Akai airconditioner AC-KS24HRC Changed batterirs in remote can not get heat mode icon on remote therefore no heating.Still under warranty but can not find Akai repairer Newcastle N.S.W. Australia
I had the same problem. Check the remote control section of the manual. When you change batteries the screen flashes the hot and cold icons alternating. press a utton when the hot one is on and it will activate the heat+cool mode.
Posted on Dec 08, 2009
  • zacour3
    zacour3 Aug 10, 2012
    It worked thank- you thank-you thank-you!
  • John Jan 01, 2017
Aircond remote dead have changed batteries?
Posted on Dec 25, 2009
Why isn't it heating?
Because its an air conditioner, not a heater?
May 03, 2015 | Heating & Cooling
Heat pump runs on electric when outside temperature is higher than cutin
Check your thermostat and heat pump owner's manuals. Thermostat may be programmed to require electric heat at higher temps. Also could be bad outdoor temperature sensor tied to
Heat pump system controls (I had that problem) When was it installed? Warranty thermostat and or Heat pump? Call installer
Thermostat programming is a headache. No help from installer? call customer service heat pump and thermostat. Some possibility of bad installer wiring. There is also a heat pump "defrost" cycle. Usually the Electric coil will turn on to compensate for the Defrost cycle which is just the standard air conditioning mode therefore moves heat from inside to the outside coil to melt the frost. This cycle may be occurring too often. I had that problem. Fixed under warrantee.
Heat pumps are complex machines. The controls even more.
You need a tech, hopfully you are still under warranty.
Hope this helps.
Feb 27, 2015 | Payne 15 SEER R-410A Complete Split System...
I can't get the airconditioner to operate unless I use the remote.Dose not get any responce from the key pad on the unit itself. The air conditioner is only 3 months old.
May be touch pad in your PCB not sensed. Better repair it, when it's under warranty. But even after it's advisable to operate maximum only by remote. Thanks.
Dec 15, 2010 | LG Heat cool Window Air Conditioner
Remote of TCL airconditioner will not point to ''heat
I have the same problem and have to get a person out to look at it, not happy as of course now it is cold!!!
May 16, 2010 | Heating & Cooling
I have a Toyo Aircon split unit Airconditioner/heat pump. 12000 Btu. When in the heating mode, I get the code E8 after it runs for 5 to 15 minutes. At that point it seems to run (at least the...
You might want to refer to the unit manual, which has a fault code section (if the unit has a manual), look up the fault code E8, in the manual and it will tell you what fault it is. Depending on where the unit was manufactured, you may not be able to contact anyone regarding the warranty or diagnoses of the fault, so instead contact your local A.C company for help. Sorry I could not be of more help.
Dec 10, 2009 | Heating & Cooling
My 1988 toyota camry: airconditioner/heat doesn't work
The heater may not work because of a bad thermostat, low coolant, or a bad sensor at the engine. It can also be a bad resistor valve under the dash. The resistor valve is connected to a wire plug on the blower motor under the dashboard. It needs to be replaced. Th AC may need to be refilled with refrigerant or the compressor may be bad.
Nov 18, 2009 | 1998 Toyota Camry
Conia CA1800 wont heat
there should be a mode button, press it until you see the sun sign
Jul 09, 2009 | Heating & Cooling
Mitsubishi PAR-F27MEA AC controller icon meanings
hi.welcome to the mitsubishi worl of airconditioning.thay are great units to have.ok let me explane this for you.
the sun is for heat mode
the snow flake is for cooling mode
rain droplet is for dehumifiy the air if its a humid day.i hope this helps have to choose the modes on the remote for the unit.then the unit will do the mode you choose on the day.
Jun 09, 2009 | Heating & Cooling
Manual for Akai reverse cycle airconditioner remote control
I have a Akai AC-GP10HRCI model portable air conditioner. We have lost the manual. It shows F8 on the display panel board and is not working at all. Please help. Thank you!!
Jun 08, 2008 | Heating & Cooling
Heating & Cooling Logo
613 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
