Question about Western Digital External USB 2.0 80 GB Hard Drive
Can not find the device when i plug the usb into my pc
Hi, could you help me on this probme?
when i plug WD 120GB usb into my pc, i could not see the device drive in my computer.
Thank You
  • 1 more comment
  • marty111 Dec 15, 2007
    plugged in and xp should see it but it will not show up despite windows saying device working properly.
  • PaturnOne Sep 15, 2008
    I ahve the same problem. with my 120gb
    My computer shows there are drives installed on the computer.
    However the drive itself will not show up.
    I am running Vista on an Acer computer sorry im not sure the model.
  • Anonymous Nov 29, 2008
    I see the drive on my system tabs and also in disc management but it doesn't show in the drive list at all. Driving me crazy.
  • 244 Answers
You need to used Disk Management, goto Start> Control Panel> Administrative Tools> Computer Management> Disk Management. Select volume/drive, if you found drive doesn't yet assign a drive letter, you need to assigned it by right click at the highlighted drive then assign drive letter then apply.
Finally, you will just use double click or right click explore inorder you to view the data inside your harddrive.
Please rate me SOLVED!
Posted on Nov 20, 2007
Diazphi,how can you recomend this solution when WesternDigital (the big mama of the monopols) doesn't provide an unified driver for plug-play recognition (plug&pray) and then the driver couldn't be apropiate installed when connecting the device to the respective port?. I've the same problem and no way to view trough the administrative tools because it doesn't registered in windows devices (It's no logic). At your position,and if you know how can be combined the files trough the windows directories in order to install manually the XP drivers and create the .inf additional file,so that's the point for us and then I'll greatly apreciate as well. Dan
Posted on Feb 04, 2008
I cannot get the computer to recognise the Maxtor device. I had it working 18 mths ago and have now just reconnected it. Not sure if I have all things plugged in correctly but can't find a diagram of...
The correct lead should be Y shaped and two of the limbs plug into two USB sockets on the PC, the third lead has a small jack which goes into the OneTouch. It should light up if it is getting power from the USB and there should be an icon showing for it in My Computer.
Aug 17, 2010 | Maxtor OneTouch 4 Mini 120GB External USB...
2 usb plugs which goes where??? maxtor 120gb external hardrive pn9nx2dc-500
You have what is call a USB POWER Y ADAPTER: this is designed to provide extra current to your USB HDD drive from a second PC USB port. Plug the end with two USB connectors to your PC/LAPTOP and the single-ended plug to your drive.
Hope it helps! Let me know how you go.
Dec 30, 2009 | Maxtor OneTouch III Mini Edition 120GB...
I have a 120gb usb after connecting it in pc it
then the problem must be with your 120gb usb. so i would request you to replace it with a new device. this should fix your issue.
Dec 08, 2009 | Computers & Internet
My usb ports are limited to 500mA each one and the WD external HD needs at least 1000mA. How can I solve that?
You might need to install a new USB card, one with 1000 mA, to provide the power necesary for your WD external drive. Check the WD manual to see whether there is a way to use two USB ports when jumpering them to see if you can provide the power yourself.
Also check the WD web site.
Jun 26, 2009 | Western Digital Passport 120GB External...
External USB Hard Disk is 120GB is not dected in winxp pc.
There are two possibilities:
The Mybook USB/ATA controller board is faulty.
In this case you can simply take apart the enclosure and mount the disk into a new enclosure. WD Mybooks are SATA, but double check the hard disk connector to ensure.
The hard disk inside is faulty.
In this case repair may be expensive. You need to locate a data recovery facility with a 'clean room' , the cost is usually more than $800.
If this happened after a power surge, then the problem is most likely a faulty controller board.
If instead you have dropped the hard disk it is possible an hard drive failure, in that case repair will be expensive.
A replacement enclosure will stfrom art about $20 on Ebay or Amazon, and must not necessarily be WD .
Check if your disk is Sata or PATA (IDE) before buying the enclosure.
Jan 14, 2009 | Western Digital 320GB MyBook External USB...
Hi,My Transcend T Sonic 840 digital Media Player is not detecting the USB cable.
If the device is not identified,
you insert the driver CD and install the driver.
Now unplug and plug in the USB cable.
Now your device will be identified and will be connected to the computer.
Jan 12, 2009 | Transcend USA 120GB Storejet 2.5" SATA -...
USB port cant regocnize my WD 500 gbyte hard disk
Just unistall all usb controllers one by one from the device manager and restart your computer and then plug the harddisk into the usb drive. Your hardisk will work
Jan 08, 2009 | Acer Veriton 7600GT PC Desktop
Cannot see WD 120 GB in my Computer
Sounds like the USB interface is working, but the physical drive is not. Remove the drive from it's external case, and try a different hard drive. If that works, your drive is the problem. If it still doesn't work, the USB to IDE interface is the issue.
Try mounting the original IDE drive internally, and see if you can read it there. If not, you'll need to send it to a data recovery center.
Sep 17, 2008 | Western Digital (WDXB1200BBRNN) 120 GB...
My PC is not recognizing my WD Passport 120GB USB external drive. I used just few days ago and connected the usb cable to my computer and the WD Passport drive and not recognized on my 2 laptop and 2 other...
I have the 80GB WD passport and it suddenly stopped working one day.  The unit lights up but nothing else.  Finally I cracked the case open and found, as I suspected, that the drive is simply a SATA laptop drive with a SATA-to-USB conversion card built in.  I suspected that the card was **** so I disconnected it and used a USB hard drive adapter ( and I can read/write to the drive just fine.  Best part is that the adapter I use has its own power supply so I'm not pulling juice through the USB cable for a SATA drive.
Even though mine "works" again I don't recommend these drives to anyone.  They're just not sturdy enough or well designed.
Sep 09, 2008 | Western Digital Passport WDXML800UE...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Western Digital External USB 2.0 80 GB Hard Drive Logo
879 people viewed this question
Top Western Digital Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
