Emerson LC320EM2 32" LCD HD Television Logo
D
Doug Staetter Posted on Feb 09, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why doesn't it turn on?
Replaced burned fuse still no good
Electro Med Services
Level 3:
  • Emerson Master 6,694 Answers
  • Posted on Feb 09, 2016
Emerson Master
Level 3:
Answers
6694
Questions
Helped
1872070
Points
21433
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
1helpful
Samsung snh9151b no power all thermal fuse and ceramic fuse checked good but still no power
Faulty door switch, Open dryer door, see if light comes on inside the dryer. If it does the door switch is good. If it doesn’t try resetting the breaker. *( dryer bulbs burn out) you may want to replace the bulb if light doesn’t come on before proceeding forward)
The start switch is another cause. You will have to unplug the dryer to check continuity.
A broken drum belt.
Turn timer on a cycle and listen for it making a ticking sound. You should as the timer is the least likely to fail, from my experience.
1helpful
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 • Dryers
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
1helpful
Sharp micro doesn't heat
see this causes and fix it. God bless you
1helpful
Maytag microwave problem everything seemingly works but does not heat. Help
1helpful
Heating problem
Tail and panel light doesn't turn on. fuse keeps burning
You have a ground issue.Current from another circuit is running through the lights to get to ground. this causes them to burn out quickly.You need to do a real detailed visual check.A good component wiring diagram and component locator is a requirement here.
Have no tail lights for my 1992 grand marquis
Look for the easy things first. Could be one bulb was burned out and then the other burned out. Check the bulbs. If that doesn help look at the fuse block, probably under the dash on the driver side. If the fuse is the problem and if it blows when you put in a new one. look in the trunk at the tail light wires to see if they have been damaged or have come loose from the bulb sockets and are causing a short that blows the fuse. Repair or replace bulb sockets and or wires. Good luck.
Thanks for using FixYa.
Gaker
How to turn my bottom fog lights on in mercedes benz 300c
It's an electrical problem(you knew that)STEP1:check for voltage with a DVOM(voltage tester) at the fog light fuse,if current here switch is good,then problem is after fuse(make sure fuse is good). STEP2:check for power at the fog light ground (the fog light ground is bolt and nut that holds the unit up)if you get power at this end,make sure both light bulbs are good they might be a"series system"like x-mas lights if one burns out the other doesn"t work.
1helpful
3answers
Turn signals dont work
that could easily be just the fuse or the flasher unit. both are on the driver side under the dash
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
