Question about Compaq NC6000 Notebook
Compaq nc6000 notebook?
I recently installed a new 80 gig hd on this unit. I have been having nothing but problems it will only turn on sometimes and when it doesn't turn on the battery light will flash orange and the fan will start then stop? When it does turn on it freezes up after a short amount of time and sometimes just shuts off? Could this be because the ram was knocked loose when the new hard drive was installed? If so how the heck do i get at the ram?
  • lzachs Dec 20, 2007
    The fan will start, the blue light turns on, the battery light will flash orange and then it turns off completly. Only takes a few seconds. The battery is of poor quality, so have tried to start with or without it inserted, and also quickly insert battery directly at start, but now go.
Now a chineese had found out what is wrong. You have to resold a part on backside of the motherbord - Google on NC6000 MAX1987 and you will find a solosion.
Posted on Dec 09, 2007
That's ********. You don't need a new board. Just use a heat gun to resolder the MAX1987 CPU volt-chip back on the mainboard. It does not appear to be unstuck, but after heating it up and pressing it onto the mainboard the laptop will work.
Posted on Jul 06, 2008
Hello All solution!
i have a nc6000. i have a problem from it.
it can't start by press power button. When i push keyboard on the side of CUP it can star, but when i pull out it blank screen.
how to resolve it ?
please help me.
thank all your idea.
good luck?
Posted on Jul 01, 2008
I tried the Chinese solution. Strip right down to the mother board. Then reheat / re-solder 48 connections on IC MAX1987. They are very fine, so use a very fine point solder iron. IC MAX1987 is located on underside of the CPU chip. At the same time I cleaned fluff from copper fins of the CPU cooler.
Now the system runs much cooler and with no startup problems. Thanx RoF2000 for bringing the solution.
Posted on Dec 23, 2007
The ram is under the keyboard. There's 2 keyboard screws on the base and then release the 4 plastic slides at the top of the keyboard. The ram can then be found under a metal cover at the centre.
Just started having the same problems and re-seating the ram didn't fix mine.
Posted on Nov 24, 2007
  • 95 Answers
The problem is with the motherboard and unfortunatly will require a new board. This is a problem that has started appearing with great regularity with this unit in the past couple of months. Everyone is working on a way to fix it and no-one has a solution other than replace the motherboard
Posted on Nov 19, 2007
Driver display hp compaq nc6000 win98se
You can download the video and device drivers from the Compaq/HP WEBsupport/download page. Make sure you select your model laptop and the Windowsdrivers you require and install them. Click on this link to download thedrivers: -
May 09, 2012 | HP Compaq nc6000 Notebook
Starting problem
Starting problem Answer hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan... (More) hi i have a HP compaq nc6000 laptop, and when i try to start it up all i get is noise of fan starting up with one glowing orange light next to a lightning bolt like symbol. IWhen I turn ON my laptop first time HP Compaq nc6000, sometimes the orange LED will just light up and nothing happens, sometimes when I get lucky I will be able to goto Windows. when start work properly.
Jan 31, 2010 | HP Compaq nc6000 Notebook
Windows black
my hpcompac nc6000 doesnot pick up the fan rolls but no display on the sreen
Oct 08, 2009 | HP Compaq nc6000 Notebook
Compaq presario v2414NR, HD acting weird.
They probably never updated the bios, and it's still looking for the old drive, if you get into the bios, you can remove that drive that it's searching for and then make sure that the new drive is being recognised at the 0 position, not 1 but zero, if that doesn't fix it we can go further but that mnmay be the problem, also go into your device manager and make sure you remove the old drive if it's still showing that it is in there. Just uninstall it and restart. the cmos settings should also be cleared by removing the plug and poping out the battery, on the motherboard, it looks like a quarter, it may stll have the old settings stoed in there Good luck, and let us know if it worked
Mar 18, 2009 | Toshiba MK8025GAS 80 GB Hard Drive
Drivers for vga
If Vista does not like your video, this means that your installing Vista on a computer that is not compatible with running Windows Vista. Either go back to XP or buy a new Graphics card from walmart for 80.00. This will solve your problems.
Mar 05, 2009 | HP Compaq nc6000 Notebook
No usb
If your USB ports are installed correctly and enabled in BIOS, you will see Universal Bus Controller list in the the Device Manager. Double-click your USB in the Device Manager and a dialog box will appear. Click on the driver tab and update the driver. To get to Device Manager right-click on My Computer>click on Hardware>Device Manager. If your computer has a built-in USB device and does not detect the device through the Device Manager, confirm that the USB is enabled in the computers BIOS and that the BIOS supprts USB devices.
Dec 29, 2008 | HP Compaq nc6000 Notebook
Screen is complete blackout when I turn on my hp compaq c6000
You either have a screen that has gone and needs to be replaced or a cheaper fix and usually a more likely one is that the inverter in the screen has gone out. The inverter is quite cheap, around $34.00. Try it
Dec 04, 2008 | HP Compaq nc6000 Notebook
Frustrating Keyboard Malfunction (HP Compaq NC6000)
please tell the solution of this problem of keyboard
hp nc6000 mobile technology
Oct 22, 2008 | HP Compaq nc6000 Notebook
Compaq NC6000 Notebook Logo
1,619 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
