Question about Canon imageRUNNER 5000 Copier
I have a Canon imagerunner 5000 copier and i replaced the toner about a month ago and whenever i copy alot of copies at one time, it puts clear streaks in the middle of my copies and i can't read half of what it says. What could be the problem and how would i fix it?
  • 149 Answers
The first thing to try when experiencing these types of problems on this machine is to clean what are called the 'corona wires'. There are 3 sets of corona wires on the machine. The easiest set to see are on beside the transport bed. Open the front door then rack down the green handle and pull the unit towards you. If you look down and just right centre you will see a metalic unit running from the front to the back of the assembly with many wires running diagonally across the unit. Inside this unit is 2 very thin copper wires which can become dirty to the point of needing replacement. You can remove the unit and blow out the dust and waste toner but if you try and clean the very thin wire with a brush or alcohol be very very careful - you may well snap one and replacing it will be almost impossible if you have never done it before. You can by a new unit though. The other two sets are hidden by the front cover above the unit you pulled out but you would really need the service manual to remove them safely.
However, you can perform a wire cleaning procedure as a user and hopefully that will help by pressing the head key (head shpe symbol with a star inside) and then the 'adjustment and cleaning' then select 'clean wires' then the machine will move cleaning pads on each of these assemblies over the thin wires several times and ifthey are not overly dirty, that may well be the solution. Perform this procedure a few times. Good Luck
Posted on Jul 16, 2009
Ir5000 error code 000005-000 how do i clear it
Whenever you have replaced the fixing web, be sure to set '0' to
the following in service mode:
COPIER>COUNTER>MISC>FIX-WEB
COPIER>COUNTER>DRBL-1>FIX-WEB.
do not clear the limit,
Jan 16, 2014 | Canon imageRUNNER 5000 Copier
Our small office purchased a Canon Imagerunner 2000/1600 copier 4 years ago. Since our last service call, when the drum was changed and the machine was cleaned, we then ran less than 2000 copies. The...
When your drum was replaced did they put in a new drum assy or just replace the drum cylinder? I would purchase a new drum because these are one of the chepest to buy, around $ 80.00. They have a 6 month warranty and around 20,000 copies. I would replace the drum to see if that solves the problem. Before doing that, pull off the left side bypass assy. It is easily removed without tools. You should be able to see the drum and see if the drum is clean. If not, then replace the drum unit assy. Are you using only Canon toner, no other kind of brand will work. Generics should work but they are usually not as good a quality. The volume is very low and that should not be an issue. I believe its suppossed to handle 10,000 copies per month. Cleaning the glass top and below may help. The mirrors should also be cleaned as well. Good luck.
Dec 01, 2010 | Canon imageRUNNER 2000 Copier
ImageRUNNER 5000 Copier: I own a Ir 5000 and i just started getting "tire t...
Try to clean corona wires, pick up, feed and separation rollers, check drum cleaning blade and fixing assy.If the tracks are white, check also the toner unit
May 17, 2010 | Canon imageRUNNER 5000 Copier
Printing too many pages
try this touch add functions key then printer settings one option should be number of copies make sure it is set at 1
Jan 21, 2009 | Canon imageRUNNER 5000 Copier
Canon imageRunner 5055 copying in landscape instead of portrait
Double check paper orientation when you put paper into the feeder and how the paper is loaded.
The orientation of the page in the feeder and the page in the drawer should match.
Dec 16, 2008 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 5000 Copier Problem
The specks and dots are caused by the Primary Corona wire not creating a good enough charge to the drum. If you swing open the toner hopper assy, carefully release and remove the Primary Corona and clean it with an eraser pencil all should be well for awhile. Very carefully clean the very thin gold plated wires below the silver grid wire. These will break very easily. If you've not had the whole assy replaced for over 300,000 copies or so you may want to purchase a new one for around $130. The old one could be used for a back-up if you should ever break the charge wires. Hope this helps.
Feb 11, 2008 | Canon imageRUNNER 5000 Copier
Having trouble replacing waste toner receptacle on Canon imageRunner 3750
If the copier indicated to empty the waste toner you will have to reset in the counter in service mode. Press the additional functions key, the 2 & 8 keys at the same time, then the additional function key again. This should get you into service mode. If not depress the reset key and try again. Once there at the top right you will see counter. Depress it then you should see a menu and depress MISC. Depress WST-TNR, then depress "C" on keypad. Counter should go to all 0's. I think that the waste toner message displays at 250,000 copies made.
Jan 07, 2008 | Canon imageRUNNER 5000 Copier
Canon Imagerunner c3200 copier problem
Sound to me like a drum problem, try replacing it and it should work after u do..
Nov 28, 2007 | Canon imageRUNNER C3200 Color Printer
Canon imageRUNNER 5000 Copier Logo
142 people viewed this question
old marine
old marine
