Question about Epson Stylus CX4600 All-In-One InkJet Printer
All lights flashing after changing ink cartridges
There is no paper jam, but I would like to check the new cartridges to be sure I removed all wrapping. Since it happened right after I changed cartridges, I think there is a high liklihood that this might be the proble.
However, I can't move the cartridge carrier into the open space so I can do this. The usual manual instructions do not work.
I cannot install the SSC Utility Service because it says I have a corrupted file.
  • mspkzink Jul 15, 2009
    Thanks, Steve. I really hope this is the problem as it sounds relatively to fix. However the more immediate problem is getting the cartridges out when the carrier does not respond...and I know not to force it. With all those lights flashing, nothing works!
    Problem Solver:
  • 10 Answers
I had this problem when I 1st changed my Black INK, this is how I solved it:-
Yes I did remove & check the cartridge, the film was off BUT I hadnt clicked it in all the way so it was saying I had no INK, Slightly release it & click tightly back in (hear a click).
Clean/Allign the printer nozzle with the printer tools and print a test page, should work fine.
if it does not, I think either a dud artridge (you get 1 offs) or wrong cartridge number maybe?
I hope i have helped you sole your problem :-)
Steve x
Posted on Jul 15, 2009
Red light under ink cartridge
The flashing light could indicate either a communication problem between one of your cartridges and the printer, a short in one of the cartridges, paper jam or the cartridge carrier has stalled. Please follow the steps below to fix the problem:
  1. Remove the sheets of paper from the feeder. Make sure there are no foreign objects or debris in the feeder.
  2. Open the printer cover and remove both the cartridges.
  3. While the cover is open, ensure there are no paper jams and the cartridge carrier is free from obstructions.
  4. Close the printer cover.
  5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first.
  7. Close the printer cover and check the light status.
  8. If light on printer is normal, open the printer cover and reinsert the other cartridge. Check the light status.
  9. Replace whichever cartridge is causing the light to flash with a new cartridge. You can also try to insert a different known working cartridge to determine if the other is faulty.
  10. Load some paper. Try to print a document again to verify that the problem is fixed.
Mar 19, 2012 | Lexmark X8350 All-In-One InkJet Printer
Lexmark x2600 i have ink and ervything my paper isnt jammed but everytime i try to print the button next to the X button keeps blinking orange
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 21, 2011 | Lexmark X2600 InkJet Printer
The orange paper light with the arrow keeps flashing and my ink cartridges wont come to the center
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
10. Load some paper. Try to print again.
Aug 18, 2011 | Lexmark X2670 All-In-One Printer
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My printer light is flashing and I am unable to print
Could be several options
First shut off and disconnect printer from pc and reboot without printer hooked up
once reboot hook it back up and turn on to see if windows found new hardware.check paper and ink
All else fails re-load printer driver
Jun 22, 2011 | Lexmark X1240 All-In-One InkJet Printer
My red lights are both flashing and printer will not responed
Both red lights flashing? One should be for paper jam and the other for low/insufficient ink. I presume this is a deskjet/injet printer. The combination of these two lights flashing usually indicates a more serious issue rather than just low ink or paper jam. It is indicative of incompatibility of ink cartridge. After a while some cartridges just could become incompatible with the machine. All things being equal (i.e. no paper jam issue) a replacement of your ink cartridge will resolve this issue. Just get brand new ink cartridge/cartridges. It is usually ok to replace only the one that has become incompatible. But the issue is you need to troubleshoot to determine. You may not have the resources to do this, so better to replace both or replace one-by-one.
Sep 15, 2009 | Epson Stylus Photo R260 InkJet Printer
Paper Jam Issue with the HP Deskjet 5440
Clean the contacts on the HP Cartridge. I've had the same error before and i switched it to a fresh new cartridge.. works fine ever since. THen i decided to switch back to the old cartridge, same error as you but i cleaned the contacts on the cartridge, works for a while but done after a week. Problem is that the ribbon circuit is rusted and the printer doesnt recognize the ink anymore.
Also make sure you both have the ink cartridges in place. Make sure it is seated properly inside.
hope this helps!
-levibit-
Mar 20, 2009 | HP Deskjet 5440 InkJet Photo Printer
Hp 845c orange light keeps flashing
When the orange light is flashing, either paper jam or ink problem is happening.Try unloaging & reloading the stack of paper in the main tray. Remove & reinsert ink cartridges in the printer. You may also clean the contacts of the cartridge and inside the product.
Mar 09, 2009 | HP DeskJet 845c Printer
Problem on a canon 3100
The Power Light Flashes Orange - Error Codes When an error occurs, the power light flashes orange. The number of orange flashes followed by a long green flash indicates the cause of the problem.
Two orange flashes: Out of paper, paper jam, or paper feed error
If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing.
Three orange flashes: Paper jam
If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing.
Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink
Replace the empty BJ tank and press the Resume button to continue printing.
Five orange flashes: BJ cartridge is not installed properly
Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely.
Six orange flashes: BJ cartridge (printhead) is not installed
Seven orange flashes: BJ cartridge (printhead) is defective
Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge.
Eight orange flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing.
The POWER light flashes orange and green alternately: Service error
A service error means the printer requires the attention of a qualified technician. Count the number of flashes. (You may be asked this information.)
Feb 02, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Printer ripair
The BJC 3000 will flash two different colored lights in a pattern to signal several different errors. From the documentation I have the two colors are orange and green, could those be the colors you see? At any rate here is the code: Two orange flashes: Out of paper, paper jam, or paper feed error. If no paper is loaded in the auto sheet feeder, or if the paper is not loaded correctly, set the paper correctly and press the Resume button on the printer to continue printing. Three orange flashes: Paper jam. If paper has jammed in the printer, carefully remove the jam and press the Resume button to continue printing. Four orange flashes: A tank inside the BJ cartridge (print head) is out of ink. Replace the empty BJ tank and press the Resume button to continue printing. Five orange flashes: BJ cartridge is not installed properly. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Six orange flashes: BJ cartridge (printhead) is not installed. Remove and reseat the cartridge correctly. Make sure the orange protective cap and tape have been removed. Make sure the blue locking lever is locked down securely. Seven orange flashes: BJ cartridge (printhead) is defective. Remove the BJ cartridge and check that the contacts on the cartridge and cartridge holder are clean. Make sure the orange protective cap and tape have been removed and reinstall the cartridge. If the error occurs again after you resume operation, you may need to replace the BJ cartridge. Eight orange flashes: Waste ink absorber almost full. The printer has a built-in waste ink absorber to hold the ink that is consumed during print head cleaning. This error indicates that the waste ink absorber is nearly full. Press the Resume button to skip the error so you can continue printing. The POWER light flashes orange and green alternately: Service error. A service error means the printer requires the attention of a qualified technician. If you have any more questions let us know otherwise please don't forget to rate this post.
Feb 20, 2007 | Canon BJC 3000 InkJet Printer
Epson Stylus CX4600 All-In-One InkJet Printer Logo
117 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
