Question about Ricoh Office Equipment & Supplies
Hello: I started scanning some documents through the machine's feeder and suddenly it just stopped and now is stuck in processing mode. It won't let me stop the job, not even turn off the machine. Please advise
What do you mean, you can't turn off the machine? "red" button on front cover, or unplug it...if it doesn't turn off that way, then you really have a problem! maybe even a haunting!
Posted on Jul 17, 2009
Document feeder is not scanning the document but brings up a former scan
That is not possible. most likely is your PC not refreshing ? or you need to uninstall and reinstall the software
Mar 22, 2014 | Brother Any 4 Ink Mfc-5490cn Mfc5490cn...
Document feeder error message
did u guys ever use maginzes to scan documents with they will get jamed in there i would open it up cheak feeders closly ok thx nick
Feb 09, 2008 | Office Equipment & Supplies
PROCESS IN HOW TO CALIBRATE C253
utility /counter, details, stop 00 stop 01,(SERVICE MODE) Image processing adjustment select all colors run twice ensure the image units are toned up for the gradation adj. Now run stabilization once. Now you will run the following three times (Gradation, Resolution, and compression). each. you will press start machine will run and print out a chart place the chart on the big glass do not use the document feeder use your best paper no color paper!!!!! ensure the black square are up against the scale on the left side you can use 11 x 17 or 8.5 x 11 paper 11 x 17 will give extra color strip not used 8.5 x 11 must be landscape. press start. In the end you should have 12 print outs 3 from each process.
Gradation, Resolution, and compression. once done print out a demo page in user mode check it out.
Feb 23, 2013 | Konica Minolta Bizhub C253 With Document...
Canon imageclass D1120 printer says: feeder paper jam,
Hi Try this method
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
  1. Press b_in_add.gif(Settings/Registration) ? [Function Settings] ? [Common] ? [Scan Settings] ? [Feeder Jam Recovery Method].
  1. Select [From 1st Page] or [From Stopped Original] ? press [OK].
Details of each item are shown below.
[From 1st Page]: If a paper jam occurs in the feeder, scanning starts again from the first page of the document. [From Stopped Original]: If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
Jun 10, 2011 | Canon ImageCLASS D1120 All-In-One Laser...
Using a brother MFC-J415W printer, what are the steps in sending a fax?
How to fax :
1. Entering fax mode To enter fax mode press (Fax), and the key will glow green.
2. Sending a fax from the ADF (Automatic Document Feeder): Using the ADF to send your faxes is the easiest way. To cancel a fax in progress press Stop/Exit.
a. Make sure you are in Fax mode . b. Place your document face up in the ADF. c. Dial the fax number. d. Press Start.
The machine scans the pages into memory and then sends the document.
3. Sending a fax from the scanner glass : You can use the scanner glass to fax the pages of a book, or a single page at a time. The documents can be up to Letter or A4 size. Press Stop/Exit to cancel a fax in progress.
a. Make sure you are in Fax mode . b. Place your document face down on the scanner glass. c. Dial the fax number. d. Press Start.The machine starts scanning the first page.
For more detailed instructions, you can go directly to Section 4 - page 22 of the manual in Brother's site. Hope this helps.
Apr 14, 2011 | Office Equipment & Supplies
I havea mx310 but have lost the manual - how do i set up to scan photos?
You can download your manual from this site:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx310#BrochuresAndManuals
Solution: Setting scan methods for the button (Windows) - MX310
Scanning using the Operation Panel
You can scan documents using the operation panel.
Important
bullet.gifDo not disconnect or connect the USB cable while the machine is in use.
bullet.gifIn Windows XP, the program selection dialog box may open when you press the Color Start or Black Start button on the machine for the first time. In that case, select MP Navigator EX, then select Always use this program for this action and click 'OK'. From the next time, MP Navigator EX will start automatically regardless of the selected scan mode.
arrow.gifSelecting a Response to Commands from the Operation Panel
1. Place the document face-down on the platen.
2. Press the Scan button on the machine.
The machine enters Scan Mode.
3. Press the Color Start or Black Start button on the machine.
MP Navigator EX starts on the connected computer. Scan documents on the platen or ADF (Auto Document Feeder) using MP Navigator EX.
Trust this is helpful.
Dec 14, 2010 | Canon PIXMA MX310 All-In-One Printer
I have a Canon Image Runner 3230 which we also use to scan PDF files into our snap drive. When scanning a large job build, if the machine jams, the documents already scanned in the job build are lost. Is...
Hi mail. Let me tell you a workaround for this problem.First of all I understand every aspect of your question and problems as the document feeder for the ir 3220 is about the biggest piece of **** I've ever seen and I have been working on copiers since 1988.And when you use the "Universal "SEND" " function I also realize that for example if you have scanned a 500 page document and it jams at 499 you have to start all over again.That because the copier has established communication with the server directly during the "send" process and when an error {document paper jam} occurs, for whatever reason the error cannot be reconciled on the fly. BUT!!!!! :-) If you scan the same document(s) to the "Mailbox" function the copier can and will allow you to recover from such a mishap as the process you are conducting is all happening "on board" the device so if a jam or misfeed occurs in the document feeder during the scanning process the copier will tell you to put the stack of originals back in the feeder with page 1 on top.Then the copier will begin to feed the originals quickly merely to count the pages till it finds the the one it jammed on.Once it counts to the original it failed on it will resume the scanning process.THEN...... no matter how many failures have occurred during the process, once you are done the "SEND" function will appear as an option.At this point you will be viewing the "batches " of documents in the display because if it is a large document you will not have been able to put the entire bulk in the feeder at once.Now highlite all of the"files/batches" and hit EDIT. Under edit will be the "merge" option. Select merge and all the batches you have highlighted will be merged together into one big document.NOW selest SEND and designate the location you wish to send it to.Since the document in its entirety resides correctly in a "mailbox/hardrive" storage area it can be sent with no fear.I have many customers with this same difficulty and this has been a lifsaver. hope this help,and have a better day! :-)
Feb 10, 2010 | Canon imageRUNNER C3200 Copier
Feeder scanner stop after 1cm scan/fax
You need to clean the rollers inside the feed section, use an alcohol wipe.. or something like methylated spirits and a rag..
Oct 16, 2009 | Panasonic KX-FL611 Plain Paper Laser Fax
Canon D860 - I get a solid black line when I use paper feeder.
I'm pretty sure you might have solved this problem already, but this might help others.
Make sure that the platen glass is clean near the right side of the machine, where the document is scanned when going through the document scanner. Remember, when placing a document on the glass to copy it that way, you would place it on the glass on the left side of the machine. When scanning through the ADF, the scanning unit itself moves to the right side of glass and scans the document as it moves through.
We had the same issue and found out that there was a little spec of dirt on the glass. After cleaning it, the problem was solved.
Feb 03, 2009 | Canon ImageRUNNER 1670F Copier
355 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
