Question about Emerson EWR20V4 DVD Recorder/VCR
Code I'm trying to hook up my dvd/vcr to my tv and lost the manual. I just need the code for the Emerson combo to my direct tv. Do you have the code on-hand?
  • 44 Answers
Re: code for the manual. manual doesn't have codes, nor does the customer support line. you need to call direct tv and ask for FUNAI CODES. that is the manufactor of this unit.
Posted on Jan 03, 2008
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
0 characters
3 Points
Gflight@yahoo.comdo you have the universal remote code for emerson dvd vcr combo ewd2202
Unversal remote setup codes for Emerson DVD/VCR combo are:
0456 [0458 0227]
Where the code is listed as [### ###] the first is for the DVD and the second is for the VCR. Otherwise just the one code operates both the DVD and the VCR.
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Aug 13, 2011 | Emerson EWD2202 DVD Player/VCR
I have a dvd/vcr combo and I need to know how to hook it up with a cable box and my new tv
need to know what type of tv, but ususally hook up your cable to your video in on the dvd/vcr and your video out from the vide/dvd to the tv
Nov 25, 2009 | Emerson EWR20V4 DVD Recorder/VCR
Connecting digital converter,Emerson VCR/DVD Combo,Sony SDTV
I think you may need an RF Modulator. This device will have connections for the DVD and TV and will have a channel 3/4 switch. Good luck to you.
May 15, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have a Emerson DVD/VCR combo player, have lost the directions, can't get it to work. EWD 2202
Go on Google and type in Emerson EWD2202 Owners Manual and look for the link tht shows it in a pDF file. Download it and then print it is you like
Jan 08, 2009 | Emerson EWD2202 DVD Player/VCR
I need the remote codes for an emerson dvd/vcr combo
i need the exact brand and model of the remote.
Dec 20, 2008 | Emerson EWR20V4 DVD Recorder/VCR
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Dish network
With the dish remote and do a code search as described in the remote manual and see if you can find it that way. If you go through the entire code search and none of them turn off the VCR/DVD combo, then there is nothing you can do, as those codes in the remote are all stored in the remote and they cannot be programed in. If you do not have a remote manual to set up the remote, to do a code search, simply go to the dishnetwork web site and search for it.
Sep 27, 2006 | Emerson EWD2004
Emerson EWR20V4 DVD Recorder/VCR Logo
250 people viewed this question
Top Emerson DVD & Blu-Ray Players Experts
Level 1 Expert
Are you an Emerson DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
