Wall connector with cable rj45 wall and computer plug dont give any signal from router to computer. cable AWM E141772 extrending co 20251 60degrees 150V aWG26/8C
  • 565 Answers
Did it work before? Is this a new install? Try replacing the cable with a known to be good one. You may have used a "crossover" cable by accident, in which case it won't work at all. You need a "patch" cable. Sometimes the wires connected inside the wall jack can get loose. Pull the wall jack and inspect the wire connections. Use a small screwdriver to push the wires into the slots if any look loose.
It's possible that the network adapter (NIC) drivers are corrupt. Check "device manager" to re-install the driver. Also, the router may be misconfigured.
Sometimes this problem can be solved by shutting down the computer, then pulling the power cable on the router and let it sit unpowered for a minute or so. Then re- power up the router. Once the lights are green, boot the computer and it should come up.
Posted on Jul 16, 2009
Engenius eoc3220-w outdoor access bridge set-up
The POE should have a balun/power supply. You plug a data cable with RJ45 connectors into the power injector and that will go to the access point. You will need either a cable running out to that or you will need the antenna (send and receive side) to get the signal there wirelessly. If you use this option the you will get up to two miles that you can shoot the signal. You will need a router to send the signal. If you give me a complete list of what you have from Engenious I can map this out for you.
Apr 20, 2014 | Computers & Internet
We just bought an aspire one acer laptop. Trying to conect to a netgear router. Help!?
If you are trying to connect the computer to the router with a cable the above diagram should help to explain the simple broadband signal path from the Ethernet or telephone wall socket, to the router and from the router to the computer's RJ45/Ethernet port. Once the computer is connected to the router by a cable is connected to a telephone wall socket or a ERJ45/Ethernet wall socket that has a 'always on' broadband internet signal coming into it, nothing else is required -> launch the Web Browser.
If you are connecting wirelessly the wall socket to the router part of the setup is the same but no cable is required between the router and the computer.
Enable the wireless function in your netbook, click on the image of two computers bottom right near the clock -> view available networks/connect to network -> click on the appropriate Netgear router signal -> connect -> launch the Web Browser.
Nov 26, 2011 | Acer Aspire One PC Notebook
I have a (like) phone chord and can't find where to put the other end. We have it plugged into the back of the router, need to know where to plug the other end.
Hi
It depends on which country you are in.
It depends what Broadband wiring setup you have.
It depends which type of cable you are talking about (see images 1 and 2 below)
In some countries, the RJ11 to RJ11 cable goes from this device into the phone Socket of an ADSL filter. One RJ45 to RJ45 cable goes from the Router into the Ethernet Socket of the ADSL Filter. Another RJ45 to RJ45 cable goes from the Router to the Computer. The ADSL Filter then goes into the Phone socket in the wall.
You need an ADSL Filter in every Phone Socket that has a telecommunications device attached to it (Fax Machines, Answering Machines, TV Set Top Boxes, games Consoles etc.). The ADSL filter separates Telehone, Voice & Fax Data traffic from Broadband traffic and allows all to share the same phone line with out conflict.
See Network Diagram below.
In some countiries or wiring setups, the RJ45 to RJ45 cable form the Router to the Wall does not need to go via the Phone Socket and can go directly into its own dedicated Ethernet Wall Socket.
If this answer helps you, please take the time to rate it. This helps answerers better understand the needs and the point of view of the asker and helps us explore the best ways to provide useful, high quality answers.
If you need further help, please feel free to post another question or add a comment to this question.
Thanks for using FixYa
IMAGE 1: RJ11 to RJ11 or ADSL MODEM or BROADBAND or TELECOMS or TELEPHONE Cable
virtual_a_4.jpgIMAGE 2: RJ45 to RJ45 or CAT5E or LAN or ETHERNET Cable
DIAGRAM 1: Typical UK Home Broadband Network Diagram
Aug 30, 2011 | Linksys Wireless-G Broadband Router
I do not know what type of cable and hoe to hook to pc
Most modern computers have a Network Interface Card (NIC) that used an industry standard RJ45 network jack (8 wire connection similar to a telephone RJ11 connector)
Most people now have broadband service (Cable Modem or DSL Modem) that has RJ45 connections. you also may have a Router between the computer and the Modem to share that internet connection with other computers. The router will also have RJ45 connections. Routers can also be wireless, and you can connect via 802.11 A/B/G/N wireless connection if your computer has an 802.11 standard wireless card.
So, once you detail the brand and model computer and the type fo network conenction/equipment you have, I can give more detailed answers.
Jul 25, 2011 | Computers & Internet
WHERE TO PUT THE WIRES ONE IS A DATA CABLE TH OTHER IS A ETHERNET CABLE?
I dont understand the question. Usually connections are very self explanatory because sizes of plugins are unique.
An ethernet cable has an rj45 connector and can only plugin to an rj45 connector.
Usb have 4 or 5 type connectors but they are unique to them also.
Personally I never use the USB connector cable though sometimes you may have to if the modem or router doesnt seem to work with the ethernet cable.
Lay people that have no idea how all this modem router stuff works should probably follow the directions for setup using the USB cable.
Apr 01, 2010 | Arris High Speed DSL Modem
How do i hook up my belkin f5d7230-4 router to hughes net internet when there is only one ethernet port?
Connect that one port to your Belkin WAN (Internet)connector (Yellow Port). The other ports go to other computers, to their Broadband RJ45 connectors.
Here's from the manual:
1. Unplug your existing modem’s power supply.
Find the cable connecting your modem and computer.
Unplug it from the modem and plug it into the gray port
on the Belkin Router.
If you are replacing an existing router, find the cable
connecting the computer and old router. Disconnect it from
the old router and plug it into the gray port on the new router
2. Connect the new cable (provided in the box) to the yellow
port on the Router. Plug the other end into the modem.
G WIRELESS ROUTER Quick Installation Guide
3. Plug in your modem’s power supply. Wait 60 seconds for the
modem to start up.
Plug the Router’s power supply into a wall outlet, and the
other end into the black port on the Belkin Router.
As the Router wakes up, lights will come on; recheck your
connections if the “power” and one of the “wired” lights
are not lit up in green after 20 seconds.
4. Locate the CD in this guide and insert it into your computer
The Setup Assistant should appear automatically.
If it doesn’t, open the CD in My Computer (Windows®)
or the Finder (Mac OS® X) and double-click on the
“Setup Assistant” icon
Nov 15, 2009 | Belkin (F5D7230-4) Router (587009)
How do i hook the router up
The router has several connections on the back, there's the Power (goes to AC Adapter), an Input RJ45 that is connected by RJ45 cable to the Cable/DSL modem, and several other connectors that can be connected to different computer Network Inputs. That's about it.
Oct 15, 2009 | 2wire (1000-400108-001) Router
Router with RJ45 cable port available
Nowadays most routers come with RJ45 connectors. That is a connector for network cable.
You might be talking about a serial port, found on many security systems.
If you want to connect the security system, you need a serial cable to connect the security system with your computer, and thru a specialized software (more certain provided by the security equipment, be able to perform the task you have in mind.
If this answer helps please don't forget to rate it
Jun 14, 2009 | 3Com Router Cable E1 1200HM RJ45 20M...
Conecting netgar wpn824v2 to cable internet
what exactly do you plug directly in the wall? what kind of connector does it use? an 'f' connector on a coax cable or RJ45 (like a phone plug? if you are using a cable connection you have to have a modem for that to work. if you are using a Ethernet cable tied directly to a jack on the wall you'll have to be sure routers are allowed to connect. or register the router with your provider. be sure your wireless router is getting an address form the internet provider. with out more details i can't give you any more specifics.
-good luck-
Will
compressionconnector.com
Feb 19, 2009 | NetGear DG834G Router
Lacking correct cable
Simply an RJ45 cable connector. Routers are broadband and a dialup modem will not work. You need an ethernet card. They are cheap and easy to get. Steve
Jan 20, 2009 | Linksys WRT160N Wireless Router
Computers & Internet Logo
501 people viewed this question
David Payne
David Payne
