Sony Playstation 3 (PS3) Console Logo
J
Jennifer ellis Posted on Feb 10, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the WPA key My ps 3 is asking for?
What's the WPA key
Mikey
Level 3:
Top Expert:
  • Sony Master 6,904 Answers
  • Posted on Feb 10, 2016
 Mikey
Sony Master
Level 3:
Top Expert:
Answers
6904
Questions
5
Helped
1623142
Points
26106
WPA is Wifi Protected Access! This is the security protocols for your wifi router......look on the router or in your broadband account for the WPA keycode
My ps3 is saying my WPA key I entered is incorrect and is saying that obtaining my IP address failed and I just used my WPA key to get the internet on my computer and laptop, How do I get online working...
Turn off the console by holding down the PS button in the center of your controller and then selecting "Turn off console". Then flip the power switch in the back of the console on and off. Then restart and attempt to connect again. Maybe all your PS3 needs is a hard restart...
What is a security key
WPA (Wi-Fi Protected Access) is an advancement over WEP (Wired Equivalent Privacy). While connecting to a home network, you are often asked to insert a WPA key or a password to which users often ask, "How Do I Find My Computer's WPA Key?" WPA stands for Wi-Fi Protected Access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over(Wired Equivalent Privacy) Wep is standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
While connecting to your home network, you are often asked to insert a WPA key. This WPA key is either located in the modem or in the router you are using. In order to find your computer's WPA key, follow the steps given below:
How to find your computer's WPA key Step 1: First of all, you need to launch an internet browser. Press "Windows + R" keys to open the "Run" prompt and type "iexplore" without quotes to open Internet Explorer. You can also type "firefox" to open Mozilla Firefox. On the address bar at the top, type http://192.168.1.1 (Belkin routers use 192.168.2.1 as the default IP) and press "Enter" key.
This address belongs to your wireless modem or wireless router to which you are connected.
Step 2: A window asking for username and password will appear. In the username field, type "admin" without quotes and in the password field, either type "password" without quotes or leave the password field blank. Press "Enter" key to continue.
If password is correct, you will be redirected to the modem/router's "Settings" page, otherwise, you will have to reset the modem/router. Check beneath the modem/router or check the manual for correct password.
To Reset a modem/router, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
Repeat the step 2, in order to gain access to "Settings" page.
Step 3: On the modem/router's "Settings" page, find "Wireless" option. Click the "Wireless" link to populate the wireless settings. Now, locate and click the "Security" or "Advanced Security" option.
On the security page, you will find "Network Authentication". Different options available under the Network Authentication menu are open, shared, WEP, WPA, WPA2, WPA-PSK, WPA2-PSK, etc. Select either WPA or WPA2, to find your computer's WPA key and insert this key when asked for.
If in step 2, you had reset the modem/router, you will not find any WPA or WPA2 key, and you will have to manually assign one. Select any of the WPA-PSK or any other authentication and assign a key to it. A key can be 8-63 long. For minimal security, you can choose 8 characters key, like "iN\/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBD\m+oMp$nrXj5XPVRTvVA5fpwGSGI\RVz4RdQ7V3y\l$P1NrT9Be".
After you have assigned a key, save/apply the changes and reboot the modem/router.
Note: The procedure shown above is common to most of the modems/routers. If this doesn't apply to you, check your modem/router's manual to find the wireless security option.
There a great article at General Router Setup.
If you need more help post back!
Thumbs and testimonial are welcome!
Says need to update encryrtion key
It sounds like you changed the password for your router's WEP or WPA security key. You need to go into the Network Settings on your PS3 and set up a new internet connection. Once you do that it will ask you for your new WPA or WEP security key.
Hope this helps.
How do i connect to internet with ps3, wireless, what is a wpa key?
WPA stands for Wi-Fi protected access. It is a standard security protocol implemented by Wi-Fi alliance to secure wireless computer networks. WPA standard is advancement over WEP (Wired Equivalent Privacy) standard that had several security issues. WPA implements most of the IEEE 802.11i standard and provides greater security than WEP.
You can correct this problem by entering the WPA Key into your PSP's Network Settings. But before you do that you need to know what your WPA Key is...
To reset a Linksys modem/router or Belkin one, locate a small hole at the back of the modem/router and insert a pin to press the switch inside it. Keep the switch pressed for about 20-30 seconds after which the modem/router will restore the settings to "factory defaults" and reboot itself.
For minimal security, you can choose 8 characters key, like "iN/5R92". For maximum security, choose 63 characters key like, "sJ0esmoU2cBDm+oMp$nrXj5XPVRTvVA5fpwGSGIRVz4RdQ7V3yl$P1NrT9Be".
Tryig to connect my ps3 over wireless connection to my belkin f5d8236-4...its asking for a wpa key
Hi Johnny,
Please follow the below steps,
1.type 192.168.2.1 in the internet explore
2.you will be able to see the Belkin router setup
3.in your left hand side,you will see the menu "security below wireless"
4.it will ask for password leave it blank and click on submit
5.now you will be able to see the WPA key,
if it shows in dots,then uncheck the "obscer PSK" box now you will be able to see the WPA key.
Regards,
Ayyasam
Im trying to set up my playstaion 3 to play online, it is asking me for a WEP key or a WPA-PSK/WPA2-PSK key and i haven't got one on my home hub.
If you are connecting through a standard ethernet cable you should not be getting this question. However, if you are trying to connect through wifi it is best to check your router/hub to make sure there is no preset factory wep or wpa key
I’m happy to assist further over the phone at https://www.6ya.com/expert/pete_c82bc0866827d502
I got new laptop and i want to conect with wireles but is asking for security key which i dont know where to check to find it. How can i do it/
All Linksys routers have a built-in web-based setup page that allows the user to customize settings and set up advanced properties.
NOTE: Before accessing the router’s web-based setup page, make sure the router is powered on and the computer is wired to one of the Ethernet ports on the router (1, 2, 3 or 4 ).
Accessing the Router’s Web-Based Setup Page
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router’s password ("admin" is the default password), then click OK.
To setup or SEE the WPA Wireless Security on your Linksys router, follow the steps below:
Setting-Up the Wireless Router to Use WPA
Step 1:
Access the router’s web-based setup page. For instructions, see above
Step 2:
When the router’s web-based, setup page appears, click Wireless and select Wireless Security.
Step 3:
Select WPA Personal under the Security Mode drop-down menu.
NOTE: IF YOU ARE JUST CHECKING ON THE PASSWORD NO NEED TO GO ON JUST TAKE NOTE OF THE WPA SHARED KEY AND USE IT IN YOUR LAPTOP WHEN ASKED OF THE PASSKEY
Step 4:
Select TKIP on WPA Algorithms.
Step 5:
Enter your desired WPA Key on the WPA Shared Key field such as “MySecretKey.” This will serve as your network key whenever you connect to your wireless network.
NOTE: Do not give this key to anyone. This key will secure your wireless network. Leave Group Key Renewal to 3600 seconds
Step 6:
Click 3695-017.png.
If you need further assistance please do not hesitate to contact me....GOOD LUCK!!!
25helpful
4answers
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
