Question about Hot Wheels Sizzlers Electric Car '70 Plymouth Cuda T/A
ENGINE WON'T RUN, TRIED NEW BATTERY - Hot Wheels Sizzlers Electric Car '70 Plymouth Cuda T/A
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
OEM parts for Yamaha
YAMAHA XVS950A Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 31, 2013 | 2011 Yamaha V Star 950
Electric blade clutch won't work and battery went dead
If you have a new battery and it went dead that quickly I would check the charging system on the mower engine. Many of them use a voltage regulator and if it goes bad it will not properly charge the battery. Get the engine running (do not engage the PTO) and use a multimeter set on DC voltage. Place the multimeter leads on the battery and you should see approximately 13-14 volts DC at the battery terminals when it is running. If less then that then it's a problem with the charging system and further tests would be needed to figure out if it is a bad regulator or charging coil.
Aug 23, 2012 | Husqvarna Garden
1994 Toyota Tacoma PreRunner - won't start with new battery, lights won't come on
Check your battery connections on the battery and the other ends where they go the ground will go to the engine block and the positive to a solenoid make sure all of this is tight and has no corrosion. This is just a loose wiring problem
Aug 18, 2012 | 2000 Toyota Tacoma PreRunner
1998 Ducati Monster 750 won't start. Ticks over ok, but won't "fire". New fuel in tank only two days ago, ran several trips since, just won't start now. Tried push-start, sounds like...
Hi, Mlyndon and the usual suspects are:
1. Fuel tank empty.
2. Fuel supply valve/petcock turned off.
3. Fouled spark plugs.
4. Engine flooded as a result of overuse of the enricher.
5. Vacuum hose to the fuel supply valve/petcock disconnected, broken, cracked, or pinched.
6. Fuel valve/petcock or filter clogged.
7. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
8. Loose or corroded wire connection at the coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, cable connections loose, or connected to the wrong cylinders.
10. Ignition timing incorrect due to a faulty ignition coil, ignition module or sensors (MAP, CMP, CKP, O2 and/or BAS).
11. Security alarm needs a reset.
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
1999 750SS engine turns over but won start Ducati ms The Ultimate Ducati...
Ducati Monster won start fixed see how
Free Ducati Motorcycle Service Manuals for download
Ducati OEM Parts Fiche Lookup and Online Ordering
Ducati Maintenance
Aug 31, 2011 | 1998 Ducati Monster 750 - Dark - City -...
Dear sirs, I have a 2000 Ford Explorer which won't start. All light in the dashboard turn on but the engine won't crank. We've tried to crank the engine direct from the battery and it cranked....
yea got get you more troubles
just check the alternator is charging well and no battery light on dashboard it indicate the bad alternator
monitor your battery if it got old and cannot hold the charge any more
you said when you used another one your car turned on
Jun 06, 2011 | 2000 Ford Explorer
Engine Won;t Turn Over when starting
GLAD TO SEE IT WAS THE BATTERY. PLEASE RATE MY SOLUTION.
Jan 15, 2009 | 1997 Cadillac Seville
Hot Wheels Sizzlers Electric Car '70 Plymouth Cuda T/A Logo
Top Hot Wheels Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Hot Wheels Toy Expert? Answer questions, earn points and help others
