Question about HP LaserJet 2300N Printer
We have been able tø print from tray one on our HP 2300 just fine as long as there is paper in the tray. But suddenly it will only print from tray 1 if you pull tray 2 almost all the way out. Setting the print driver to print to tray 2 has no effect, but setting the printer to print manually will force the printjob to tray 1 - but you have to hit the check button for each page. What's going on?
  • bert_knabe Jul 20, 2009
    Tray 1 was set as first. It made no difference. The solution turned out to be turning the printer off and back on. Something I should have known to try first.
    President:
  • 3,085 Answers
In the paper handling menu on the printer set tray 1 as first.
Posted on Jul 15, 2009
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
Print 4.374 x 5.75 sharp 2300
Envelopes must be run from the bypass tray at the side of the machine. touch the paper trays on the touch screen. Set the bypass to envelope and com10. when you go to print, make sure the paper type is set to envelope under printer preferances.
Aug 03, 2012 | Sharp MX-2300N Color Copier
Problems with duplex printing
So you're saying it will only pull paper from tray 1? This is likely because there is some setting that makes it think the paper in the other tray is not "normal" -- either thick paper, or a different size, or recycled. Check the paper type and size settings in the printer's menu, and also check the settings in the print driver.
The other tray that you want to duplex from is capable of duplexing, right? On some printers you can only duplex from specific trays.
May 27, 2010 | HP LaserJet 2300 Printer
When i print it defaults to tray manual feed. i
change paper size setting on printer preferences on your pc
Apr 21, 2010 | HP Office Equipment & Supplies
Why my hp deskjet 2300 paper jam
please your printer in paper tray in out of paper and open the head couver and so the fixing in apaer. and printer is off and next time on and aply print is ok.
Oct 22, 2009 | HP DeskJet F380 All-In-One Printer
PRINTING FROM WRONG TRAY
Go to your Control Panel - Printers - [Select the LJ 2300 printer] - Properties setting on the PC and reset the default print tray to number 2
Sep 22, 2009 | HP LaserJet 2300 Printer
My HP LaserJet 4200 prints fine from tray 2, but will NOT print envelopes from tray 1. It WILL print on regular paper from tray 1, but will not print envelopes. What gives? I've already rebooted the
Are there settings on the control panel of your printer?
Is the tray 1 the MP tray? (The one that flips towards you)
If so, can you change the settings of the Tray 1 to Envelope on the control panel?
I hope this helps.
Aug 08, 2008 | HP LaserJet 4200 Printer
"No paper" or "Wrong paper size" warnings
Look in driver and see if the paper size is set to a different size. It could be that the driver says you want Letter size prints but you have A4 in the tray. The problem is most likely a driver setting that is set differently to what you need. Another option is to check that the paper feed guide is pushed up properly. If it is set too wide the machine may think it has a different sized paper in it.
Mar 04, 2007 | Konica Minolta magicolor 2300DL Laser...
HP LaserJet 2300N Printer Logo
100 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
