Question about Car Audio & Video
I got a amp hooked up to my mids and highs in my car, im getting a whining noise now how do i fix it?
  • sigl8618 Jul 15, 2009
    i got an amp connected to the mid and high speakers in my car, and its making a whinning noise, what could be causing this
    Top Expert:
  • Car Audio & ... Master
  • 80,637 Answers
This is Alternator noise, you need to install a DC power filter, go to the link below for a high quality filter.
http://www.powerwerx.com/product.asp?ProdID=1852&CtgID=1003
If u wish to understand the causes and repairs for "alternator whine" go to this link and read the article there.
http://www.sacskyranch.com/altnoise.htm
Posted on Jul 15, 2009
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.
Many newer cars have vacuum assist transmissions. Indications are that you have a loose or broken hose. These draft lines are usually connected to the intake manifold area on top and snake over long distances across often hot surfaces. Trouble shooting these malfunctions can be complicated and dangerous since other devices may also share these vacuum circuits. Have a trustworthy friend fully depress the "E" brake, hold the regular brake, putt the car in reverse, and then you can get a closer listen to were the noise is coming from. This leaking hose can vary in color and size ranging from pencil lead to thumb diameter. It might be a cheep fix. There is an oil plug on the rear differential. On a level surface, remove the plug; if oil starts to flow out, the fluid is full. If no oil flows, carefully put your finger in the hole and feel for the oil level. Your finger should go no lower than the first knuckle before you feel oil. If it goes further, you are low on oil and should either fill it up or better yet replace it. Rear axle oil doesn't get replaced nearly often enough in most vehicles and since your truck is 18 years old, would be a bad idea to have it changed. Be careful and good luck. God Bless.
Timing belt noise
You likely have a bad/worn
idler pulley, needing replacement. This may have been what made the timing belt go.
Apr 18, 2014 | 2004 Chrysler PT Cruiser
Need help finding & solving high pitch whine at mid to high speeds
It sounds like a Bearing is worn in one of the wheels or in the Drive-shaft. Get a mechanic to check it out
Jan 15, 2014 | 1994 Ford Crown Victoria
High pitched whine while accelerating
remove the belt and start the engine ..IF THE NOISE disappear it might be idler bearings that driven by belt but if the noise still there check the pcv valve..
Sep 24, 2013 | Toyota Tacoma Cars & Trucks
93 s10 whines
The fuel pressure regulator & spyder assy, most likely is bad
Don't think that is your noise though
Check trans fluid,may be pump noise
Jan 06, 2013 | 1993 Chevrolet S-10
Engine noise coming through one channel
This sounds like alternator whine. Do you have the power and ground connected to your battery, or through the accessory power? Make sure the power and ground wires are sufficient size, and connected to your battery, and make sure you have the power wire fused no more than a foot or two from the battery. If it is only on the right channely, maybe this wire is getting feedback from another wire. Seperate the wires if this is the case.
Wires create magnetic fields, and if a speaker wire is next to a power wire or something, you will hear a noise, typically high pitched whining.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 13, 2010 | Jl Audio E6450 Car Audio Amplifier
RCA F32650 production May 2003. Was working fine. Turned it on the next day, got no picture and a high pitched whining noise.  Please let me know what I should do to fix it.
If it weren't for the high pitch whining noise. I would say it probably is an internal fuse inside the chasis. It is rated at 1.5 to 2.0 amps. With the whining noise it sounds like a trouble shooting bench
job. Problems occur when a electrical/electronics device is turned on and turned off. Inrush voltage,
when it is turned on, can go up to three times more than normal. This also happens at turn off. Solid state components usually fail at this time. I don't feel that this is a problem that can be fixed in the home.---BBB
Jan 25, 2009 | RCA F32650 32" TV
IM getting a whinning noise from my speakers on my 2nd amp
CHANGE YOUR REMOTE WIRE TO A SINGLE LEAD, AND THEN CHECK ALL YOUR CONNECTIONS.
GOOD LUCK
Dec 11, 2008 | Car Audio & Video
RCA Whine, Newly Installed Amp
The shield ground is probably open in the head unit. You can check the shield ground by measuring the resistance from the shield of the RCA connector to the chassis of the head unit. It should be near 0 ohms. Disconnect all RCA cables from the head unit before testing.
If you find that the shield ground is indeed open, the following link has more information for a temporary fix.
Temporary Shield Ground Repair
Nov 18, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
