Question about KitchenAid (KSRD22FKST) Side by Side Refrigerator
No water to ice maker
I checked the solonoid and it had power to it but only 2.2 volts. I don't know how much it requires but no water coming out. There is water at the door.
  • KitchenAid Master
  • 4,654 Answers
The voltage to the solenoid only comes on when the ice maker ask for water to refill. Unplug both sides and check the resistance in the 2 coils. They should show very close to the same. The ice maker has a thermostat inside to tell the water valve to come on if defective the voltage most times 120 volts will not get to the coil. Sea Breeze
Posted on Jul 18, 2009
Ice maker stopped making ice
Here is a check list to use to verify ice maker is good or bad or if something else is causing the problem.
1) Has the water filter been changed recently, or does it need to be changed? The filter being old can cause a reduction on water and lower performance of anything else that requires water.
2) Check the temperature in the freezer. Even though things are frozen in there, the ice maker requires that the temperature be at least 10 degrees F to even cycle. Ideal would be around the 0 degree mark.
3) Check the fill tube where water comes into the ice maker. From time to time this will get blocked due to water freezing in the tube itself.
********* If the first three checks all pass, either the water valve is bad and not allowing water to come to the ice maker, or the ice maker itself is not calling for water **********
Depending on the age of the machine it might not be a bad idea to change the water valve and the ice maker together.
May 30, 2012 | Frigidaire Refrigerators
Ice macker will not make ice have water going to I havewater I front door but no water in ice tray
The water supply valve is a dual one with separate solenoids for ice and water. I bet your water supply valve is shot. themobilian_2698.jpg
Jul 28, 2011 | Maytag Refrigerators
We have a Whirlpool refrigerator model ET1MTKXKQ07. We have recently had a problem with water pooling inside the refrigerator. We know that the drain line must be stopped up, because there isn't anything...
There is no drain line as the only water that goes into the refrigerator is the water that goes into the ice maker. The out side water only goes into a glass or spilled on the floor.
I suspect that your inlet water solonoid is not reseating properly after the ice maker signals it to close. It opens by an electro magnet and closes by spring pressure. You may have to have it replaced. The ice maker rotats and hits a micro switch that sends power to the solonoid that snaps it open and is held as long as the switch is depressed. when the cam on the rotating vane passes the micro switch lever, the switch goes back to normal taking the power off of the solonoid, and spring pressure snaps it back in the closed position. This cam is timed to just fill up your ice tray.
Jan 04, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a code 2 on the water light, cme506as-10, the solonoid isn't kicking in, Help
check float switch if its not functioning control will not no it is out of water so it will not engage fill
Aug 31, 2010 | Scotsman CSW45 15" Ice Maker with 26 lb....
I have connected the water to the refridgerator and have water flowing properly from the door. However, the ice maker does not fill with water. What am I missing?
Suggest you do a good defrost, then retry. Also take note if the opposite solonoid to the water solonoid for the fridge activates. (will be found at the back of the fridge).When the ice maker requires water, it will activate the one valve at the back.
Aug 17, 2010 | Refrigerators
Profile ice maker stopped making ice
ice maker for ge profile wont' make ice.Unplugged elect supply from both waterin the door coil and ice maker coil.Plugged water in the door elect to ice maker valve coil and pressed water in the door input sw out front and got water to ice maker so this let me know it wasn't the solonoid valve.Got another ice maker unit plugged in and mounted waited several days still no ice.
Sep 27, 2009 | GE Profile PSW26P Stainless Steel Side by...
I get water in the door but no ice we purchased off a person who said they never hooked up the ice maker older model tfx25zpzbww am I missing something put lever down 12 hours not a drop. does the filter...
Trace back and see if water is waiting to come into icemaker.If not, suggest you check the 2 valves at the back. one is for the water dispenser and the other is for the icemaker. Possibly the solonoid is not functioning. If there is no water, the icemaker sensor sees no water and there is no action. Let me know.
Sep 25, 2009 | Refrigerators
Ice maker is not filling w water. water does come
The ice maker likely needs replaced however it could also be the fill valve. If you have the ability to locate the valve at the end of the fill hose (usually bottom right when looking at the back of the fridge) it will have 2 solonoids with electical connectors on them. Swap the connectors and press the water dispenser paddle. This should fill the icemaker. If it does, the valve is fine and the icemaker is bad.
Aug 21, 2009 | Whirlpool GD5SHAX Side by Side...
Amana side by side ice maker will not fill with water
Old message, I'm sure you have solved your problem by now, but . . .
IF
 Amana/Whirlpool conforms to wiring standards (no guarantees), the main AC wires should be white=neutral, black=hot, red=switched line.  Of course, they already depart with the use of the brown wire.
You should be able to access the 'full' switch at the ice maker itself and as you have found, it will turn on (or off) the fill solenoid.
It would be kind to post back what you found as it might benefit others in the future.
Thanks-
Nov 30, 2008 | KitchenAid (KSRD22FKST) Side by Side...
KitchenAid (KSRD22FKST) Side by Side Refrigerator Logo
157 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
