Question about Sony CDX-M800 CD Player
Inside buttons do not function at all.
This just started happening about 2 weeks ago. When I press the button on the unit or the remote to flip the cover down, none of the buttons are illuminated and none of them function whatsoever. With the front part still flipped, down I can use the remote just fine.
Any ideas on what the problem is?
  • ekornmeyer Nov 26, 2007
    No one?
  • Paul25_2 Dec 01, 2007
    my buttons dont work, face is flipped down but dont have remote to check so, where do i get this fixed and roughly how much
  • 111 Answers
The problem with you radio is the ribbon cable,this part connects the face to the main get it from
parts number is 168795211
you can try to replace it by you own,just becareful with the front button because they may fall dow when you open the face.
Posted on Dec 01, 2007
Remote has stopped functioning properly. Menu button, exit, cc, return, nor information buttons. How can I resolve this?
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Dec 18, 2014 | Televison & Video
Alarm remote not functioning properly, no valet switch.
i would think the button is activating the fob, or when you put new battery in is it the right way or you may have pushed something inside and its come lose off the board, it would need opening up and having a look, and testing the switch.
Jun 10, 2017 | Audiovox Prestige Code Alarm Remote Alarm...
Power button only one that won't turn power on
Have the remote tested either with a tester that most shops have or in a dark room with a digital camera the display will faintly flash when remote pointed at it and buttons pressed.
Also if button does not work (power) unplug the set for a while to see if it will reset. If the tester shows same problem--no working for power or have to press ******* buttons 99% chance something got spilled onto remote and got inside
Oct 24, 2012 | RCA TruFlat 27F520T 27" TV
Back box on bottom 1/2 of screen happened a year ago. Can' remember what to do. Help I have big Toshiba CZ32V51 with universal removte Phillips
Can u get into ur tv menu with the universal remote?If u can't tries it with the tv manual buttons look at on the botton of ur tv have manual button said menu.Press it go into the tv menu.Look inside the tv menu for functions like Close Caption like CC1,2,3 and Text 1,2,3 make sure all CC1,2,3 and Text 1,2,3 turn it to all off.Black square box will disapear.Can't do it in the tv manual button etheir.Try website like to buy the tv origial remote to close Close Captioning and Text 1,2,3 to all off.
Apr 15, 2011 | Toshiba CZ32V51 32" TV
Chk remote error keeps appearing and the dvd is slow to load. Worked 2 hours ago. Brand new batteries. any ideas?
Use this function to synchronize the codes for the
remote control and the main unit when there are other
Panasonic products close to your unit.
IF dsplay show RC1 or 2,3 try While pressing and holding ,enter button
press and hold the numbered
button , 1, or 2 or 3
corresponding to the code set in
step for more than 5 seconds to set
Jan 04, 2010 | Panasonic DMR-ES10 DVD Recorder
I have a new ESTR 200 that has been in a closet for a couple of years. Very little seems to function well. The presets will not hold if I turn the system off or if I turn to another function. Record...
I assume we're talking about the Element ESTR200...
A turntable will not work with this receiver unless the TT is already preamplified. No Phono Preamp in this unit.
From the manual...
Store a station
1. Press the FM/AM button on the front panel (or
the AM/FM button on the remote).
2. Select the station you want to store in memory
by the methods described above.
3. Press the MEMORY button on the remote
While "MEMORY" is glittering, press number
buttons on the remote for the station.
If the Memory indicator on the display turns off before you preset the station selection, Press Memory again.
Manual preset
1. Select the band wave by pressing FM/AM
2. Turn to a radio station(see "Manual tuning" on
page 8 in details).
3. Select a group (A- D) of preset stations. This
group will be displayed on the front panel.
For example: "A".
4. Press MEMORY on the remote control.
"MEMORY"will appear on the display.
5. While the word "MEM" appears, input your desired preset number (1-8 ) by using the numeric keys on the remote control to store the radio station. For example this number is "1", the station is stored as "A1".
A new setting can cover the former one.
This memory is kept before next reset.
Retrieving preset stations
1. Press FM/AM button on the front panel or the
remote control to select tuner mode.
2. Press A/B/C/D button on the front panel or the
remote control to select the group of preset stations that you require.
3. Press the numeric keys on the remote control to select the number of preset station that you require. Station selected is displayed on the front panel.
4. By the same way, you can select other stored
The remote control does not operate the unit.
-Another function is selected on the remote.
Press the correct function button.
-No batteries installed. Install the batteries before
using the remote.
Be sure "+" and "-" marks of each battery match the symbol on the inside of the remote battery compartment.
-The batteries are exhausted. Replace all batteries.
-The remote is not pointed at the remote control sensor on the main unit or there is an obstacle between the remote and the main unit.
-The remote control is too far away from the main
unit, move closer.
Dec 05, 2009 | Audio Players & Recorders
Our DVR jumps to the suggestions screen and we can't get back to the programs we've recorded unless we unplug the unit and let it reboot.
mwe71704 -
I saw a similar problem with a vcr and it's menu years ago. It turned out to be the remote. If you can operate the unit without using the remote, try that to see if the problem happens again. If not, the remote is the issue. You don't say if there were any factors that could be traced directly to the remote (like the jump happened when you pointed the remote at the unit or pressed a button). You might also have a button that is stuck.
You'll have to do some experimenting to see if the remote is the cause, but it might be worth it. If the unit can't be operated without the remote, reboot it with the remote pointing away from it. Then turn the remote towards the unit. then try some of the functions. If it jumps to the suggestion screen, note which button you had just pressed and repeat the entire process. If a particular button always causes the issue, that's the culprit. You may want to just use the unit as you have been, rebooting as necessary, but pay attention to what happens right before the jump to the suggestion screen.
Aug 07, 2009 | Directv (R10) DTV Receiver / 70-Hours...
Jensen VM9410 - Stopped Operating All Of A Sudden
Sound like to me you got a problem with the capcitor inside the unit, if its under warrenty it will need to be serviced. If its not I ould be checking capcitors inside to make sure there not bulging leaking or otherwisen ot wroking correctly.
Jun 24, 2009 | Jensen VM9410 Car DVD Player
Sony CDX-M800 CD Player Logo
123 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
