Question about OTC Transmission Output Shaft End Yoke Remover 7075
Leaking transmission fluid at output shaft. - OTC Transmission Output Shaft End Yoke Remover 7075
    Sergeant:
  • 302 Answers
You will have to drop the driveshaft at the rear, pull the yoke out of the tranny and then replace the rear seal in it.
Posted on Aug 14, 2009
Transmission on my 1983 delta 88 royal is leaking trans fluid while I am driving and when sitting still please help
Your are sure it is transmission fluid? If it is, there are probably seals on the shafts and on the pan that are leaking. This means removing parts like the transmission pan and replacing the gaskets. It could also be a main seal on one of the shafts that are on the engine and output side of the transmission. This is not a job for the average do it yourself person. It requires special tools.
Feb 07, 2017 | 1983 Oldsmobile Delta 88
My 95 mercury grand Marquis is leaking transmission fluid got the transmission fluid gasket replaced but it's still leaking what else could it be.
Hello , You could have a leak at the transmission dip stick tube o-ring, the front pump gasket, the torque converter seal , the transmission output shaft seal or the transmission oil cooler lines. I suggest you put the car on a lift to make it easier to see where the leak is coming from.
Nov 05, 2015 | Mercury Cars & Trucks
Front axle leak
hi,
if its leaking transmission fluid from one of the output shafts then it needs a seal there. find a reputable transmission shop in your area and take it in for an estimate, get two estimates..jm
Sep 25, 2013 | Saturn Cars & Trucks
Leaky transmission fluid
CHECK UNDER VECHICLE IF TRANSMISSION FLUID UNDER TRANSMISSION MORE LIKELY PAN GASKET LEAKING FLUID.IF FLUID HAS NOT BEEN CHANGED THE PAN GASKET GET HARD LEAKS FLUID.THATS IF YOU HAVE SLOW LEAK.IF YOU LOSING LOTS OF TRANSMISSION FLUID ITS .LEAKING AT TORQUE CONVERTER SHAFT SEAL.LEAKING AT COOLER LINES.CHECK COOLER LINES FROM RADIATOR TO UNDER CAR WHERE COOLER LINES GOES TO TRANSMISSION. AND CHECK LEAKS AT FRONT DRIVE SHAFT AXLES SEALS
Jan 25, 2011 | 2001 Saab 9-3
replace the seal. can be 1 of 2 output shaft seals or the torque converter seal... pray its not the torque seal as it takes about 5 hrs for an experienced mechanic :)
it could also be a transmission cooling line. this is not so bad to replace but the quick connects on the radiator can be a pain
May 15, 2010 | 1999 Ford Windstar
Red fluid leak. Large puddle formed overnight.
It could be a leaking trans pan, output shaft seal,or bad rack & pinion.
Nov 29, 2009 | 2003 Mercury Sable
Transmission fluid leaking back, 1988 Ford Bronco
your output seal on the tranny or input seal on your transfer case is bad. you have to pull your transfer case to tell. this is a pretty straight forward job. block wheels. put transfer case in neutral. drop front and rear drive lines.diconnect transfer case shift linkage. there is a short commponent connecting the trans to the transfer case. the bolt on either end face each other. remove the bolts to the transmission. the transfer case is heavier than it looks, i suggest getting help. pull back on the transfer case until it will drop down. it will pull out a bit because of the trans output shaft. replace what will probibly turn out to be the tranny output shaft seal and reassemble in reverse order.
Nov 06, 2009 | 1988 Ford Bronco II
My 1986 toyota cressida leaks transmistion fluid out bottom of car where drive line connects to transmisson the transmission is fine how do i fix it
Based on your description I am going to assume your leak is @ the rear of the transmission. If so, the leak would most likely be from the transmission output seal. To fix, you will have to remove the drive-shaft by unbolting it from the rear axle and sliding it rearward out of the transmission. Once the shaft is out of the way, you will need to remove the seal by inserting a pry bar or large screwdriver between the transmission output shaft and the seal lip and pop it out. Sometimes you may have to partially collapse the steel shell inward towards the center with a small chisel and hammer to releive the press fit. Drive the new seal into the bore and reinstall the driveshaft. Check fluid, road test and check for leaks after the road test.
Mar 25, 2009 | 1986 Toyota Cressida
Loosing oil on the output shaft of the transfer case, I changed the seal two times it's still leaking. I HAVE A LEAK AT THE INPUT SHAFT ON MY TRANSFER CASE. iS THERE A SEAL i COULD CHANGE, OR TRY A CAN OF...
90 percent of the time stop leak does not work. Usually the seal between the transmission and transfercase goes out and forces all the fluid into the transfercase and leaks out the rear seal. Or the tranfercase or transmission breather could be plugged.
Nov 03, 2008 | 1984 Ford F 150
4T60E Transmission output shaft movement
Hi Caarl
The lateral movement in the output shaft is normal and nothing to worry about.
Nov 01, 2008 | 1996 Buick Regal Olympic Gold
OTC Transmission Output Shaft End Yoke Remover 7075 Logo
98 people viewed this question
Top OTC Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you an OTC Measuring Tool and Sensor Expert? Answer questions, earn points and help others
