Question about Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112)
I have downloaded msn8.0 on my computer why isn't it working?
Not showing in my control panel that i have downloaded it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 163 Answers
Download it once again or check your temp folder
Posted on Jul 16, 2009
The control panel isn't working properly. How do
Try getting in through the start menu, your documents, and your search bar. If all fails, then start your computers command prompt, (type in search button in start menu: "cmd") just type in: "start control" and press enter; the control panel will launch. Also, if you type "run" in your start menu search bar and type in control followed by pressing the enter key, the control panel should start up.
Jun 22, 2013 | Computers & Internet
Canon pixma mx420 scanner menu doesn't load
Uninstall the Software from the computer completely and go to http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx420#DriversAndSoftware
to download the software again. make sure you delete the old one first through "control Panel" Uninstall Program, etc. Also make sure your printer isn't connected to the computer until after the software has finished installing. Then plug in the printer and see if the menus will show up. let me know how it goes..hope this helps!
Jun 16, 2012 | Canon PIXMA MX420
My Emtec animal USB flash drive isn't showing up on my computer
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
Jan 10, 2012 | Electronics - Others
My touchpad buttons don't work IBM T42 laptop
In this case you probably disabled it by mistake ..and you need to enable it again ..Go to control panel ..and locate the touch pad..and see if it needs enabling . If this will not work ..you have to download the driver for the touch pad..and reinstall it ..or ..if the driver is still in the system it is enough to get to control panel ..add hardware ..and run the add new hardware wizard..This will search for hardware and show the ones which are not installed or ..if no one is present ..select already added and look for the pad..
Or ..I would option for getting into device manager..(right click on computer ..select properties../hardware /device manager..or direct device manager for win7 ..)
in the device manager select the touch pad..and click right on it ..and select update driver..This will start the wizard and install the missing driver if it is still in the system ..If it isn't you will have to install it manually after you download it from the support site ..or from the disk .
Nov 24, 2011 | IBM ThinkPad T42 Notebook
Floppy drive is not shown in computer what is the reason behind it
hi.................................
Floppy Drive Does Not Show Up In My Computer
In case when your floppy drive does not show up in your "My Computer" whereas all other drives are showing up than you must first check if your drive is working fine?
Click on Start > Run and in the Run windows type compmgmt.msc, click on Device Manager and in the right pane right click on Floppy Disk Controllers and select properties. Check if the device is working fine. If it isn't than you need to contact your hardware vendor else if it is working fine than read on the problem seems to be in your BIOS.
Before proceeding make sure you know how to play with your BIOS. If you cannot better get help from experienced hands.
Check the CMOS settings and see if the floppy drive is visible. Ensure that the CMOS is set to "Halt on all errors" and also check that the BIOS' "Report the floppy drive to OS" setting is enabled.
Another reason could be drive letter conflicts caused by software such as RAMdisk.
Another reason might be the TweakUI power toy available at microsoft for FREE download. (check the right column for the download link.) The tool can cause drive letters to be hidden in Windows Explorer and My Computer. If you have it installed, go to the Control Panel and double-click on TweakUI. In the My Computer tab, select the checkboxes of the drives shown as hidden. Click Close and restart.
BEST OF LUCK............................
Sep 23, 2011 | Computers & Internet
My USB drive isn't showing the data that i put on it. The data is still there, but i can't access it
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
ports(com&lpt)right click update driver if this fails to fix the problem
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Aug 11, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
Batteries are good. However TV isn't on right channel to show any programming what to do?
Hi William,
To confirm if the remote control is working fine, aim the infrared emitter of the remote control to your cellphone camera, press any button key and check if the infrared will flash to your camera. Watch this video on how to do this trick.
Also, does the front panel button key of the TV isn't working?
Jdvillanueva
Jul 09, 2011 | Toshiba CT-9995 Remote Control
Acer x1300 - reinstalled vista and have three yellow warnings in device manager: Coprocessor, Ethernet controller, sm bus controller? How do I fix?
Easiest way would be to use a seperate computer and download the drivers onto a usb stick and use that to install the drivers. You can't download straight to your computer since your Internet won't work (Ethernet Controller isn't installed) You can also burn a CD if a USB doesn't work.
You can get the drivers from here.
http://driverscollection.com/?H=Aspire%20X1300&By=ACER&SS=Windows%20Vista
Jun 05, 2011 | Computers & Internet
My MSI web cam would not work. i pressed the fn then the f6 button still not working! does anyone have any solution or help please and thank you
Go to the "Control Panel" on your computer and access the hardware options and see if your camera is listed on it. If it isn't, you will need to download the driver that will install the camera on your computer.
May 20, 2011 | Computers & Internet
Presario C714NR gr983UA#ABA ALPS touchpad does not work I have updated the BIOS and uninstalled and reinstalled the drivers but it still does not work
I had a similar issue with my ASUS. Try finding a program on your computer other than the Control Panel that controls the trackpad. For instance mine is Elan Smart-Pad. Usually working with some of the configurations in the program reinitialize the trackpad. If that doesn't work make sure that it isn't turned of due to keyboard interference (hitting a button that turns the trackpad off). Hopefully that isn't the case though.
May 10, 2011 | Compaq Presario 700 470024-192 Notebook
Microsoft Windows? Vista Home Basic Edition Full Version for PC (882224181112) Logo
67 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
