Question about Holmes Products Dryers
Looking for replacement motor on a Holmes HASF1710
Red light keeps blinking
Hello, this is Ava with Think Crucial.
It looks like you may need to change your filters. It is advisable to change filters every 3-6 months for optimal use. When replacing your filters, make sure that the unit is turned off and unplugged from the power. Once filters are replaced, turn on your unit then press and hold the filter check indicator button for 3 seconds. The indicator light will blink 3 times and turn off, and reset the filter change timer.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Aug 24, 2014 | Holmes Products Air Purifiers
The fan just stopped working...
Take a look at the plug. If there is a little flap, open it. There is a fuse. Check it / replace it if it's blown....
Jun 23, 2014 | Holmes Products (HPF650MCU) Stand...
When bar light is on level 3 what does that mean holmes air purifier
There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air.
Ava B.
May 19, 2014 | Holmes Products HAP422-UC Air Purifier
Who do I contact for a defective fan?
Try to find a local electronic repair center maybe sears if you have one in your area or Google the brand on your computer for the authorized service center in your City
Oct 18, 2011 | Holmes Products HASF1710-UC Stand...
My fan is not rotating when I connected to plug. There is no burning smell or anything. How can I fix the problem? Thanks in advance
Hello.
I have a Holmes pedestal fan that does this every few years. I have had this fan for about 10 years.
Unplug the fan and remove the fan blade guard. The fan blade should spin easily when you tap the edge of the fan blades with your finger. If the blade barely moves and abruptly stops, the bearings are dirty and need to be cleaned and oiled with 10W non-detergent motor oil. A quick-fix is a tiny bit of WD-40 where the motor shaft (the rod that the fan blade is mounted on) meets the bearing (the part of the motor that the shaft spins on). To properly fix this, you must oil both the front and back motor bearings which requires removal of the motor housing.
If the fan blade spins easily and you are certain that the fan is getting power (try a different outlet) the motor may be bad. Likewise, if the fan blade will not move at all. I do not know if Holmes sells motors for these fans. Here is their online support website:
www.holmesproducts.com/Support.aspx
Good luck from Detroit, MI.
P.S.: Never turn a motor-operated appliance on for more than a second if you know it's not working. That will cook the motor windings.
Jun 12, 2011 | Holmes Products HASF1710-UC Stand...
We have two holmes fans and they both stopped working within the same week, we replaced the batteries and nothing and we tried to manually start them and nothing; any ideas>
mcdevito75 here, You say you changed the batteries in both fans, tried to spin the blades and no start., Double check battery install, try another set of batteries even new batteries from the store can be weak or even dead as batteries have shelf life of, not too long. Spin the fan blades as fast but as safe as possible by hand with the on /off switch off, and listen for any noise from the fan motor, a sraping sound, or whistle could mean a bad motor. Lastly, bring the fans to a Staples, they will be glad to test them, a Radio Shack also can test the fan motors.
Jul 28, 2010 | Holmes Products HAPF622R Floor / Box Fan
I am looking for one of these to buy... anyone know where I can find one? Holmes Products Halls HLS5000-U
you can try local hardware stores like target, walmart, walgreens, ace hardware. places like that. if not you can always call holmes themselves to order through customer service.
Mar 23, 2009 | Holmes Products Halls HLS5000-U Humidifier
Temperature control threshold too high
I have a solution. Let me buy it!! So you can replace it with something that works. I am looking for used
Holmes Heater ModelHFH5506 only and will pay top dollars.
Thanks,
Nov 22, 2008 | Holmes Products Holmes HFH5506-CN Heater...
Dryers Logo
46 people viewed this question
Top Holmes Products Dryers Experts
Darial Jr Lasaria
Darial Jr Lasaria
Jay Finke
Jay Finke
James Coghill
Are you a Holmes Products Dryer Expert? Answer questions, earn points and help others
