Question about E-Machines eMachines Desktop PC
Emachine W2646--lights blinking on keyboard,pwr lamp on speaker on,power button on tower YELLOW,NO response! unplugged several hours,now dead,as if unplugged! This happened overnight while shut off completely,no one touched.
  • 788 Answers
If you have a Yellow light on power supply, chances are you have blown the power supply.
Even with a PC unplugged in a Bad Storm, I have seen many PC's and Laptops with Supplies shoot.
If you have a little computer savvy, the best thing to do is,
1. Disconnect power.
2. Open unit.
3. Disconnect all Devices from supply.
4. Disconnect 20 04 24 pin power supply connector to mother board.
5. If you have other connectors such as 4-pin 24 Volt acc. you can disconnect that as well.
6. Now plug in the supply. Note... Some supply's have a reset located in the rear of the supply, where it makes its input ( A/C connection. ) If so try the reset. Some supply's also light up or have a service light when sensing input power, some do not.
7. If all looks good and no sparks or flames, re-connect the mother board connection, (only)
Try to power on computer.
Note..... If you still have the Yellow light, Replace the supply.
In some cases, the power supply sees a fault and fold back to a protection mode.
The supply has several Capacitors in which hold a charge and when connected to the mother board retain that charge. Disconnecting the Mother Board 20- 24 pin connector will allow this charge to dissipate.
If all works after reconnecting supply, Your Good To Go.!!!
If not, you may need another Power supply.
Or may have done other damage.
Hope all works out for you.
Try it, it may work...
Readers, please rate your Technician
Thank you.
John Ray
john@johnrraycomputer.com
Posted on Jul 15, 2009
Compaq FS7600 Computer not turning on
what tower? model, the monitor has nothing to do with power and dead fans in the tower.
'Sounds, (and silent to) means the PLUS in the PC is dead.
all things can be repaired, that is what technicians do.
here is the chain of events, ! to get noise (fans)
power in the wall 120vac , usa
power to the PSU,
the power button goes to the MOBO, and standby power is there
now and pushing said button the MOBO commands the PSU on
if the PSU is happy (PWROK) thinks PSU IS safe the PSU tells the PC its ok, and power stays up.
and fans run.
so my guess bad PSU, its easy to test with anyf $10 voltmeter,
ask.
tower PSU, 101
http://pcdied.com/power.html
May 21, 2017 | HP Compaq FS7600 17" CRT Monitor
I have an emachine t2885, when i hit the power button, i dont get any power to the computer, but the keyboard, speakers and monitor lights go on, but no power to the computer, help
I'm going to guess pwr supply 12 volts side. The 5 volts side lights up keyboard and mouse; both get replaced when they fix (replace) the power supply.
The hard drive and dvd player us the 12volts side.
Check 12 volt supply side if low disconnect hard drive check voltage again,, if 12 volts hard drive bad,,, if low disconnect dvd,,, if 12volts connect hard drive,,,if 12 volts dvd bad. of course this scenerio can go the opposite way. Do you know how to use a multimeter? Black box maintence is exciting.
Nov 27, 2010 | E-Machines eMachines Desktop PC
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Casio keyboard lit up, no sound, no responses
Unplug for several minutes and try again.
If that doesn't work, look up the "factory reset" procedure for your particular model via google and follow that procedure. It usually involves holding certain buttons down before and during power up.
Jul 20, 2010 | Casio Music
The yellow power led light blinks on front of the emachine w2646. The CPU Fan works. The power button will not turn the PC on or off, you just have to plug in the power cord to turn it on. The monitor just...
Did you flash the main board ??
1.) remove battery
2.) press and hold the power button for 10 - 30 seconds
3.) replace battery.
4.) when the system boots it will say press XX (e.g F2) to load defaults and continue ,, press that key.
It could also be the power button is stuck!.
find were it connects to the main boad and unplug it
bridge the 2 pins it jacks into to turn the computer on. if it works u will need to replace that button or the case.
Feb 26, 2010 | E-Machines eMachines Desktop PC
Compaq presario sr1115cl wont power up
dont u dare ever use 220 line on thes eon usa power u blow it ever time u turn it on at 220 v dont u dare do that not no reset switch erther u must now buy new power supllly ok
Oct 12, 2008 | Compaq Presario SR1120NX 2.66GHZ Tower w/...
No Power will not turn on WD 62525
Are there any lights indicating the Tv has power? Any relay click when you depress power button?? Try unplugging the unit for about one minute, then plug it back into power and attempt to power it up. Let me know.
Bill
Sep 04, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Remove the power supply after everything is unplugged and take it to your nearest electronics store. They should have a tester there. This is probably the problem.
Jul 01, 2008 | HP Compaq Presario SR1420nx...
Flashing power button - no keyboard nor mouse. But PC works... ??
Yes, it may be that the +5v supply from the PSU is faulty, as the PS/2 ports run on 5v and USB runs on 9-12v. Replace the PSU with another of the same form factor and same power rating or better (>=230W). They come at ~£30, so not too expensive. For a little more. Try this:
http://www.quietpc.com/gb-en-gbp/products/psus-300-500/x-red-psus
Jan 28, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
315 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
