Question about HP PhotoSmart 7350 InkJet Printer
Hp photosmart 7350-cannor print from emails or any
Hp photosmart 7350-cannot print from emails or any other source.
the ink cartridges are showing full, and thry trsvel back and forth, but no printing
    Novelist:
  • 109 Answers
As far as I remember, HP has the actual print nozzles built into the cartridge itself. Part of the reason their cartridges are so expensive. The trick that I use is fold a paper towel into quarters (fold in half. then fold in half the long way, again). This should now be about 1/4 the original size. You want it 4 layers thick so that the ink doesn't soak through and stain your counter top or whatever. Moisten the folded paper towel with warm water (doesn't need to be hot) and hold the print head part of the cartridge against the wet, warm towel. This will soften the ink and allow it to flow again. Check to make sure that there are ink marks on the towel where you had the head area placed. Dab the head on a dry part of the towel and replace it back into the printer and run the head cleaning utility. This has always solved my HP cartridge ink flow problems, uses less ink than the cleaning utility and keeps the heads from getting messy by not running the cleaning utility 4-5 times in a row.
Posted on Jul 15, 2009
    Genius:
  • 1,043 Answers
Your printhead is either clogged or not working. There should be a self cleaning program built in to the printer. Run this 4 or 5 times. If the unit still doesn't print you can either clean it yourself with Q-tips and isopropyl alcohol, or take it to your local HP printer repair center. If you printer is still under warranty I would advised having them check it.
Ink cartridge leaked inside HP photosmart 7350. How do I clean up the mess. I tried cleaning w/Q-Tip and alcohol but there's a lot of ink there. I probably have to clean it all before installing a...
Lots of Q-tips! I'd also use some small pieces of cotton cloth--be careful it doesn't leave strands of cloth in the bottom of the printer. I've had this happen and I just stuck with it until it got reasonably clean.
Oh--and warm water will work just fine. Most of the ink is water-soluble
Oct 26, 2011 | HP PhotoSmart 7350 InkJet Printer
On HP Photosmart 7960, which cartridge to replace when the blue and green look pale
The printer takes a tri-color cartridge and a black cartridge. So anytime there is an issue with color, replace the tri-color cartridge. As far as using compatible inks, you will not be able to use HP's software for ink levels with compatible inks. This feature will work only with HP ink cartridges.
Oct 23, 2011 | HP PhotoSmart 7350 InkJet Printer
I have an hp photoshop 7350 with an error message of "Print cartridge cradle is stuck". Can you help?
Good day!Try to see if there is a foreign object that made it stucked..try cleaning the ink in the carrier of your cartridges..
feel free to ask..
mastergani
Mar 26, 2010 | HP PhotoSmart 7350 InkJet Printer
How do you get your hp 7350 to print iron ons without lines in the photos?
Hello, here are a couple things to check.
1) Make sure your ink levels are good. Are you using original HP ink? Do not use refills.
2) Use a higher resolution when you go to print. (Click on Preferences to change the resolution. Look for Print Quality and select a minimum of 1200 DPI.)
Hope this helps.
Thanks for using Fixya.
Dec 09, 2009 | HP PhotoSmart 7350 InkJet Printer
My HP 7350 Prints Almost Nothing
You should try going into the properties and running the head cleaning that will fix ya right up
Aug 27, 2009 | HP PhotoSmart 7350 InkJet Printer
Need to clean hp photosmart 7350 cartridge head
You can try manual cleaning :
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Jan 15, 2009 | HP PhotoSmart 7350 InkJet Printer
Cartridge failed
I just purchased new hp cartidges and I still get error massage cartidge #57 needs to be replaced.
The line on the printing at the end or far right of the sentence (like the last 3 or 4 words are faded)
this is for hp 7550 photosmart
Oct 29, 2008 | HP PhotoSmart 7350 InkJet Printer
Printer cartridge cradle is stuck-hp photosmart 7350
I just had the same problem...and this is what I did to get it working...
Turn off your printer. Open the top. Push the cartridge thingie off to the side (if possible) and then take QTips and cleaned the silver bar the cartridge moves on. Got a lot of ink off of it.
Should run after that.
Dec 01, 2007 | HP PhotoSmart 7350 InkJet Printer
Print cartridge cradle struck
packing material like spanch remove form printer
Photos
Well, go to your local Ink Link franchise and ask them to clean the print heads on your cartridges, that should solve your problem. They should have the proper tools for that and you won't be wasting any more ink on software cleaning.
Nov 02, 2007 | HP PhotoSmart 7350 InkJet Printer
HP PhotoSmart 7350 InkJet Printer Logo
105 people viewed this question
Seeker5211
Seeker5211
