How can i hookup the amp that came with the bose system??
If you bought a wiring adapter kit for the aftermarket stereo, the unit should hook up directly to the stock bose system. Note: If there is sound coming from the speakers after installation, the amp IS hooked up...the speaker wiring is routed to the factory amplifier, not the stereo itself, the stereo wiring is just signal leads to the amplifier. In some instances, you may have to connect the amp remote wire to the remote wire coming from the aftermarket stereo(blue wire). I hope this helps. Any other questions, just reply.
Feb 06, 2011 | 1992 Mercury Grand Marquis
I dont know how to setup my amplifier to MP3 Stereo...
Just like any other stereo. Get a wire harness for your car and match the wire colors together, tape them or cap them, or best yet soder them. Then run rca cables from the output in the back of the stereo to the amp. The run a remote wire (bue with white stripe) from the stereo to the amp remote terminal. Hook up the amp normal. let me know.
Dec 22, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Stereo turns off when headlights turned on
Sounds like you have the ground for the radio hooked up to the illumination ground wire. Check for orange or orange/black wire coming from the radio harness. Did you buy the harness for the car as well? If so then just match all the colors of wires from the car harness and the radio harness. By car harness I mean the harness that plugs into the harness that the original factory radio plugged in to.
Thanks
Mar 29, 2009 | Car Audio & Video
97 dakota installed radio harness have power no sound
If you still haven't fixed this, look at your wiring harness. The blue wire that comes off your factory harness is the external amp in the Infinity stereo. I found this out when I hooked my Pioneer head unit up. Coming off the aftermarket stereo should be a blue wire that says remote. Hook those up and you should be good to go.
Jan 18, 2009 | 1997 Dodge Dakota
Installing after market stereo
Dave,
You will need to go buy a wiring harness adapter from your local Walmart (usually cheapest there) or Local Electronics place (ie Best Buy). The wire harness that goes out from the radio goes into the Adapter and the adapter plugs into the car harnesses. Also these Adapters come with the wiring diagrams for your vehicle. They typically run 10 - 15 bucks depending on where you get them. Thanks for using FixYa!
Sincerely,
JC
Nov 21, 2008 | 2000 Pontiac Grand Prix
Panasonic CQ-C1103U CD Player Logo
308 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
