Question about Bladez 320-5M/25 Clutch Belt for BladeZ Moby
How do I change the clutch belt on my BladeZ Moby motorized foot scooter (25CC)? Do you have any instruciton manual type pictures as I can't download any from the manufacturer?
There are 4 bolts that hold the engine in place on the left side of scooter when your looking straight towards the bars
then there are 3 more bolts below those tak em all all be carefull not to loose the small spacers behind the large ons there hard to notice but they are there
slip you belt over both pulleys and reasemble using the 2adjustment screws that attach to the big pulley on bottom until the belt is 110 & straight and has a little bit of play abotu half in or so should be fine you dont wat too much other wise it will break if you hit a bump or whatever an if its too loose wellit will slip as you might know
Posted on Aug 25, 2009
Walking on tread mill is jerky. almost like some one keeps putting the break on
Hi There, have you lubricated the deck lately? does the belt glide easily over the deck with your foot pushing it and the power to the treadmill off? If the belt glides easily with your foot, but not when powered, you're motor control board could be about to fail. capacitors routinely go bad on these controllers over the years. You can find further help by emailing gregATbuyfitnessrepairpartsDOTcom
good luck!!
Feb 07, 2016 | Bladez Ion 9.9 Fold-up Treadmill
Manual for 24 hp 42 craftsman - Diagram and How to change the drive belt?
Remember this,there is a belt diagram under the left foot rest. It will show you how the belt is rigged onto the pulleys. In changing this belt you will have to pull the clutch assembly,from beneath the motor. Only one bolt holds this assembly to the motor's vertical shaft.Once removed,install the belt onto the pulleys. Then slip the belt onto the clutch assembly's pulley and lift straight up,align the key way with the key and slip on the clutch assembly and replace the bolt.Torque down the bolt,i can't remember the torque pounds,but i believe it's 100-200 lbs. of torque.B. Locke
Sep 28, 2015 | Craftsman Garden
Clutch replacement starter jackshaft
Hi, Gurueagle I am sorry you can't find the first and best tool you ever bought for your Bajaj but despair not for a mere $0 you can download another one. For more information about your issue, please visit the websites below. Good luck and have a nice day.
How to Replace Starter Motor on 150cc GY6 Scooter
Changing starter clutch on 150cc scooter
DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 15, 2013 | 2006 Bajaj CT 100
I have a 2010 cpi oliver city scooter and i cant get the drive belt on
Hi, Mikeaspearman sorry you can't find the first and best tool you ever bought for your CPI despair not for a mere $0 you can download another one. For more information about your issue and free downloads that you will need please visit the websites below. Good luck and have a nice day.
50cc 49cc Scooter Performance Clutch and Variator install variator roller...
How To Change Moped Scooter Drive Belt CVT
http://absolutelyscooters.net/service-manuals.html
CPI Scooter Parts Racing Planet USA
https://scootergrisen.dk/scooterhjemmeside/download/cpi_oliver_brugermanual.pdf
Jun 20, 2012 | 2011 Cpi Oliver City
Looking for a bladez DKS200 mobility scooter battery case?
http://www.bladezscooters.com/
http://www.monsterscooterparts.com/
Unlikely some other manufacturer's box will fit, if only because the circuit connecter is built into the pack.
May 03, 2012 | Health & Beauty
I have bladez moby that im being able to start but not to keep running, i used the ratio of 30:1 oil mix im not sure if its ok
Ok sorry you havent had an answer yet lol , here it is , i had this same issue . All you have to do is take the plastic cover off of the motor , and once its off pull the throttle ( with scooter off ) and you will see where it leades to . Where it leads to there is a screw which can be tightened to increase its motor stength / use . So tighten it , but only a little bit , if tightened to much the scooter will go without you pulling the throttle , so a 2-3 twists on a screw driver should do it. Once done , start your scooter up , and it should run great !
Dec 17, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
WILL NOT IDLE
vaccuum leak, or idle adjustment screw maladjusted.
Sep 28, 2009 | Tanaka 35cc Piston Kit Bladez Moby...
Moby bladez pull cord spring out how do i assemble it
The only trick to getting this back together is patience and determination. You must keep the spring flat as you wind it tight.
Jim
Jun 09, 2009 | Poulan 12a Elec Blower/Vacuum
Bladez 320-5M/25 Clutch Belt for BladeZ Moby Logo
400 people viewed this question
Top Bladez Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Bladez Toy Expert? Answer questions, earn points and help others
