Why won't the buzzer alarm sound at the end of a drying cycle? I've replaced the buzzer with still no sound.
Search Results
Why does my Kenmore dryer model 417.94802/94862 end ...
www.shopyourway.com > Manage My Life > Questions
Why does my Kenmore dryer model 417.94802/94862 end of cycle alarm go off ...washer/dryer unit I do see that it is normal for the end of cycle buzzer to go off ...Why won't my Kenmore dryer model 110.86872100 shut off at the end of the ...
Why won't the buzzer shut off on my Kenmore 80 Series ...
The buzzer won't stop buzzing after the load is complete. ... or turn on the timer and the dryer will start just by selecting a cycle and closing the door. ... The dryer should continue to run and at the end the buzzer should only stay on as long as ...
FIXED The Buzzer At The End Of The Dryer Cycle Comes On But Won't ...
www.applianceblog.com/.../21739-The-Buzzer-At-The-End-Of-The-Dry...
Dec 11, 2010 - 10 posts - 2 authors
My maytag dryer has operated wonderfully until today. All of a sudden the buzzer that goes on at the end of the drying will go on but will not shut off unless I open the door.... To test it: by-pass the push-to-start switch and see if when you turn the timer on and close the door, the ...
VERY annoying dryer End of Cycle Signal
Jun 29, 2012
Maytag DE8410 electric dryer - End of cycle buzzer stuck ...
Mar 27, 2011
Kenmore 80 series, buzzer won't shut off
Sep 10, 2005
More results from www.applianceblog.com
Turn off and unplug the dryer. Since you need to remove the front panels and expose the electrical wiring of the dryer's buzzer you should turn the dryer off and then unplug the machine to avoid shocks. Once the dryer has been unplugged, turn its dial to the "on" setting to make sure the dryer is completely powered down.
Locate the buzzer. The best way to locate the dryer's buzzer is to check the machine's schematic or manual. The buzzer is usually located behind the front panel of the machine. In some cases the buzzer is located behind the dryer's back panel. Dryer buzzers are generally small black boxes that are wired to the timing device.
Pull the buzzer's wires. The most simple way to deal with a buzzer is to pull the wires that run into the buzzer. The wires should pull free with a firm but careful tug. Once you've disconnected the wires from the buzzer simply run a good amount of electrical tape over the ends so that no live wires are exposed. If you want to get the wires out of the way, tape the wrapped wires to the top or side of the dryer panels.
Test the machine. Once you've yanked and taped the buzzer's wires, plug the dryer back in and turn the machine on to test the buzzer. If the machine still buzzes at the end of the cycle then you removed the wrong wires. However, chances are that the machine will finish its drying with a quiet whimper instead of a loud buzz.
It says Claude answered my question but I am having difficulty finding the answer. What am I missing?
