LG front load washing machine water leaks with heavy loads
  • 55 Answers
If your water is leaking with heavy loads, the first thing you want to check is the gasket (door boot) attached to the tub. Look for holes or rips in the bellows part(where the water settles) and around where it contacts the door. Any nicks or holes will cause leakage. Also, check the glass dome on the door towards the bottom. If it has dirt or hair buildup on it, it will leak with any pressure on the door.
Posted on Jul 15, 2009
5 Suggested Answers
  • 1314 Answers
SOURCE: kitchenaid front loading washing machine
check your drain hose see if its too low lower than the tub or too far down in the drain as this will cause a siphon action
Posted on Mar 02, 2008
  • 15 Answers
SOURCE: lg front load washer leaking from bottom of machine
I just fixed this problem - there is a rubber hose that hooks the bottom of the drum to the drain and recycle pumps - it is ribbed and it developed a hole. To confirm and repair (repair can be done from the front of the machine)
  1. Unplug the machine.
  2. Drain whatever water you can from the machine using the stoppered hose behind the bottom left panel
  3. Unscrew the visible screw holding the plastic in place near the drain hose and filter
  4. If you can pull the plastic recessed piece out, there is one screw visible behind it - unswcrew this. If you cannot pull it out now, you should be able to get it after you remove the screws in step 10
  5. Pull out the detergent drawer (push in the middle back "botton" to release the drawer to pull out fully)
  6. Unscrew two screws in the drawer area.
  7. Pull the top of the electronics assembly away from the machine and lift the assembly out (place on top of the machine or hook it out of the way)
  8. Open the door and remove the spring loaded wire around the door seal (be careful as the seal can be torn)
  9. Pull the seal away from the metal front panel, then close the door
  10. Remove four screws at the top of the front panel (that were behind the eletronics assembly) - If you already have removed the screw from step 4, proceed, otherwise lean the top of front panel out and pop the plastic out, hold panel in place and remove that bottom screw from step 4.
  11. Lift front panel about two inches, swing the entire front panel to the right and set against something - You should now be able to see inside the machine.
  12. There is a black hose right in the middle - when I squeezed mine a little, I could see where the water was dripping out from the bottom.
  13. There are three clamps - two that can be squeezed with pliers and removed, one that has to be unscrewed (phillips head screw - it is a bit blind as the screw faces the back of the machine) - Once I got mine off - I could see the hole.
  14. Order replacement and reassmble in the opposite order
Posted on Apr 18, 2009
localwonder
  • 6784 Answers
SOURCE: LG WM2355C water leaking under machine after washing finished.
HI, you will want to Inspect the water supply connections. this is a good spot to check first. there may be a loose connection here, causing the leakage. Next, Inspect the drain hose. Check to make sure that it is tightly connected to the drain pump. replace if needed. Last. Inspect outer tub/basket for cracks or corrosion.
You will find the issue in one or all of the above stated check points.
Posted on Jul 23, 2009
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
Lg front load washer drain hose out ot machine leaking
IF it is leaking on the floor, the hose may be damaged or cracked. Since you did not post the model number, it is hard to say what the next step is.
Mar 18, 2018 | LG Washing Machines
Why is my brand new front loading lg washing machine leaking water from the bottom?
Maybe the door gasket is leaking. Maybe an internal connection is leaking.
Feb 25, 2018 | LG Washing Machines
Lg 1370 slight clean water leak on left side of dispenser draw sometimes? solutions please ,
Usually a sign that you are using too much detergent. Pull the drawer out completely and clean it out. The drawer and the casing
May 28, 2014 | LG WM-2277HW Front Load Washer
LG front load washer is leaking underneath the front left corner, the display code is FE.
Why don't you simply find out what the FE code is alluding to? Go to web site or do a google search and then you can check for the issue further.
Sep 17, 2017 | LG WM2487H Front Load Washer
I have a LG front load washer seem to leaking front area. Hoses OK Need o see what causes it to leak
you will need to narrow down where the water is leaking from. under the door...? behind the bottom drain door..? underneath machine..? behind machine..? leaks can be found in many areas.
May 16, 2011 | LG WM-2277HW Front Load Washer
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Jul 23, 2009 | LG WM2277H Front Load Washer
LG Washing Machine stops spinning in mid cycle
IE:
• Water supply is not adequate in
area.
• Water supply taps are not
completely open.
• Water inlet hose is bent.
• The filter of the inlet hose clogged.
Solution:
Check another tap in the house.
Fully open tap.
Straighten hose.
Check the filter of the inlet hose.
UE:
• Load is too small.
• Load is out of balance.
• The appliance has an imbalance
detection and correction system. If
individual heavy articles are loaded
(bath mat, bath robe, etc.) and the
imbalance is too great, after several
attempts to restart the spin cycle the
machine will stop and the error code
will be displayed.
Solution:
Add 1 or 2 similar items to help
balance the load.
Rearrange load to allow proper
spinning.
UE:
Apr 27, 2009 | LG WM2487H Front Load Washer
Water leaking after i have installed a new drain pump in LG
Obviously you need to find the leak and repair it...duh
Mar 12, 2009 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
1,219 people viewed this question
Top Washing Machines Experts
