Question about DeLonghi Ovens
Delonghi oven grill broken, oven still works?
Hi there i have just returned from holiday to find the grill not working on my delonghi esm 455 st single oven. It was working perfectly before i went away. The oven and fan still work, i assume they are on different circuits. Is there an easy fix? Cheers Dan
  • DeLonghi Master
  • 3,463 Answers
You will probably find it is the grill element that is faulty, a common fault on your brand of oven, to be certain, you need a meter to test it.
Please rate my solution.
Thanks.
Posted on Jul 19, 2009
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
Fan oven no working ,but grill working
check the timer is set (often an icon of a hot baking tray)
two phase?
is the oven just not heating (fan still working) >> check fan element
Oct 17, 2013 | DeLonghi Ovens
My Delonghi EST461 ST oven has stopped working. The grill and fan work but the oven does not, it initially tripped the fuse. Any suggestions
always turn the power off first , you will need a flash light look carefully around the bottom element , I think it has burned out on you , it will have a bump or burned spot on it or may even be broken off , this is bery easy to replace and cheep if you find it is burned or broken off email all info on oven make, model, serial number I will locate the part and tell you how to replace it Have a nice day !
Dec 06, 2011 | Ovens
My Delonghi DE60PYROS needs a new thermostat, are
Ok get a Service Manual, and the Sensor, and it is not too hard.
Mar 29, 2010 | DeLonghi AS1070 Electric Single Oven
Burnt some food yest in grill and is not working today. wouldnt turn on straight away so i left it till this morning but still not heating up. oven is working perfectly fine. could the heating element for...
if the temp light or indicator light for the grill is on then i'm tempted to say that it is the element but checking for resistance is the only sure way to know..
Dec 22, 2009 | Zanussi ZBF360 Electric Single Oven
Hi there, The cooker trips the fusebox rcd,I have checked for s/c's between l,n,e, but found none. The rcd trips after you set the clock and turn the main controller to any postion,ie oven light only, or...
It is quite possible that it is the oven or grill element that is causing the problem.
You need to test them with a meter, to determine if they are o/k.
If you have no meter, then disconnect each one in turn, and try it again, this should isolate the problem.
Hope this helps you.
Dec 19, 2009 | Tecnik TKC071/3 Electric Single Oven
Delonghi ESM465ST Oven Noisy Fan
If it is a fan assisted oven, then you are likely to have 2 fans, an external cooling fan, and a fan inside the oven for ciculating the hot air.
So to answer your query, yes it is a noisy fan you are going to have to establish which fan.
It could be a worn bearing, or the fan blade has come loose.
If it is a worn bearing, thge only cure is a new fan.
Hope this helps with your problem.
Dec 02, 2009 | DeLonghi Ovens
Ovens Logo
314 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Jason Harris
Jason Harris
Brandon Berry
Brandon Berry
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
