Question about Samsung HLN4365W 43" Rear Projection HDTV-Ready Television
I am having a problem with my Samsung HLN4365W DLP Television. There are 10 vertical grey lines spaced about 3 inches apart running across the screen. Furthermore, the whole screen appears to be broken up by vertical lines. Any Advice??
    Brigadier General:
  • 3,513 Answers
Thanks for contacting Fixya.
Have you removed the back of the set and cleaned the fans every 6 months. It is a projector that depends on two computer fans to keep the lamp and the DMD control module within proper temperature limits. If those fans get dirty and slow down or stop, bad things happen. All it takes is a screwdriver and the brushy atttachment to your vac hose.
Now this happend, because a bad soldering connections in that module. Lines will come on and off. Probably 1 day will stay on. For last 2-3 years im seen that only on hlm and hln series. Probably
happens on other models. but, i never seen that. Is not that hard to replace that module. You have to remove 2 screws from left side and 1 screw from bottom righ side of module and 4 of them
from around dlp unit unpulag all cables ( i think 3 cables ) that it. Same way install new one in.
but you will need to adjust a module position to get picture to fill whole screen.
God Bless
Posted on Jul 15, 2009
I have a 43 inch samsung DLP tv 2004 model# HLN4365W, I was getting a black and white picture, so i replaced the color wheel which was broken. It worked fine for a couple of days then there was no picture,...
No picture on a DLP when you can see the lamp is working is ALWAYS the DLP chip. BECAUSE you recently replaced the color wheel, i suspect that the LVDS/data cable to the light engine was not plugged in well and has come loose. I suggest checking and rechecking every cable and plug you can find.
Aug 09, 2012 | Samsung HLN4365W 43" Rear Projection...
Samsung dlp
If you have have 40 vertical lines 16 pixels wide: DDP1011 or BCA, DMD panel interference: Replace the DMD board.
Jul 26, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
My samsung 55" DLP television
I looked up how to fix red horizontal lines on a Philips flat-screen tv. It turns out it needed the Y buffer upper replaced. I am not sure if this problem would be similar but it might help. I am also searching how to fix a fuzzy screen on a DLP tv. Hope you find what you need.
Nov 26, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung HLN4365W picture not centered
turn the tv off, hit mute 1 8 2 power, the tv will come on in the service menue, look in that menue for vertival and horizontal adjust, after you adjust it, just turn the tv back off, it will save your changes
Jan 07, 2009 | Samsung HLN4365W 43" Rear Projection...
White lines equally spaced 1" apart.
This is probably caused by the small signal board. It controls and decodes the picture information before it is sent to the display panel. It can be fixed by a quailified technician and if you contact philips (this is who makes magnavox) they will tell you the closest certified technician. Hope this helps.
Mar 29, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Dlp white vertical lines
YOU NEED CHECK THE 3 CRYSTALS ( RED, GREEN AND BLUE). CLEAN IT WHIT "DUST REMOVER" ( compressed gas duster) AND REPLACE THE COLOR WHEEL.
Jan 17, 2008 | Televison & Video
Dlp vertical lines
the person you talked to at samsung is more than likely a customer support rep that does know anything but what his computer tells him. i have seen this symptom several times in many makes and models. if you can give me your full model number i will give you a part number to fix this issue.
Oct 24, 2007 | Samsung HLN5065W 50" Rear Projection...
Samsung dlp
do they look like jail bars ,running from top to bottom.
Aug 30, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung HLN4365W 43" Rear Projection HDTV-Ready Television Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
